Recommend me a seri...
[Closed] Recommend me a seriously warm inexpensive base layer
Many thanks in advance.
Posted : 05/01/2017 5:33 pm
I've liked my Decathlon thermal ones. Zipped high collar and a thermal fabric.
Posted : 05/01/2017 5:36 pm
Look out for Patagonia Capeline 4 in a sale. Mrs_oab had one that cost £10 in Aviemore.
I find most base layers the same because majority are made of either polyester or wool.
If you get the polyester material make sure you go for those with "double layers" polyester. As for wool they all (mostly) give you itchiness but warmer IMO.
Brand wise I don't know ... plenty about in sales at the moment.
Posted : 05/01/2017 5:41 pm
IMO a base layer shouldn't keep you warm, that's the job of other layers. Your base layer should act as a windstopper and, most important of all, keep you as dry as possible.
My Gore Bike Wear base layer is absolutely indispensable during cold winter months.
EDIT : Sorry I assumed that you meant base layer for cycling but perhaps you didn't?
this came up a bit ago... wasn't the consensus that some Helly Hansen or other was the winner?
Posted : 05/01/2017 5:47 pm
doris5000 - Member
Yes, that's it Helly Hansen ...
Posted : 05/01/2017 5:48 pm
Not sure what seriously warm means here but my cheapy Trespass is great- wicks away sweat and keeps me warm even when it's damp. Too hot for riding, generally. But I don't think it'd pass for arctic kit.
It doesn't do any windstopping, put the windstopper on the outside.
Posted : 05/01/2017 5:49 pm
[i]Your base layer should act as a windstopper and, most important of all, keep you as dry as possible.[/i]
Surely the windstopping element should be on the outer layer of your clothes. I would also second the Decathlon base layer for cheap and functional.
Posted : 05/01/2017 5:56 pm
In winter you want polypropylene for base layer. Warm, and will not retain moisture, (you can wear it under wetsuits as insulation).
Cheapest I could find (although I think decathlon do a triboard one)
http://www.hall-fast.com/safety-at-work/workwear/hellyhansen/wind-wet-cold/helly-hansen-kastrup-crewneck/?gclid=CjwKEAiA-rfDBRDeyOybg8jd2U4SJAAoE5XqAmyzPI4meMBF_mcze6b6zqaH7SgpFQiAen73MfZjgRoC-Dnw_wcB
Definitely the wrong way around, if you're relying on your baselayer as a windstopper, how are the outer layers going to offer any insulation with gale blowing through them?
Outer layer for wind/water resistance.
Mid layers for insulation
Base layers for insulation or cooling*
*Lycra in summer base layers does the opposite of polypropylene in winter layers and 'wicks' moisture, thus keeping it on your skin and cooling, polypropylene works by just letting your skin breathe in the first place.
Posted : 05/01/2017 6:05 pm
 ton
i use these. toasty and cheap.
https://www.johnnorris.co.uk/snowbee-base-layer-thermal-underwear-set-grey-marl.html
Posted : 05/01/2017 6:06 pm
HH for the win IMO. Cant kill them with a stick 🙂 and the new ones dont smell.
Probably lots of stuff that is as warm but for wicking and speed of drying I have never found anything to touch HH.
Posted : 05/01/2017 6:07 pm
Sports Direct have a few, Campri or Nevica branded, about £10.
Posted : 05/01/2017 6:11 pm
i bought a troy lee one because it was cheap, wasnt expecting much, but its really good. use it on its own or if cold with an old on one merino long sleeve under my gabba and have been fine so far. i really feel the cold.
interestingly popped on a 2xu shirt as well the other day and was soaking when i came off the bike, and the 2xu was way more expensive.
Posted : 05/01/2017 6:47 pm
It will. My Polaris thermal top has no problem keeping me warm in freezing conditions. If I start sweating the limited air movement allows it to dry quickly. Because the base layer is like a second skin it wicks quickly despite acting as windstopper.
