Remote Desktop
[Closed] Remote Desktop
12 Users
Remote desktop server only comes with W7 ultimate, is that right? Is there a way of getting it to work on other versions of W7 without having to upgrade the whole of windows?
Posted : 16/12/2010 3:13 pm
What's remote desktop server?
I can remote on to my W7 Pro machine from elsewhere with remote desktop... or is this something else?
Posted : 16/12/2010 3:31 pm
Use VNC instead?
RDP is active on all versions of W7 I thought?
Posted : 16/12/2010 3:52 pm
 nbt
Have you enabled remote access on the machine? It's not enable by default I think
Posted : 16/12/2010 4:02 pm
I might be thinking of Vista. Haven't checked W7 actually 😳
Posted : 16/12/2010 4:13 pm
No, it def. does not come with Windows 7 Home Premium...I tried it on Monday.
Posted : 16/12/2010 4:39 pm
RDP server only on Win 7 Pro or Ultimate.
RDP Client is on all versions of Win7
Posted : 16/12/2010 4:43 pm
Same as Vista then.
Posted : 16/12/2010 4:56 pm
Have a look at RAdmin, it's a very good alternative. Used to use it on old Win2000 servers.
LogMeIn too...
Posted : 16/12/2010 5:00 pm
LogMeIn is good
Posted : 16/12/2010 5:11 pm
The host end of RDP isn't supported in "Home" versions of Vista / Windows 7 (other than Ultimate IIRC).
However. If you fire up regedit and go to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server
You'll see a key here named "fDenyTSConnections", set to 1. If you set to 0, it'll accept RDP connections. Unsupportedly.
You're welcome. I accept payment in most major forms of alcohol. (-:
Posted : 16/12/2010 5:39 pm
(oh - this won't put RDP settings on the Remote tab of System Properties or anything like that, so to disable it you need to regedit it back again)
Posted : 16/12/2010 5:42 pm
2nd for LogMeIn or thirded
Posted : 16/12/2010 5:54 pm
Fairly sure I've used remote desktop on a vista home edition machine, from a W7 ultimate machine.
Posted : 16/12/2010 6:04 pm
That's exactly the kind of answer I was looking for. Cougar comes through as always 🙂
Posted : 17/12/2010 10:02 am
<grins> ta.
I do worry sometimes about the amount of largely pointless cruft floating round my head. I think my mind's like that carrier bag of largely unidentifiable cables and chargers that every geek has somewhere in their house. You look at it and think "why am I keeping this?" and then someone will ring you up one day going "long shot, but have you got a converter for a nine-pin European whosit to a UK 6-pin square connector" and you go "you know, actually..."
Posted : 17/12/2010 10:51 am
So do you know this much about other areas besides PCs? 🙂
I too have a box of electronic-related gubbins. I recently sorted it out and distilled it to all the useful stuff like 2.5" disk caddies and small portable dvd drives etc.
Posted : 17/12/2010 10:54 am
Like the box of cables - I know everything, of course, the problem is finding it. (-:
Posted : 17/12/2010 1:36 pm
Thought this might have been an interesting discussion but it seems you're all talking about novice RD tools 😉
Dave
Tivoli Framework (and TCM and TWS) Expert
Posted : 17/12/2010 3:29 pm
