Rate my Brickie....
[Closed] Rate my Brickie....
some amount of money spent on that structure. better built than some houses, must be some bikes in there, did my garage into a gym,workshop sauna years ago, lucky im a carpenter and cost me peanuts, enjoy though the escapism rocks
Posted : 08/12/2012 11:14 am
In sheltered areas 9" walls are accepted as being weather resistant,
however as far as I can remember Celotex shouldn't be applied to 4" walls
Posted : 08/12/2012 11:33 am
Went passed on the train today and was pleased to see the roof on - but have you painted the render pink or were my eyes decieved ?
Posted : 08/12/2012 6:16 pm
Never heard that before.
What's the reason ?
Posted : 08/12/2012 6:19 pm
not bikes 🙂
Posted : 08/12/2012 6:27 pm
I've been enjoying following this thread thanks footflaps. I have got planning permission now to pull our old outbuilding down and rebuild it. I am impressed by your roof structure and would like to do something similar, I'm guessing you had a structural engineer to work out size of rsj and do you have any cross beams to make it like an A frame or don't you need any?
Thanks and keep pics coming
Posted : 08/12/2012 6:29 pm
Errr yes. But we can't see the painted sides. We had a sunny weekend, so nipped round to Ridgeons and the trade masonry paint had either Black, White, Grey or something called Suffolk - so we went for that. Turns out it's Suffolk Pink - we were quite surprised. NB Trade paint tins are all just white with a name on....
Posted : 09/12/2012 12:16 am
Pretty much all Victorian houses are 9" walls, and they are everywhere in the UK - make very nice dry houses.....
Utter nonsense. Cellotex is an polyisocyanurate closed cell foam bonded between two sheets of aluminium. Last time I checked, aluminnum wasn't water soluble and neither is the foam. As for damp pouring through 4" of concrete, we're having a rather wet autumn right now, and I've got a very dry workshop shell.....
It's even more nonsense eg when you build a standard cavity wall house, guess what you have in the gap right next to the 4" wall - a layer of celotex or equivalent....
Posted : 09/12/2012 12:17 am
 JoeG
A PINK mancave? 😆 😆 😆
Posted : 09/12/2012 12:23 am
A PINK mancave?
Er yes... I've had quite a lot of stick from the neighbours about it...
Posted : 09/12/2012 12:25 am
As for progress, I've just finished a 14 hour shift fitting the bloody stuff - horrible to work with - fine dust everywhere. I now have the lung function of a squirrel.
The first phase is 100mm in between the pillars, to make the walls flush. 70mm in between rafters. Then phase 2 is 50mm bonded to 12.5mm plaster board (damp proof board) will go flush over everything. So final depths will be 150mm on 4" walls. 50mm on pillars. 120mm on the roof and 100mm on the floor.
[url= http://farm9.staticflickr.com/8072/8255304147_bd6d53344d.jp g" target="_blank">http://farm9.staticflickr.com/8072/8255304147_bd6d53344d.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8255304147/ ]8 Dec 2012 17:00[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
[url= http://farm9.staticflickr.com/8351/8255305093_86f2e71541.jp g" target="_blank">http://farm9.staticflickr.com/8351/8255305093_86f2e71541.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8255305093/ ]8 Dec 2012 17:00[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
[url= http://farm9.staticflickr.com/8338/8256378874_355f84e42c.jp g" target="_blank">http://farm9.staticflickr.com/8338/8256378874_355f84e42c.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8256378874/ ]8 Dec 2012 14:26[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
[url= http://farm9.staticflickr.com/8063/8255303493_ff1eb280b3.jp g" target="_blank">http://farm9.staticflickr.com/8063/8255303493_ff1eb280b3.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8255303493/ ]8 Dec 2012 19:55[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Posted : 09/12/2012 12:29 am
Jeezo- are you allergic to kryptonite but looking to store your collection somewhere??
Posted : 09/12/2012 12:33 am
I intend to heat the workshop using a candle, so need to get my U value right down......
EDIT plus you seal the whole thing up with aluminium tape to stop any drafts between / around the panels - basically the Celotex forms a vapour barrier. By the time it's done, they'll be something insane like 400m of tape on there as there are so many panels in the roof...
Posted : 09/12/2012 12:36 am
Brilliant stuff.
Will you be doing tours once complete 😀
Ultimate man cave.
Posted : 09/12/2012 12:40 am
The world's first Passiv Schuppen.
Posted : 09/12/2012 12:43 am
I've been doing it wrong all these years 🙄
How you fixing top layer of board flaps? You dabbed the first layer on the walls?
Posted : 09/12/2012 9:51 am
Top layer will screw through to the rafters. For the walls I'll bond it to the brick pillars, the piers are 1.7m apart and the boards are 2.4m long. They'll bow a bit in the middle, if it looks terrible, I'll just cut out a middle stud, be pretty quick to fit.
[url= http://farm9.staticflickr.com/8485/8258394476_842199275c.jp g" target="_blank">http://farm9.staticflickr.com/8485/8258394476_842199275c.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8258394476/ ]First insulation later complete[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
[url= http://farm9.staticflickr.com/8481/8257325375_69b6b341e4.jp g" target="_blank">http://farm9.staticflickr.com/8481/8257325375_69b6b341e4.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8257325375/ ]First insulation later complete[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Posted : 09/12/2012 5:56 pm
Nealglover,
manufacturers details apparently,had it pointed out to me by building control surveyor
Posted : 09/12/2012 6:59 pm
Footflaps - Fisher make wall fixing plugs ( Termofix) for insulation boards that are ace. See if you can get a box - they do them in screw in wood, screw into masonry with rawl-plug attached and hammer fix epoxy. Means you should not have any bowing anywhere.