That's why Gore Bike Wear make windstopper base layers :
[url= https://www.amazon.co.uk/s/?ie=UTF8&keywords=gore+base+layer+windstopper&tag=googhydr-21&index=aps&hvadid=65684548256&hvpos=1t1&hvnetw=g&hvrand=14195735039576864165&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045872&hvtargid=kwd-28652819175&ref=pd_sl_8qgjgrhhex_b ]Clicky[/url]
Posted : 05/01/2017 8:39 pm
Windstopper base layer? Sweaty like a pig in a butcher's... Just because you can...
Posted : 05/01/2017 8:53 pm
I use a 350 Smartwool base layer for walking, its pretty bloomin warm, not sure I could cope with that level of warmth on a bike though, although being in the chat forum maybe its for general use?
Posted : 05/01/2017 9:03 pm
HH Warm is the badger's nadgers.
Posted : 05/01/2017 9:05 pm
Windproof base layer lol
Posted : 05/01/2017 9:19 pm
[url= http://www.brynje-shop.com/en/sportswear~c12/brynje-super-thermo-shirt-10200300-p9610 ]Very much not a windproof base layer[/url] although there is a windstopper version.
I roasted in one of these under a Rab VR jacket in the 'Puffer one cold year.
Posted : 05/01/2017 9:27 pm
If a base layer is windproof, it's not going to wick, because it'll have some sort of membrane to stop the wind.
I reckon that Gore stuff is just using 'Windstopper' as a trade name.
Fleece isn't in any way windproof, not without a membrane, which is why something like a Buffalo Wind Shirt over a fleece/wicking baselayer works.
Posted : 05/01/2017 9:30 pm
CaptainFlashheart - Member
I have it on good authority that Flashy has first hand experience of this.
Posted : 05/01/2017 9:31 pm
Layers is the key. All of mine are ski tops. Start with one, maybe t-shirt over for riding. Colder it goes to two. Stupidly cold, three.
Not sure what my stuff is other than various ski top/base layers that I've got from numerous ski shops around the world.
Also got HH stuff, but much the same as the generic stuff. As I say, the key is layering.
Posted : 05/01/2017 9:33 pm
Beg to differ on the HH [b]Warm[/b] tops. Hybrid merino/man-made. The fit is ace. The fabric very good. Best for cold, damp days.
Different better is Patagonia Capeline in 1&2 flavour - wicks like nothing else.
Buy way better than all my other base layers.
Posted : 05/01/2017 9:37 pm
They're right, you're not. Well you are and aren't.
Base layer for wicking, mid layers until you are warm enough for insulation, and the outer shell keeps the wind and rain out, or just wind.
Gore make windstopper base layers because people will buy them when they aren't needed. Same reason they make windstopper mid layers.
Insulation is based on the idea of trapped air. So if you don't use an outer windproof shell, the trapped warm air is blown out of the fabric by cold incoming air. Now, you may want this to happen on a bike where you are warm and need the sweat drying off, but if it's really cold you won't.
A single windproof outer layer with a base layer is much warmer than a stack of fleeces without a windproof layer.
Anyway to the OP - base layers come in a few weights, but if you are really cold you want to stick more fleece on - it's cheap enough. Best wicking base layer I've ever used is a Mountain Warehouse one, it was £6.
Posted : 05/01/2017 9:47 pm
Sports Pursuit had the Helly Hansen merino/polypropylene tops cheap a while ago (I bought three, and they're my go-to base layer this time of year). Worth a look.
Posted : 05/01/2017 9:49 pm
Windstopper doesn't mean waterproof. My Gore Bike Wear windstopper base layer, which I've been using in freezing weather conditions for about the last 10 years, keeps me remarkable dry due to its wicking properties - no matter what the pace of the ride. I've tried other base layers and ended up with a damp base layer for the duration of the bike ride.
Wear whatever works for you.
