Putting shelves aro...
[Closed] Putting shelves around the bit that's left when you take a wall down...
10 Users
We're going to be removing a wall in the kitchen on our new house and putting an RSJ up.
Where the upright bits are (that support the RSJ) I was thinking of making some small shelves to wrap around the upright.
There's going to be a breakfast bar that has the upright cut out of it so thought the shelves might be useful for condiments etc.
My idea was to make them U shaped so we have 3-sides to use but I can't think of a good way to fix them.
Any ideas?
Dodgy sketch..:
Posted : 08/11/2017 11:01 am
Floating shelf supports would be easiest I expect?
Posted : 08/11/2017 11:03 am
How deep are they? And how much weight do they need to support?
Posted : 08/11/2017 11:08 am
Put a dado/housing into the two facing sides and a strap of wood on each side of the upright that slots into the rebate, you can then slide the shelf on.
Posted : 08/11/2017 11:09 am
That sounds like a great idea, rene 🙂
Posted : 09/11/2017 2:10 pm
Yeah, depending on how deep the shelf is, I would create a rebate in the shelf & then screw battens into the wall & front edge of the pillar to slide the shelf onto. You could screw from underneath into the batten to stop the shelf from being pulled off.
I'm a bit disappointed you haven't CNC'd some fancy wall brackets for it though! 😀
Posted : 09/11/2017 2:29 pm
I was going to suggest a rebate in the wall - on all 3 sides - then just slide the shelf in.
Posted : 09/11/2017 2:36 pm
Nothing to add on the fixing side of things, but do make sure your shelves are level. In your sketch version your Tommy K is going to be sliding off with monotonous regularity 😉
Posted : 09/11/2017 2:53 pm
You seem to have mastered inverted 2-point perspective there.
Posted : 09/11/2017 3:56 pm
Is it to hold people’s drinks while you do your pole dancing routine?
Posted : 09/11/2017 3:58 pm
I suppose I could CNC the bracket for the shelf to slid onto 😉
Posted : 09/11/2017 3:59 pm
Some aluminium angle, with the leg dimension the same as the thickness of the shelf, fixed either side of post.
Open side/mouth of the angle facing up, slide shelf on and it covers the vertical leg and fixings.
Posted : 09/11/2017 4:06 pm
