Rubber pad on under...
[Closed] Rubber pad on underneath of kitchen sink. Will I die?
12 Users
Our stainless steel kitchen sink has a rectangle of stiff rubber glued to it. Or at it does some of the time as it regularly falls off.
Any idea what it's for? Is it supposed to deaden sound or something? I'm guessing the glue softens with hot water in the bowl - suggestions on how to stick it back?
Posted : 23/02/2017 3:01 pm
keeps the water going down your drain the right way. without you'll open a portal to the under-word and the un-dead will come and steal every other sock in you laundry...
probably
Posted : 23/02/2017 3:03 pm
I'd assumed it was just to avoid scratches when they stack them together in the stock room.
Posted : 23/02/2017 3:05 pm
It's a sound deadening pad. Think there's usually one under the drainer bit too.
Posted : 23/02/2017 3:17 pm
It is sound deadening. It may sound tinny if it's removed.
Posted : 23/02/2017 3:18 pm
Superglue? Bostik / Gorilla Glue type stuff
Or duck tape perhaps
It is sound deadening. It will sound very tinny if it's removed.
The sink will sound even worse 8)
Posted : 23/02/2017 3:25 pm
How old is the sink?
They used to be made of asbestos. You'll be OK if you're not drilling or cutting it, but just FYI.
APF
Posted : 23/02/2017 3:27 pm
You can replace it with any generic sound-deadening material.
I lined out cooker extractor hood with self-adhesive aluminium roof-flashing material.
The drop in noise was considerable.
Posted : 23/02/2017 3:33 pm
Learn something knew every day!
Posted : 23/02/2017 3:40 pm
That's what [i]they[/i] want you to believe
Posted : 23/02/2017 3:50 pm
Ours came off and it doesn't sound any different when running taps etc. However..... if you tip boiling water into the sink, it goes *bang* - the thermal expansion causes it to deform suddenly. The rubber mat used to stop this happening.
Posted : 23/02/2017 6:45 pm
 Bear
use some adhesive called CT1.
Posted : 23/02/2017 7:51 pm
That's a good idea. We've probably still got something similar kicking around from the build.
I was thinking car trip foam stuff but that might be better.
Posted : 23/02/2017 9:20 pm
 Bear
CT1 is amazing stuff, stuck a pair of trainers back together with it and they are still together.
Posted : 23/02/2017 9:25 pm
Bear - Member
Must make running in them difficult.
Posted : 23/02/2017 10:51 pm
