Roofing calculation...
[Closed] Roofing calculations?
Looking for some help in working out materials required for a new roof. I could just get a roofer round for a quote, but I don't want to waste anyone's time as I will probably source the materials myself and then hire in some labour.
It is a pitched roof, 30 degree angle, each face of the roof is approx. 110 sq metres, ridge length is 18m. The slates will be 32cm x 22cm and secured using the hook method, not nails.
How many slates will I need? Also, what should the batten spacing be, and how much batten will I need and what size?
All this is a bit beyond an IT bod . . .
Posted : 23/04/2013 9:54 am
you won't be wasting anyones time, you'll be paying for the knowledge and experience that a roofer has to order the right amount of materials.
Posted : 23/04/2013 10:57 am
At this point I just need to know how to work out the approximate amount of materials that would be required. From that I can look at suppliers, either locally in France or possibly in the UK or Spain which can be cheaper and/or better quality, and work out the appxoimate cost.
Getting a local roofer in who would only look at local suppliers could be a waste of his time. Having said that it might turn out to be the best option in the end.
Posted : 23/04/2013 12:15 pm
http://www.matchatile.co.uk/roof-tile-calculator.html
Posted : 23/04/2013 12:20 pm
Pjm84 that's for interlocking tiles, no good
Posted : 23/04/2013 12:34 pm
http://www.source4me.co.uk/calculate_roofing_slate.php
Chinese slates are cheaper still
Posted : 23/04/2013 12:36 pm
Holyzeus - thanks for the link. The slate sizes are not quite the same, but I can take a view based on the numbers for sizes above and below.
Chinese slates are cheaper, but I've heard of a few quality issues. I had Spanish slates on the house roof, so will probably go for those again.
Posted : 23/04/2013 1:34 pm
Doh! Looked at the Source website and attached the other link.
Posted : 23/04/2013 1:35 pm
Yeah see size's are not quite there but it'll give you a good idea. You are using a very small slate
Chinese really aren't bad but if you can afford better then good.
Only did hook slating once, bout 20 years ago!
Posted : 23/04/2013 2:08 pm
The size is a bit small, but that's the size used on the house and the barn looks to be about the same. I'm not sure what the implications would be of going up a size or two.
The French like the hook method, probably better in high winds, and apparently quicker to fit (although that is just what someone told me).
Posted : 23/04/2013 2:26 pm
They are quick to lay
Posted : 23/04/2013 2:47 pm
i like the hook method. as above chinese slate is sh1t. i won't go on them for repairs these days, fancy going up to fix a couple, only to have most of them around your cat ladder snap on the way up? no ta...
Posted : 23/04/2013 3:56 pm