Posted : 09/12/2012 7:17 pm
I think the phrase 'something insane like' can be used as a prefix to all your quantities 🙂
Posted : 09/12/2012 9:28 pm
After the nuclear winter has passed, the only building standing will be Fortress Footlaps.
NORAD will be flattened, but Fortress Footflaps will still be standing.
p.s [url= http://en.wikipedia.org/wiki/Cheyenne_Mountain_nuclear_bunker ]NORAD[/url] is built under a friggin' mountain.
Posted : 09/12/2012 9:37 pm
Cheers Matt, looking for long fixings was next on my to-do list....
Posted : 09/12/2012 9:41 pm
Nothing in the 96 page product guide building control gave me when I asked about it. I did all my U value calculations using Celotex's online calculators and it was quite happy with 100mm block.
The only possible relevant reference, in the 96 page guide, is: "Please note that where existing walls are subject to the ingress of excessive moisture, it is recommended that Celotex PL4000 should be installed using mechanical fixings rather than a direct bonding technique."
Posted : 09/12/2012 9:56 pm
*glitchy bump*
Posted : 09/12/2012 10:02 pm
Jeez that celotex must of cost more than my garage
Posted : 09/12/2012 10:11 pm
Pink? I don't geddit? It's twistin my melon man
Posted : 09/12/2012 10:37 pm
Footflaps, how much has it all cost?
"something insane like..".
Posted : 09/12/2012 10:49 pm
 JoeG
Bike shed (over)built by a Footflaps ancestor a long time ago:
Posted : 10/12/2012 3:15 am
Must be into at least week 13 of this build (mega-structure)
Posted : 10/12/2012 7:32 am
having not really looked since page 2... did he sack the first brickie? This thread needs a "Previously on Rate my Brickie" at the top of each page
Posted : 10/12/2012 7:43 am
Don't listen to them Footflaps, I love your bunker.
Seriously, great thread - over engineering porn.
Posted : 10/12/2012 9:50 am
Yes. The replacement was most excellent.
Posted : 10/12/2012 3:26 pm
You know you talk so hip man
Posted : 10/12/2012 3:28 pm
I'm having a large episode of Man-Jealousy towards your workshop flaps!! It makes my new 18' cedar workshop look very insignificant!!
On the plus side, I ordered it after you started, and have been in for nearly 2 months 🙂
Posted : 10/12/2012 4:16 pm
OK, Thanks to matt_outandabout , I've been looking at fixings and have found a whole range which mean I can fix 150mm Celotex + 12.5mm plasterboard direct to concrete with no stud framework:
200 of something similar to these turn up tomorrow (215mm long, 10mm pilot hole in concrete and hammer in).
[url= http://farm9.staticflickr.com/8349/8261648402_cb08b87301.jp g" target="_blank">http://farm9.staticflickr.com/8349/8261648402_cb08b87301.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8261648402/ ]Untitled[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Posted : 10/12/2012 4:31 pm
Footflaps, you are having a 'Grand opening' when its done? 🙂
Posted : 10/12/2012 8:51 pm
These grand projects are never really finished, they just slow down exponentially as the 'designer' gets worn down by the whole thing...
Posted : 10/12/2012 8:53 pm
Flaps, those fixings are great. I have used those for 150mm insulation loads of times and they are really fast and easy.
Very strong too. Get a slightly smaller pilot bit just in case though, depending on the substrate a smaller hole than specced sometimes works better.
And don't forget to tape over the heads 😉
Posted : 10/12/2012 9:01 pm
For airtightness? We did not bother in woodfibre...
They are fab things and much under-known about. None of this daft dot n dab or studding out.
Posted : 10/12/2012 10:56 pm
Can you put some pics up of those fixing things in action can't get my head around the collar bit unless it comes off?
Posted : 10/12/2012 11:05 pm
Go steady with the drill, set a depth guide up or youll be through the other side!
Posted : 10/12/2012 11:10 pm
I'll try them out in the spare blocks I have first to suss them out. Will post lots of photos. I'll tape over the heads and then skim over the lot (but probably not this side of xmas for the skiming).
Posted : 10/12/2012 11:27 pm
If you mean the plastic circle thing - that stays in the foam, slightly indented, to spread the load. Anything narrower will just pull through as the foam is so soft.
NB Had the PB lined Celotex boards arrive today and I can't carry them on my own as their weight to strength ratio was too high so my hand pulled through the board when I upped them on one edge to get through gates, leaving a massive hand sized dent in the side of them. Have to be carried by two people to spread the load enough to not deform them. Mrs FF was very helpful and shifted 28 of them with me into the WS. The first two I did on my own and are hand print deformed.
[url= http://farm9.staticflickr.com/8063/8261465630_ce9edcde95.jp g" target="_blank">http://farm9.staticflickr.com/8063/8261465630_ce9edcde95.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8261465630/ ]Plaster Board backed Celotex (PB4050) arriving - two palletes worth![/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Posted : 10/12/2012 11:33 pm
I think my DeWalt SDS is dying, as it really struggles with the concrete blocks, so over drilling is not a concern at the moment. It really didn't like fitting the fixings for the door - 150mm x M10 was really slowing it down.
Posted : 10/12/2012 11:35 pm
As said above, drill with depth stop/guage, hold up insulation board, drill holes (usually 5 per board, then screw in fixing and pop wee insulated end cap over screw head to prevent cold spots in plaster or render.
Posted : 11/12/2012 4:19 pm
Page 13 / 17