Posted : 05/01/2017 9:50 pm
Has to be said the windstopper boxers in Ernie's link must make it difficult to fart in anyone's general direction except your own
Posted : 05/01/2017 10:00 pm
If you really want seriously warm, just cut the crap and get a buffalo
Supposed to be worn next to the skin, so no base layer needed
Posted : 05/01/2017 10:07 pm
You could always get the Helly Hansen 'workwear' baselayer:
http://www.screwfix.com/p/helly-hansen-kastrup-baselayer-crewneck-black-large-42-chest/55368#product_additional_details_container
Which has a striking resemblance (in terms of material) to some of their other performance baselayers:
https://shop.hellyhansen.com/en_gb/shop/pages/base-layer/hh-dry-stripe-2-crew-48052
Posted : 05/01/2017 11:12 pm
Not necessarily as I think it depends on the activity and the individual (and their moisture 'output')
I've tried loads over the years and my personal choice for winter activities (with the exception of running) is a close fitting merino base layer. If it's super cold then I wear 2 x merino.
This approach has worked well for me for everything from wintry bike rides to arctic expeditions.
I find that if polypropylene gets even slightly damp through sweat then when I stop the activity I will cool down really quickly and shiver - as others have said the advantage of merino is that you stay warm even when damp.
These days you can pick up merino base layers quite reasonably, however I think its often worth paying for quality as they last longer and don't itch.
Posted : 06/01/2017 9:33 am
Two options here
- Brynje mesh, excellent, really
- Powerdry, something close fitting made of this. Excellent wicking very warm, doesn't feel wet. I have a Marmot Thermo 1\2 zip
These sort of items come from an outdoorsy background rather than a cycling background. Former is not something you would want to wear in public though, latter is fine.
I had to wear a thin softshell over my Brynje mesh when I went for dinner in Chamonix after a walking trip, baselayer on its own was not a good look - i was absolutely boiling!
Posted : 06/01/2017 9:42 am
Sub sports COLD - can pick them up from £11 from amazon/sports pursuit
Nearly kills me putting it on as it's a bit tight, but lovely and warm once on.
Posted : 06/01/2017 9:44 am
Yes and no. I have a windproof base which is great on the roadbike under a thermal layer, on nippy dry days. Wouldn't bother with in offroad.
Probably the best 'base' layer I have is a Castelli tea bag top which I wear under wool as it moves sweat incredibly fast away from the body. It's actually really good in the summer too for keeping you cool - you can often see TdF riders wearing them under team kit.
Otherwise it really depends what you're doing. In my experience (and in colder conditions) wool is great for slower activities as it retains heat well, but it doesn't wick as brilliantly as marketing claims. Cheaper wool can also be itchy. Synthetics can wick incredibly efficiently while moving and sweating, but can chill in cold conditions if you're stop/start, so best saved for either shorter, intense activities or prolonged spells, such as adventure racing. Glad to be contradicted on this too. 🙂
Personally I like Helly Hanson base layers, which I often wear as a mid layer. I also like Planet X merino/Coolmax tees which work well as a compromise between wool and synthetic - they fit well and look good enough to wear on their own in the summer.
Posted : 06/01/2017 10:01 am
I suffer badly with the cold (especially a recent ride in -8 temps). I read an article recently on Cyclingtips by a Pro roadie who mentioned that the best way to stay warm in winter is a string vest base layer with another normal style one over the top. Tried it, works a treat. I have a castelli string vest type affair (much amusement for the other half) then use either a Nike skinfit thing over the top or a HH long sleeve base layer . Super warm, not sweaty at all and not massively bulky either.
Having tried other brands, Endura are utter bobbins. Not warm, holds moisture so you get even colder and not cheap.
Posted : 06/01/2017 10:02 am
Uniqlo Heattech:
http://www.uniqlo.com/uk/store/feature/uq/heattech/men/
Posted : 06/01/2017 10:08 am
No it's not. It' really is a next to skin, windproof baselayer using the Windstopper membrane. My experience of using WS N2S years ago is that it's brilliant in a very narrow window of conditions. The rest of the time it's unpleasantly sweaty. I wouldn't touch it with a bargepole.
