Putting a new 12V b...
Putting a new 12V battery in a car
Toyota Corolla Hybrid, 2023 model year.
I'm getting the occasional message in the Toyota app, telling me the 12v battery isn't delivering enough voltage, and that perhaps I should go for a drive to charge it up. The only thing is, this happened most recently yesterday after we'd been out for half an hour anyway. And it's happened twice before just recently too. So, probably new battery time. (I don't have a multimeter to check it, so im going with some semblance of credibility in the Toyota message for now)
Halfords have one which appears suitable for £75, an acceptable amount considering what main stealer would probably charge, but the words in the description say "Most vehicles require this battery to be registered with the on-board computer system". What's that all about? A likely story, or bullsh1t?
Posted : 28/12/2025 9:48 pm
Yeah, it's a thing now. I've got a OBD reader for our two VAG group cars that I had to do the same recently and used it to update the battery info. Basically the charger circuits in cars these days are smart and need to know what they are charging to do it right - battery chemistry, capacity etc. How much actual difference it makes I couldn't tell you, but it's a thing.
That's a very new battery you might be replacing. The two I've just replaced were in a 64 and a 16 plate. Most batteries come with a 3 or 5 year warranty...though not sure if you get that if they are OEM and batteries are considered consumables on the accrual car's warranty.
Posted : 28/12/2025 10:04 pm
It  may not be the battery. I would suspect the phone app is causing the issue. The 12V battery on my 2 month old Kia EV 6 went flat, had been left on the drive for 3 hours. Anyway 2 weeks of head scratching and Kia couldn't replicate the issue. They suggested the app on my phone may have caused the drain. Everytime the phone pings the car for a status update it wakes the car up which can drain the car 12V battery. I was sceptical but some Googling suggests they might be right. I now always close the app on my phone when not using it. Not had a repeat of the issue yet.
Posted : 28/12/2025 11:24 pm
Posted by: stumpyjon
That sounds hard to believe. I mean I can believe that regularly waking the car up and polling its systems will cause battery drain. But drain all the 12V charge in 3 hours? Must be a very demanding app for that. Maybe check if there’s an update that ‘resolves persistent battery drain bug’?
Edit. OP, won’t Halfrauds replace batteries for a modest fee? I assume that would include correct installation with registration to the car’s systems. Last time I replaced a 12V battery was about 2015. Despite following the correct steps I was left with a disco dashboard of warning lights and freak outs. Thankfully my £15 OBD reader managed to clear all of them.
Posted : 29/12/2025 8:36 am
@stumpyjon check that you powered off and locked the car correctly with the key? Our Hyundai has flattened the 12v battery a couple of times when Mrs and Miss OTS haven’t locked the car as they’ve left it. The car continues to try to contact the key in the car which I can’t do because it isn’t there and will eventually flatten the 12v battery trying.
it’s a known issue. I keep a small usb starter pack in the glove box as a backup fix now.
Posted : 29/12/2025 9:21 am
In my case the car was locked. I get a notification if it's not.
Posted : 29/12/2025 9:36 am
On 2023 model still under warranty, I'd be talking to the dealer. They might point out a common "user error" like others have mentioned. Or have updates avaible etc.
Also a few quid on a multimeter is a better investment than a parts darts battery replacement.
Lidl or Aldi often have clamp meters, which clip around cables to measure the current, very useful to check battery drain or charging issues.
Posted : 29/12/2025 11:36 am
At two years old I'd be back to the dealer, no question.  And I'd be unlikely to take "consumable, mate" as an answer.
Posted : 29/12/2025 11:50 am
ThePinkster reacted
 K
Posted by: Cougar
This
Posted : 29/12/2025 11:51 am
Posted by: steveb
Start with the main dealer.
