Sand base for climb...
[Closed] Sand base for climbing frame: Anyone done it?
11 Users
We have quite a big climbing frame, two towers, swings etc and it is a pain to maintain the grass, mow around it and keep it tidy. Has anyone used sand as a base? If so how much maintainance does it take?
Posted : 24/04/2017 8:13 am
Will sand not attract the local cat population to use it as a litter try?
Posted : 24/04/2017 8:15 am
Any cats in the neighborhood? You might just create an enormous litter tray...
edit: oops, crossed post
Posted : 24/04/2017 8:17 am
Have you looked at the rubber chips?
We were always going to do that and put down the anti-weed layer but it's still covered in small shingle... (which is what was there before and carrying it away never got done).. Now the kids 7 and frequently falls off his bike on single track, falling a few feet off the swing or climbing frame onto the shingle seems fairly minor 😀
Anyhow... we'd planned the rubber chips as it attracts less cat/fox poo than sand!
oops: triple posted except adding fox poo
Posted : 24/04/2017 8:18 am
Sand will just get kicked/transported all over the garden and house.
Falling onto wet sand is like hitting concrete too.
Woodchips might be better? A decent depth has a reasonable amount of give in it and will drain well too.
Posted : 24/04/2017 8:20 am
Hmmn, not keen on the sound of that. Would the rubber bark not have the sam effect, except for being invisible?
Posted : 24/04/2017 8:22 am
As per Bruce, if you have lots of cats locally, don't. Use fake grass or those soft rubber tiles.
If you have no cats locally a properly prepared sand area (gravel for drainage plus weed membrane underneath and properly boxed/edged) should only take about 10 minutes a month to deal with, if that. And a fresh 10 kilo bag or two of sand once a quarter or so depending on how much use it gets (the sand gets kicked out of the box on a regular basis.).
Depending on how much garden there is and what it's like, a bit of sand won't do any harm. You could barely see the sand in the grass once it'd been rained on and/or mowed once or twice.
We used "playground grade wood chips" for our garden. The rubber stuff is great but worked out about 3 times the cost.
Posted : 24/04/2017 8:30 am
RoSPA (yes, really) has a great section on play area ground coverings designed for Local Authority use. It's a great resource.
Posted : 24/04/2017 8:55 am
Thanks all, food for thought.
Posted : 24/04/2017 9:40 am
How about some artificial grass?
Posted : 24/04/2017 9:53 am
Might be an option jondoh, I am looking at all avenues.
Posted : 24/04/2017 10:12 am
Family of 6 with 4 kids, had a really big frame so used woodchips with a border about half a foot high. Only thing is a strimmer needs using for that edge next to grass. Lasted roughly 13 years before it all got removed.
Posted : 24/04/2017 11:26 am
We used playground bark - not all bark/chips are the same, the playground stuff is softer and there's more give in case of a fall.
Posted : 24/04/2017 11:28 am
