You need the key. Once you've unlocked it, the end unscrews, releasing tension on the foot plate.
Posted : 12/07/2013 8:54 pm
If you've completely lost the key, the key number is stamped into the lock faceplate and spares are easy enough to get from the internets.
Posted : 12/07/2013 8:57 pm
Ah ok thanks for that! Looks like I won't be selling the car 10AM tomorrow then.. ;-O Unless my local thule dealer has them in stock.
Posted : 12/07/2013 9:10 pm
Jam a screwdriver in the key slot and give it a quarter turn. The bit that is attached to the lock pulls out a bit - you then turn that to undo the bolts that hold the rack on.
glupton you're spot on! After an hour or so of messing around I just forced it a little with a different key ๐ Cheers!
Posted : 12/07/2013 9:20 pm
