Rufford Ford
Rufford Ford
 5lab
some of those (like the mini) in the latest vid are getting borked on barely a puddle.
Posted : 08/01/2025 1:49 pm
jamj1974
I have not bought a Ford for some time.  Is there an issue?
<small class="bbp-reply-post-date" style="box-sizing: border-box; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-scroll-snap-strictness: proximity; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(59 130 246/0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; font-size: 10px;">Posted 1 hour ago</small>
As a current Ford owner...where would you like me to start ?
Posted : 08/01/2025 2:09 pm
There’s idiots who get stuck in water, and there’s idiots who get lucky and attribute it to being a driving god.
Or they could try just not being idiots. If you've no idea how deep it is, don't drive through it.
Posted : 08/01/2025 2:47 pm
steveb and steveb reacted
Or they could try just not being idiots. If you’ve no idea how deep it is, don’t drive through it.
I think you've got the wrong end of the stick.
They know how deep it is (6"), they probably tut on the internet when they see people who "drove into water that was too deep for their vehicle", then subsequently find out the hard way that kerb deep water is enough to kill an alarming number of cars.
And then in the case of Burnt Acres Road a picture of their car once the river has risen over the bonnet ends up on the local facebook group and people tut and ask why they "drove into water that was too deep for their vehicle".
Posted : 08/01/2025 2:58 pm
Part of the problem once you're in water is that it's almost impossible to turn around or to stop and reverse out, that'll kill everything just as much as carrying on.
Doesn't help when you have other drivers tailgating you through or getting impatient cos you're trying to leave a big gap to the car in front in case that stalls and blocks you in. It's easy to drive into something that you've just seen another car negotiate successfully but catch the bow wave wrong, dip into a pothole or just have a car that's not as capable. I think the problem is actually worse now because so many people have SUVs which they assume can do things like wading, driving on snow etc and then they find either that the car is a triumph of marketing over engineering or that they're not experienced enough as a driver to handle those conditions. Or both.
Posted : 08/01/2025 3:10 pm
hightensionline, tractionman, fatbikedog and 7 people reacted
Because they're driven by idiots who hit the water at speed. This forces it up into the air intake where it swamps the air filter. They would probably get away with it at this point if they let the engine idle so the water drains out, but they boot it instead and suck the water straight into the engine.
If you watch the videos you'll see most of the cars die the moment the driver mashes the accelerator pedal.
Posted : 08/01/2025 3:23 pm
When it rains, a small stream runs across my driveway.
Do I own a Ford?
Posted : 08/01/2025 3:28 pm
retrorick and retrorick reacted
You must live near some really big kerbs. They're all standard 100mm (ish) around here. 1st gear, slow and steady, etc. Can't see the kerb, turn around. We've had a fair amount of flash flooding recently that's put water at kerb height.
Posted : 08/01/2025 3:40 pm
Can’t see the kerb, turn around
that's my rule too, though last time I was in that situation (last year in Cov) I was in a long line of traffic, the concrete kerbs on either side of the road basically making it into a canal, I couldn't turn around doing a full 180 because of the limited width of the road (aka canal) and a 3-point turn was impossible because there was some spooner driving on my backside, fortunately the water did not get much deeper...
Posted : 08/01/2025 4:14 pm
It can happen to any of us in even the most innocuous puddle.
PXL_20230621_194012088-01 (1)
Posted : 08/01/2025 4:17 pm
crossed, davros, walowiz and 3 people reacted
Mental.. I hadn't seen this thread before!!!
There's a reason off road vehicles have those snorkle pipe things comming out of the bonnet!!!
Posted : 08/01/2025 4:52 pm
Saw the Qashqai video. The air intake is high up but it's right near the bonnet and anything over the bonnet will go in the intake. They were lucky. Won't take the wife's Qashqai through more than a few inches as I'd be in right bother.
Posted : 08/01/2025 6:04 pm
Saw the Qashqai video. The air intake is high up but it’s right near the bonnet and anything over the bonnet will go in the intake. They were lucky. Won’t take the wife’s Qashqai through more than a few inches as I’d be in right bother.