Haglofs used to do a brilliant 'warm' baselayer that was a hybrid mix of merino wool and Polyester. The merino was on the inside for comfort, the polyester on the outside to wick stuff away. However it worked, it was really good.
Posted : 06/01/2017 10:11 am
A secondhand Merino or other soft wool jumper from a charity shop can cost bugger-all. I wear old shrunk ones under tees, and IMHO your windstopper should be the top layer to trap warm air next to your body within the fabric.
Posted : 06/01/2017 11:05 am
When you say 'tee', you don't mean cotton, do you? Cost that will not help you keep warm.
Posted : 06/01/2017 11:20 am
Merino is OK, but it's not the miracle people say it is, if it get's wet it stays wet and stops being insulating.
Polyprop repels water which is why it doesn't 'wick' like lycra (or cotton, or wool), if you dunk a fleece in water, it won't draw water up, but if you put it over a bowl of hot water the steam passes straight through, do the same with lycra or merino and you end up with damp lycra/merino.
I have merino baselayers, and they're my go-to most days, but for properly cold days polyprop base layers are almost unbearably hot when the temperature goes back above zero.
Posted : 06/01/2017 12:25 pm
Hmm.
Cotton soaks up water, which is why it 'wicks' when you stick a piece of it in water. But we don't want this in our outdoor gear, as we end up with lots of water not going anywhere. You don't want the base layer to soak up water, you want it to transport it.
Fine enough fleece will wick via capilliary action not absorbtion. Wear a fine fleece as a mid layer, do lots of hard work then take the outer shell off - you'll see a mist on the outside of the fleece. The temperature and humidity gradient transport the water - which is why the glass of water experiment isn't a good model for outdoor wear.
In other words - just because a fibre doesn't absorb water, doesn't mean it's bad at wicking - it means it's good.
My best ever wicking Mountain Warehouse base layers are made from polyester as are my fleeces IIRC.
Posted : 06/01/2017 12:44 pm
I'm not sure I entirely follow your reasoning but I may have understood ...
Firstly, a base layer [i]should [/i] wick - that's one of it's prime purposes isn't it?
Secondly, Winter days often start off really cold and then air temps end up much milder with the effects of solar radiation etc, before dropping dramatically again when the sun sets. I would have therefore thought that material that becomes 'unbearably hot' should be avoided.
Rule of thumb in winter activities is take a layer off before you get hot and put a layer on before you get cold. Having an 'unbearably hot' layer sounds like something best avoided in my experience - rather like when you see people out UK hill walking in a down 'belay jacket' and then they wonder why it's wet through on the inside and they are uncomfortable for the rest of the day.
Posted : 06/01/2017 12:46 pm
Windstopper base layer is for when you sit directly under an AC unit at work but are still expected to have a professional shirt+tie appearance. Can't think of any other use for one.
Posted : 06/01/2017 12:56 pm
Different things work for different people so there isn't a single answer.
If you're sweaty then there aren't fabrics that will wick everything to an outer layer that is breathable to let it through. In that instance you need multiple layers to keep you warm but that don't lose their insulation when damp. That's me and I find merino base layers ideal for that and much nicer next to the skin when damp than synthetics.
If you're not sweaty then the classic wicking base later followed by breathable layers to a windproof outer is what you need.
Posted : 06/01/2017 12:58 pm
Same here! My standard winter attire [in the mountains] after years of trial & error, mix & matching is:
Merino boxers
Merino Long-johns
Merino socks
GoreTex shell pants (with vents)
2 x Merino LS tops
GoreTex Shell jacket
When touring/skinning I will normally remove the shell jacket.
The merino tops mean than even when my back is sweaty from carrying the backpack, I won't get chilly as I cool down.
But yes - different things work well for different people.
Posted : 06/01/2017 1:08 pm
So Digby - do you sweat much in that getup?
I sweat plenty (last night I went running in around 0C weather, I wore a tshirt, and it was still soaked through with sweat and it was dripping off my forehead - at the same time as my bare arms were stinging with cold air), and I hate merino because it just gets soggy and baggy.