How many miles do you drive? It might be that the battery isn't being charged adequately, unfortunately this eventually causes sulphation and can be fatal as well as a warranty escape clause. Be prepared for a discussion
If your mileage isn't sufficient then a monthly top-up with a smart charger might be the way forward, see what the dealer says
Posted : 29/12/2025 11:58 am
Yeah, I'm coming to the conclusion of starting with the dealership. I'm seeing discussions about similar battery problems in Toyota C-HRs and Yaris, same technology but different models. Some say to install a new aftermarket battery and take it for a drive to let the car work out what's what for itself, while others have bitten the bullet and gone to dealer. I've driven Prius for most of the last 20 years without problems; the difference here is having the app - none of my company cars had that. I don't usually leave that running on the phone, so the idea that it's waking the car frequently to ask how it's feeling is probably not right in this case.
Car was bought 'nearly new(ish)' last April with about 7000 miles on it, is now 12500. So ~600 miles a month, varying between 300 and 1000+ if we go away for holiday. Found a Youtube video last night that suggested leaving it in 'Ready' mode for an hour from time to time, as that apparently pulls some leccy from the traction battery into the 12v job. I can also top up on the drive with a Ctek charger, but it means shuffling my car round with wife's to get up near the garage door, and sometimes I just CBA with that!
Will put it in trickle charge now, and call into the dealer this week, I think. Its probably worth going that way to avoid invalidating the warranty in the end.
Posted : 29/12/2025 12:34 pm
I can remember there being an issue with one particular model of car when I worked for SFS/Cazoo, and I have a feeling it might have been the Yaris. Turns out the microswitch in the hatch/boot that activated the interior light wasn’t very sensitive, or effective you like; if you didn’t slam the lid fairly hard, it didn’t register the pressure on the switch and the light would stay on, a problem if the car was likely to be held in storage for some considerable time.
It’s worth checking things like interior lights, especially ones that aren’t generally visible when doors, etc are shut.
Posted : 02/01/2026 5:12 am
 Don't ask me how I know, but, this is common in the industry. The car systems are usually based on 12v regardless of the Lithium battery voltage. Usually the 12v batt is charged from the HV circuit and also powers the car critical systems.... If the 12v circuit goes dead the car is lobotomized. The usual cause of this is software, the 12v systems will likely be busy in the background doing things like keeping the ECU power on, the background Comms, powering the safety interlock whatever crap is glued onto these things .... But if the 12 v circuit goes low the system will likely just fall over as the HV circuit should be safely shutdown at that time and it can't do anything.
I struggle with long sentences:
Bad system design, man. Warranty.
Posted : 02/01/2026 7:25 am
 irc
Posted by: CountZero
Good call. I had a Mondeo  years ago where the battery would drain if parked  for long periods. Solved when I disconnected the glove box bulb. This was before LEDs were a thing in cars though. Possibly if boot/glovebox lights  are now LED  the drain is not big enough to flatten the battery.
Posted : 02/01/2026 2:39 pm
Posted by: thelawman
I haven't read the whole thread, but it's worth pointing out that half an hour's drive is bugger all, battery charging wise.
Posted : 02/01/2026 6:22 pm
Especially at this time of year with lights on, heater etc.  30mins was enough for my Spitfires if their batteries had died but they had bugger all ancillaries!   I put a new battery on my 08 Golf yesterday- looking at prices Halfords charge c £40 for fitting. IIRC, if you sign up to their motoring club you can get money off the battery & poss 1 item fitted free per year.
Being an older Golf it has less bells & whistles but the old battery had been on it for over 10 years. It had a VW sticker on it, so could have been from a main dealer rather than original. I've had it 5 years, my mate for 4 before & his brother 2 years prior and neither changed the battery so the original battery either lasted under 7 years and its replacement over 11 or the original did 18 years!
We've recently had a problem on my son's WAV transit- that battery lost all power and it was only 1 year old.  It had been doing a few short trips and has stuff like electric foot plates that extend when the door opens and electric reels for his wheelchair so gets extra drain.  After it was recharged, I took it for a run, c30-40mins on the motorway based on my previous experience with the Spitfires. As IHN said, that wasn't enough as the warning light has reappeared, unless we have a parasitic drain.
