Recommend me a........
[Closed] Recommend me a..... Weedkilker!
25 Users
 rob2
Got a gravel drive and weeds that just keep coming. Made worse by this warm and wet weather.
Recommend me a decent weed killer as its just taking forever to weed at the moment.
Happy to take some agricultural stuff if anyone had some in the south oxon area:-)
Posted : 10/06/2012 12:38 pm
Roundup?
Posted : 10/06/2012 12:41 pm
 Spin
Anything with glyphosate as the active ingredient.
Roundup is to glyphosate what Neurofen is to ibuprofen so look at own brand stuff to save a few quid.
Posted : 10/06/2012 12:49 pm
Salt.
Posted : 10/06/2012 12:53 pm
Pathclear.
Posted : 10/06/2012 12:54 pm
Dunno what the chemical difference is, but i've found Pathclear type products more effective than Roundup/ generic glyphosates, as it appears to contain stuff that resides in the earth for longer and prevents germination of more seeds.
Posted : 10/06/2012 12:58 pm
Salt if you don't want anything to grow there for years.
Or spray a mix of vinegar, salt & washing up liquid on them. Works fast, but wear gloves.
I've read about people killing weeds with Coca-Cola as well, no idea if it wors.
Posted : 10/06/2012 1:08 pm
 dobo
rounup and other off the shelf stuff doesnt really work that well on some plants.
i got some big leafy things that just turn yellow and then come back to life..
also B&Q has value range that has glyposhate in? same mg amounts too.
Posted : 10/06/2012 1:14 pm
glyphosate based
or elbow grease, ie lift gravel and lay a membrane, I did and I get very few weeds, and as they're gravel rooted only they pull out easily
Posted : 10/06/2012 2:06 pm
 rob2
Squid - Is that just vinegar, salt and washing up liquid? Or do you add water? It's got a concrete then clay base but they are beginning to seed into the clay
Posted : 10/06/2012 4:01 pm
You need a friendly farmer to buy some glyphosate from. The stuff jo public can buy is watered down shite! Glyphosate is what you need, it does't need to be round up, most of it still comes from Monsanto anyway.
Posted : 10/06/2012 4:07 pm
We used to use the industrial (farm) strength Roundup on the estate and it killed EVERYTHING we used to spray it over 1/4 to 1/2 acre areas before working the land for replanting and it was excellent since they have marketed in the consumer market it's crap.
The consumer version must be water down to hell as we used to use it at home (after my recomendation to the gf) at it's been bobbins. 🙁
Posted : 10/06/2012 4:08 pm
Again it's all about the glyphosate.
It comes in all shapes, sizes, powders, liquids etc. Just get whatever one gives you the most actual active ingredient for you cash.
Posted : 10/06/2012 4:12 pm
a blend of Grazon and Roundup will do a good job.
Grazon is ace stuff as it will not effect grass (as long as you dont use it in too strong a concentration and not during drought conditions) - its made a great job of bringing the field back to a meadowland from an overgrown thistle and bramble thicket.
Posted : 10/06/2012 4:56 pm
Clinic Ace available from MVF does a good job at about 20% of the cost of the named brands. SBK can be used effectively for broad leaved weeds in grass. Pathclear is still one of the best residual weedkillers for gravel.
Posted : 10/06/2012 5:55 pm
if only it were that easy
Posted : 10/06/2012 5:58 pm
As above, i use rock salt, the stuff they put on roads, fill a watering can half full ofsalt then add water, stir up, and just water the drive, repeat a few days latter, works every time.
Oh and its so cheap.
Posted : 10/06/2012 6:01 pm
[b]Rob2[/b]
The most effective home-made weedkiller is a mixture of four cups of vinegar to half a cup of salt and a couple of teaspoons of washing-up liquid. When the salt is fully dissolved, just spray or wipe it on to broad-leaved weeds such as docks and ground elder. Unfortunately, it is lethal to all other plants around it as well. It works best in sunny conditions.
Found [url= http://www.guardian.co.uk/lifeandstyle/2008/sep/08/gardeningadvice.gardens ]here[/url]
It also notes
Gardeners have made their own weed controls for generations, but home-made herbicides and pesticides are illegal under current EU legislation.
But I won't tell if you won't...
I think you could prob dilute with water. Use a very cheap plastic sprayer, as the salt will knacker it after a few uses. Oh, and it's smelly, so make it up in the garage or somewhere.
Not saying it's better than RoundUp (etc). And it is more hassle. But our water comes from a well at the back of the house, so I'm wary of spraying chemicals about unnecessarily.
(Note for pedants: yes, I know salt [etc] is a chemical, But I reckon if I'm happy to put it on my dinner plate, I'm happy to put it on my garden).
Posted : 10/06/2012 6:11 pm
I have a few large patches of Ground Elder and the stuff we put on (glyphosate based) didn't even touch them.
Posted : 10/06/2012 6:14 pm
 flip
I run a gardening business and have a pesticide license, this is what i mostly use for the circumstances you have:
http://www.pitchcare.com/shop/professional-total-weed-killers/rosate-36-5l-glyphosate.html
It will kill all the usual weeds no problem.
Posted : 10/06/2012 6:39 pm
anagallis_arvensis - Member
Ok, worked for me.
Posted : 10/06/2012 9:10 pm
looked like a better meadow before you started, now you just have some bits with long grass!!
Posted : 14/06/2012 3:57 pm
Sorted the house out nicely though! "Just spray on" you say...
Posted : 14/06/2012 4:14 pm
Just normal Table salt kills weeds?
Posted : 14/06/2012 4:17 pm
My wifes chicken gravy
Posted : 14/06/2012 4:26 pm
If you're using "bought" stuff just make sure it systemic - the plant actively transports it through itself.
Posted : 14/06/2012 4:51 pm
Anyone in the business know how close we could use weed-kill (for horse tails) up to our evergreen hedge, without killing the hedge? Estimates will do.
Posted : 14/06/2012 4:54 pm
Horse tails are notoriously difficult to deal with. A good solution is to cover the affected area with cardboard then heap compost on top. This will need to be repeated, but will enrich the soil and reduce/cut out numbers over time.
Posted : 14/06/2012 8:00 pm
Quick thread resurrection... anyone got any experience of "Kurtail" (aka Kibosh) seemingly a specific Horse tail weed killer?
It's downright silly expensive and I'm wondering if it 'is' any better than any other std glyphosate weed killer.
(this is our front 'lawn' ['area' as it not actually lawned] so SteveO's suggestion may be great but isn't what my partner wants on display..)
Posted : 25/06/2012 10:01 am
 flip
Not had experience of this particular pesticide but its not over expensive if it does the job, that 0.5l pack covers 1000m2.
Horsetail is a bugger to shift, repeated doses of Rosate 36 does work but you have to keep at it.
Posted : 02/07/2012 6:17 pm
I've just ordered a bottle of kurtail, and yes, at nearly forty quid, it seems expensive, but there is enough for repeated applications, and if it works it'll save me a hell of a time.
Posted : 08/07/2012 8:55 am
zippy, I know someone who paints on glyphosate 360 with a 1/2" paintbrush, to do very selective weedkilling, I'd do a tester first though
Posted : 08/07/2012 9:01 am