My polyester layers move much more of the moisture so there is much less dampness and I'm still warm because I have enough insulation layers on. In principle, at least - usually I'm in just a base layer and light soft shell on the bike, it has to be damn cold for me to put a third layer in.
Posted : 06/01/2017 1:11 pm
HH normal are great, HH warm are very warm. Skiing more than riding IME.
I have some old M&S warm base layers which are incredibly warm. Too warm for lowland activities IME again
Posted : 06/01/2017 1:18 pm
 scud
In the usual STW vein of recommend what you own.
I got one of these free from Human Race for doing a number of their events, made by Craft, been really good, warm but not so warm you overheat, comfortable next to skin and wicks really well
http://www.wiggle.co.uk/craft-active-extreme-20-cn-ls-base-layer/?lang=en&curr=GBP&dest=1&sku=5360770305&kpid=5360770305&utm_source=google&utm_term&utm_campaign=UK_PLA_Clothing&utm_medium=base&utm_content=mkwid%7csrxeQDmCr_dc%7cpcrid%7c67090791782%7cpkw%7c%7cpmt%7c%7cprd%7c5360770305uk
Posted : 06/01/2017 1:19 pm
I tend to run quite 'hot and moist' at the slightest bit of physical exercise! 😳
But that 'getup' has proven to be a good compromise and the best at avoiding me being uncomfortable.
When 'cruising the groomers' I would be unlikely to break out in a sweat from about plus 3 Celsius down to about -7. Outside of that range I would adapt and remove/add a layer.
When climbing/bootpacking/skinning I would avoid setting a pace that resulted in overheating as once you overheat I find it's hard to get control over your body temp again in colder climates. But to answer your question, yes I sweat but not excessively - it tends to be my back (under the backpack) and my forehead (absorbed by a buff or sunhat)
edit - just read your addendum Molgrips - my previously exception was running in merino: Like you it just gets sweaty and baggy. I once ran in merino in Canada in minus 20 and I still got sweaty and baggy!
For running in cold temps I'll wear an Arcteryx Phase base layer and lightweight jacket or technical t-shirt on top (depending on the wind, rain, snow etc)
A big difference I think is the relative humidity/dew point in the UK compared to the alps etc - which means I tend to sweat more when exercising in the UK, so I adjust my wardrobe accordingly.
Posted : 06/01/2017 1:25 pm
Lidl France currently has ski base layer in stock. I prefer it to Northface, Northcape and some fancy merino things I've got.
Posted : 06/01/2017 1:47 pm
Very good point. Relative humidity is pretty high in the UK, especially when the winds are coming from the south or west.
Posted : 06/01/2017 2:36 pm
I am probably guilty of not reading properly but I am talking about riding mostly, and in the UK.
Craft Extreme Zero base layers are the ultimate answer for this. You can go out in one down to zero degrees with just a normal jersey over the top. Amazingly good quality (some of mine are 7 years old) and just wonderful to wear.
They do one with a layer of Gore Windstopper on the front , over the normal fabric. They're great, you can then go out on a windy but not rainy day without having to put on a boil in the bag coat to stop the wind. I have two and lover them.
Posted : 06/01/2017 2:50 pm
Yeah but the disadvantage of having two functions in one garment (windproofing and wicking) is that you can't just remove one if conditions change. This is why personally I dont' wear them. Especially MTBing where you might be winching up a big climb for ages then pop out of trees into cold wind for a long descent.
Posted : 06/01/2017 3:03 pm
And I think I went off at something of a tangent with the merino pants and mountains etc ... apologies ... however to be fair this is in the 'chat' forum and the OP's slightly vague request was just for a 'seriously warm inexpensive base layer'. No activity was specified.
From a personal perspective I don't think I would ever wear anything 'seriously warm' i.e. 'insulated' etc on the bike as I'd be 'steaming' within minutes. I'd rather have a gillet or something that can be quickly removed and put back on again.
Posted : 06/01/2017 3:11 pm
I've got one of these
[img] ?v=1462461566[/img]
definitely one of my warmest base layers.