Posted : 02/01/2026 10:20 pm
Alternators have published output curves (rpm/A)
Posted : 04/01/2026 12:46 am
 Del
FWIW my golf needed a new battery last year. bloody thing had only served 10 years! 😆 Because the thing was static on the drive i got the RAC to change it - i am not a member of the RAC but it's service they offer. very helpful. sorted all the 'car coding' and fault code shit. obviously they delivered it, fitted it, and sorted it for about 30-40 quid more than if i'd gone and bought it just the battery itself.
Posted : 04/01/2026 10:36 pm
Posted by: IHN
Yes and also some modern cars have software controlled battery charging for economy/CO2 test reasons.  My Focus Ecoblue would only charge the battery under certain circumstances (when coasting, AND the battery SOC is below X% AND the temperature is above Y etc), and with my usage cycle it was always on the verge of going flat.
I'm sure if the SOC was really low it would try and charge regardless of the other criteria but nonetheless you could drive for 2 hours and afterwards it would only be at 60%.
I use to charge it up to 100% every few weeks with a smart charger because i had a few times it got so low it failed to start.
Posted : 06/01/2026 10:32 am
Watching with interest as my 11.5 year old car's original battery has been struggling through each winter since covid.  Every spring i say i will replace it in the autumn but then winter comes and I plug the charger in instead. It's going to need replacement soon though!
Posted : 06/01/2026 10:42 am
Not relevant to the OP but lower in the thread, Kia EVs have a reputation for killing the 12V battery. I'm looking forward to mine dying at an inconvenient time. 3y in and it's fine however (Kia Soul).
It obviously can't just be an app polling for updates, must be switching on some drain that keeps on going....anyway a lot of people have it.
Posted : 06/01/2026 10:44 am
OP, that battery sounds a little cheap at £75. Are you sure you have the right one?
BTW call the parts place of your local Toyota dealer for a price. Surprisingly they were a couple of quid cheaper than elsewhere and obvs they ought to be 100% sure to supply the appropriate item.
Posted : 06/01/2026 1:17 pm
Just to update this. I booked the car into the local dealership for them to investigate, and whilst they couldn't find anything wrong with the electrics as such, they put it on a slow charge for two consecutive nights. At the end of that it was showing 100% SOC, so I've been using it since then for a week or so with no further drama or messages in the app. (That's cursed it, obviously) The Service Manager rather implied that losing some charge or voltage in the 12v system is a bit of a thing these days, unless you do quite a lot of miles, much as someone mentioned upthread. Multiple onboard computers and ECUs, etc.
I will be keeping the jump-starter pack to hand in the car from here on in, having had to use it one afternoon a few days before taking the car in. And will trickle charge it overnight at home periodically too.
Posted : 23/01/2026 3:45 pm
very very common in electric and hybrids from what i can see.
I added the 12v battery to be charged (with a smart charge maintainer) to the service list on mums leaf and will do the same on our EV.
2/3 years seems to be about the time folk start moaning about their batteries looking at the leaf forums  - and THEY REPLACE THEM.....every goddam time someone has a slight battery issue the mantra is "Replace it its ****ed"
No one seems to believe in maintenance these days.
Posted : 23/01/2026 5:21 pm
Put on a trickle charger and carry a jump started kit.
I do jump start from time to time because I don't drive that often.  Can't do trickle charge now coz it is raining and car is parked on the road.  🙂
Posted : 23/01/2026 6:49 pm
Dashcams can be a drain - most have a parked mode where they'll monitor for shocks from break-ins or careless adjacent parking and then film it, but the monitoring system is on all the time. There may be a limit you can set to turn off that system when the battery drops below a set voltage.
Posted : 23/01/2026 9:05 pm