You'd need to sillicone all the joints in the air intake system& filter box too.. as the intake sucks air in really hard at high revs so it would suck water in wherever it can...and coil/ignition pack? presumably they are not waterproof on most cars...
Posted : 08/01/2025 6:15 pm
You’d need to sillicone all the joints in the air intake system& filter box too.. as the intake sucks air in really hard at high revs so it would suck water in wherever it can
Surely if it's air tight then you shouldn't need to do all that? If you have to apply silicone to seal then the joint was never good in the first place.
Posted : 08/01/2025 6:58 pm
chipster and chipster reacted
To me people posting with confidence on a subject they are not expert in is the same human trait that causes this sort of behavior. Over confidence arising from ignorance, e.g. Dunning Kruger. We all suffer from it sometimes. Any automotive engineers commenting here?
Posted : 08/01/2025 7:08 pm
Surely if it’s air tight then you shouldn’t need to do all that? If you have to apply silicone to seal then the joint was never good in the first place.
Between the filter and intake manifold, it should already be, but I wouldnt bank on anything on the 'non engine' side of the filter.
Posted : 08/01/2025 7:21 pm
4WD 24-7 on YouTube is one of my fave channels, I've seen them drive through water that's up to their chests lol!
As for the Rufford videos, they certainly seem to attract a certain type of driver.  A not very good type.
Posted : 08/01/2025 8:10 pm
Halfwits !! I’m guessing it’s a long diversion to avoid the flooded areas ? Hence the muppets going for it ?
Posted : 08/01/2025 9:05 pm
The tractor lad was on holiday when someone showed him the video, he turned himself in and got a telling off and a fine I believe. Notts CC have said theres no alternative to closing the ford. The locals I believe are appealing.
Posted : 08/01/2025 10:51 pm
1
Posted : 08/01/2025 11:03 pm
 rone
Well bridges are very expensive aren't they?
(There's a road bridge that goes over the A1 near Tuxford not far from there. That's shut to traffic because of no longer being strong enough. That's not been replaced.)
The Rufford area which I ride often - must have heritage based restrictions too attached to it, given the historical nature of that area.
It's really not that far around and very small roads/lanes near the ford so I'm glad it's shut. Just a rat run to the a614 between Ollerton and Nottingham.
There aren't that many locals in that area really.  It's a tiny spot.
(Technically it does have a small footbridge so you can ride and walk.)
Posted : 09/01/2025 7:00 am
Rufford is on some of the road routes I ride. I suspect the locals rarely have a problem with the ford as they know when it's safe and when it's not, and take the diversion when they need to.
These videos attract idiots to the area who then cause the problems that mean locals have lost the use of the ford when it's safe. Utter stupid morons.
Posted : 09/01/2025 8:04 am
As always, this is why we can't have nice things.
Posted : 09/01/2025 9:20 am
My sat nav always used to take me through that Rufford Ford when I went to Sherwood Pines. I think I have been through it once in the summer time when it was clearly no deeper than a few inches.
I did turn up once in the late autumn when it was much deeper. There were several people egging me on to drive through it. I stopped,  took a proper look to assess the depth and then gunned it straight through with my foot to the floor turned around to find a more suitable route.
I find it amazing that people will risk their expensive cars driving through deep water (or even shallow water in an inappropriate manner).
Posted : 09/01/2025 9:35 am
The lay person nowadays can't change their own engine oils - how would they have an understanding of the physics of hydraulic compression and bent conrods?
Saying that I understand it but accordingly I'm a social leper at dinner parties so it balances out.
Posted : 09/01/2025 10:21 am
You’d need to sillicone all the joints in the air intake system& filter box too.. as the intake sucks air in really hard at high revs so it would suck water in wherever it can…and coil/ignition pack? presumably they are not waterproof on most cars…
I was considering that in relation to our Fiesta and the stranded Focus.
On the Fiesta at least the airbox is mounted on top of the cam covers and the intake is  short hose from that to the front grille.  Ditto the coil is mounted on the end of the camshaft (I guess for historical packaging reasons, it's not driven off it anymore) so it's all quite well shielded unless you completely submerged the car. On a Focus the filter is a little lower behind one of the headlights and the spark plugs are exposed, there was actually an issue with them because the screen washers would leak, fill the space between the cam covers and then the car wouldn't start.