Posted : 06/01/2017 3:19 pm
Yep, given away all my Icebreaker stuff and just use Polartec Power Dry or HH Lifas.
Posted : 06/01/2017 3:27 pm
I have been very impressed and kept very warm Icebreaker Merino (stink free too), Cheap Decathlon Ski baselayers (7 quid!) and Under Armour Coldgear (current favourite as the compression is ace).
You pay your money, you takes your choice!
Posted : 06/01/2017 3:31 pm
I never really rated Icebreaker merino ... it seems to develop holes and become 'threadbare' in places very quickly.
Over the years I've had merino from:
Howies
Icebreaker
Ortovox
Sweet Protection
Rapha
Race Face
My Howies Merino LS Tops (made in NZ) are over 10 years old and still going strong having done multiple winter seasons (although the armpits are a bit 'stiff' with deodorant) They are also the least itchy. The newer Howies merino tops don't come anywhere close! 🙁
The Race Face 'stark' wool LS has been a bit of a revelation and so far has lasted much use, abuse and 40 degree washes with velcro and zips.
and I've worn merino for 2 weeks continuously without bathing (apart from wetwipes and 'dry shower') and I was very impressed with the low 'pong'. Not a miracle by any stretch of the imagination but much 'fresher' than silk base layers - which tend to smell of 'bums' when not washed regularly! 😳
edit - lovin' the chunky cable knit jimjam! 8)
Posted : 06/01/2017 3:55 pm
and I've worn merino for 2 weeks continuously...
Pretty much this, albeit with washing sometimes. Lived in a merino T while driving to the Balkans and back in summer 2012. The lack of niff was appreciated.
Posted : 06/01/2017 3:59 pm
Yes - wore my Louis Garneau roadie winter top on the MTB the other day and regretted it. Boiled on the climbs. Works better on road because I generally still have decent airflow even when going up.
My icebreaker merino wore a big hole in the back under where my camelbak goes.
Posted : 06/01/2017 4:12 pm
Firstly, a base layer should wick - that's one of it's prime purposes isn't it?
It should be breathable, which is different to wicking.
Put on a merino or lycra baselayer and go for a run (or even better, put something warm on top and go for a run). The baselayer gets sodden. Take the outer layer off (like you would when out on the bike and warming up) and you're stood there in a wet t-shirt.
Repeat the experiment in polypropylene and it will be much, much dryer.
Same applies if you get caught in a downpour, fall in a river, etc. Polypropylene layers don't hold water. I wear it under my wetuit when sailing as well, take the wetsuit off and it's clammy rather than "wring it out" like a lycra rash vest.
Ok, unbearably hot is an exaggeration. How about "hot enough that you have to seriously re-calibate the number/type of layers you wear on top if you're used to wearing lycra/merino. A polyprop base layer under a windstopper type jersey is about as a lycra base layer, under the same jersey, under a softshell.
Posted : 06/01/2017 6:45 pm
I think we'd already discussed the fact that merino is perhaps not an ideal choice for intense activities like running.
Horses for courses and and all that.
Different base layers can have different roles and suit different conditions/people.
From my perspective, a close fitting base layer should wick and a fleece layer should be 'breathable'. You may wear one, the other or both depending on the circumstances:
Arcteryx explain this quite nicely with a summary of the technologies available in their base layer range:
[url= http://www.arcteryx.com/baselayers.aspx?country=gb&language=en ]Arcteryx Base layer info[/url]
Posted : 06/01/2017 7:13 pm
Decathlon's new range from their basic to the Xtra Warm are great.
Kept me toasty on the run down to Italy last month on the GS despite it being -6 and more without windchill!
Posted : 06/01/2017 8:28 pm
Before OP gets excited, Arcteryx != inexpensive
Great company, just don't expect to buy one if you need a cheap BL.
Posted : 06/01/2017 8:53 pm
cheers for that, was just going to ask something similar, have rapha mesh ones, but a full jersey under my jacket feels too bulky, will try just that
Posted : 06/01/2017 8:58 pm
