PSA Feed five for u...
[Closed] PSA Feed five for under a fiver
2 Users
Feed five for under a fiver...
By Paul Warburton
Recipe #3: Chorizo and pea risotto
Check out this original recipe for chorizo and pea risotto - and feed five people for less than a fiver!
Total cost
If you already have the cupboard staples, then according to mysupermarket.co.uk, this trolley was cheapest at Tesco* where it came to just £4.97.
Ingredients
225g of Tesco finest chorizo ring (£2.48)
500g of Arborio rice (95p)
1 large onion (16p)
1 bulb of garlic (34p)
1 tin of garden peas (29p)
50g of grated parmesan (75p)
The cupboard staples
We're assuming you have the following cupboard staples already: Black pepper, olive oil and 2 pints of chicken stock (made with stock cubes).
Cooking
More articles like this
Spicy tuna, bean and coriander lasagne
Beef koftas with a feta, spinach and fresh mint salad.
Instructions
* Add a couple of glugs of olive oil to a large heavy-based saucepan. Heat the oil for 30 seconds and then add the finely chopped garlic and onion. Sauté for a few minutes on a medium heat until onions softened - be careful NOT to burn the garlic! Once this is done pour the onion and mixture into a bowl for use shortly.
* Get the pan back on the heat and add the cubed (about 0.5cm) chorizo - remember to take the skin of the chorizo before chopping. Fry off the chorizo for a few minutes until slightly crispy and the oils have run off. Drain off as much of the oil as possible and add the onion and garlic mixture back to the pan.
* Now add the rice. Try to get all the grains coated with oil. Keep on a medium heat and stirring all the time so it doesn't catch on the bottom of the pan. Do this for just over a minute until all coated.
* Prepare two pints of hot chicken stock and add one ladleful of the stock to the pan, keep stirring! Never stop stirring until the liquid is absorbed. Repeat this process until the majority of the liquid has been absorbed and the rice is nice and tender. The more you stir the creamier the risotto - so make the effort!
* Finally add the peas, heat through and add a good few twists of black pepper.
* Serve with a good sprinkling of parmesan and a twist of black pepper if desired!
Posted : 20/06/2009 9:44 pm
1. Don't buy your chorizo at Tesco, much cheaper at lidl, and if you're frying it you won't notice the difference, honest.
2. Since when were peas (frozen I assume), onion, garlic and parmesan (again from lidl), not in the storecupboard? Anyway, enjoy..!
Posted : 20/06/2009 10:05 pm