I suspect either he hit the water hard enough to do some mechanical damage and dislodge something or it's just sprayed into the engine bay and hit the electrics.
Posted : 09/01/2025 10:36 am
I guess it's all kind of redundant unless you've kitted out your car like a 'Camel' land rover for driving around in the Amazon...
Once you create a 'bow wave' up and over your front grille your gonna have a bad day as you will get water sucked into the engine via the air filter at a minimum...
Most intakes before the filter are mounted at headlight level or even lower, so you're going to lunch your engine anyway unless you do some serious mods.
Posted : 09/01/2025 5:33 pm
It’s really not that far around and very small roads/lanes near the ford so I’m glad it’s shut.
7 minutes extra! That’s over an hour a week, Tyrone!
Posted : 10/01/2025 1:31 am
@Kayak23 did similar at Penmachno a couple of years ago, except on the MTB. Had to strip the rear hub, BB and jockey wheels. Came out like a bog monster with long grassy stuff everywhere.
Posted : 10/01/2025 1:42 am
kayak23 and kayak23 reacted
It's not just the intake you need to worry about though. Driving through water is a terrible return on the  cost/benefit.
The cold water will get into bearings and past seals. Differentials and other gear housings will suck in water. Your lovely DSG box has a vent about 300mm off the ground.
All of the spinny mechanical bits on a car have breathers, they're all vulnerable and expensive.
I've got a 30yr old Toyota Hilux, it's completely fine up to about a 1m of water, chances are it would be ok deeper. I'd still avoid deep water if there was an option though because of the above.
Posted : 10/01/2025 8:45 am
If anybody has a replica of the car from The Spy Who Loved Me  - that would make a great video, just seeing how the crowd reacts.
Posted : 10/01/2025 9:05 am
Bloke at the start in the van trying to tell his boss or someone that a car coming the other way caused him to get stuck in a ford. Lolz 🙂
Lying on YouTube.
Posted : 29/01/2025 8:30 pm
It’s not just the intake you need to worry about though.
Also add to list under-trays, trim and bumpers ripped off even in a couple of inches if you are going quick enough. Just not worth it on so many levels.
Posted : 29/01/2025 8:45 pm
It's a 3.9mile detour 9min according to maps.
Posted : 29/01/2025 10:25 pm
 zomg
If poor road choice was about the time I wouldn't always meet drivers trying to rush through the terrible little back road past RSPB Fowlmere - that one doesn't even save any driving time according to Google, and certainly won't when you meet another driver coming the other way, yet people still have to do it because they're just that thick.
Posted : 29/01/2025 10:40 pm
It’s a 3.9mile detour 9min according to maps.
It's crazy what people do to save a few mins...
Unrelated, but I was in an accident many years ago, small flat-bed lorry carrying pallets insecurley in front of me, lost a stock of pallets off the back, some of which ended up under my car and into my bonnet.
So we both stop, hazards on, etc.. as I went to open my door to inspect the damage, someone behind me clearly decided they didn't want to be held up, and went tearing past me (you'd think it was prettly bleeding obvious what happened, given teh flashing lights and there were bits of smashed up pallet all over the road)...
Opened the door maybe ten inches and BANG! he caught his wing mirror on my door, ripping the whole unit off his car, probably did some damage to his door too, but he didn't hang around.. he was off!
Not only impatient, but also passing the scene of an accident with less than a foot gap between thier car and mine... I didn't really mind as my car was ****** anyway, but it would have been an expensive morning for him, all for the sake of saving a few mins...crazy!
Posted : 29/01/2025 10:50 pm
Well it's not helpful that Google Maps still routes vehicles through the ford.
Posted : 29/01/2025 11:40 pm
Defo this.  I hit some standing water last year, during a period of constant deluge, that was in hindsight probably 4 or 5  inches deep. Ford Kuga. Probably 35-40 mph. Ripped one of  the plastic under-tray half off. Total PITA as I had to get under the car by the side of the road, in the dark, pishing down, and try to get it sufficiently back in place that I could limp the 3 miles home and then fix it properly the next day in daylight.
Posted : 30/01/2025 12:02 am
Page 5 / 5
