Recommend me a satn...
[Closed] Recommend me a satnav app for an android phone that doesn't chew through data
Looks like I'm finally going to have to join the world of satnav users, so looking for an app that I can put on the phone and which won't run through my entire data allowance in one journey.
What are people using at the moment?
Posted : 01/03/2015 10:25 pm
 zap
take a look a copilot, It works offline, very good cost about 22 pounds from memory for ios
Posted : 01/03/2015 10:31 pm
Sygic? Just download the area you're likely to need.
CoPilot user here on Android... Very good, reasonably cheap. Maps on phone/sd card. And I've been able to transfer it as I get upgraded phones
Posted : 01/03/2015 10:32 pm
Yeah, you need one with off line maps. Co-Pilot seems to be commonly recommended.
Sat nav doesn't use much data though....but suppose it depends on your allowance as to whether it's too much or not.
Posted : 01/03/2015 10:33 pm
Cheers, I'll have a look at Co Pilot to start with
Posted : 01/03/2015 10:37 pm
Google maps works fine for me and it's not that heavy a user of data. You can preload areas for use offline too. The integration with google now is cool, it pings me a message if traffic is bad enough for me to have to leave earlier for work.
Posted : 01/03/2015 10:41 pm
I guess another benefit of on-board rather than on line mapping is that battery life will also improve.
Posted : 01/03/2015 10:43 pm
google maps is very data light
Posted : 01/03/2015 10:44 pm
for the car, navfree
for the bike, backcountry navigator (costs a few quid for the full version and detailed maps can use a lot of storage)
Posted : 01/03/2015 10:46 pm
Get Nokia Here maps from the play store and download the UK map its free, once you done it doesn't use any data.
Posted : 01/03/2015 10:48 pm
NavFree, much better than CoPilot for giving routes across country, instead of forcing you to use all A-roads and motorways. I've used both for some time, and I prefer NavFree.
stuartlangwilson - Member
Problem is, if you're somewhere with zero data, and you need to download new map info, you're stuffed.
I had that problem in South Devon, CoPilot couldn't give me a route to a place I wanted to go on Dartmoor, and I had no phone signal and no wifi.
Having a navigation app with all the map data native to the phone wins every time.
Posted : 01/03/2015 11:06 pm
Another one for NavFree - not just for UK either, it took me all over the US, bits of Canada and Australia with maps downloaded in advance. We wouldn't have had a chance of downloading map data for huge chunks of that.
Posted : 01/03/2015 11:25 pm
I've used navfree, and would use it again if I needed satnav some place where I couldn't get any data, but I've actually uninstalled it now and use google maps instead as the data usage isn't that high. Depends on your requirements.
Posted : 01/03/2015 11:44 pm
have used navfree - copilot is better, IMO
Posted : 02/03/2015 10:04 am
I've used navfree whilst abroad and it's OK. It's not perfect, but good enough.
For me, one of the real benefits of a satnav is to get the traffic info, which you are not going to manage without some sort of data feed.
I use Waze most of the time, but I'm starting to look at google maps too.
Posted : 02/03/2015 10:08 am
