Plumbing Q, Whats ...
[Closed] Plumbing Q, Whats going on here?
7 Users
Every time I turn the cold tap on in out upstairs bathroom, the water come out then CLONK and it stops. Turn the tap on again and it CLONKS again. After a couple of times it works normally.
What is happening and how can I sort it?
I've tried turn the isolater in the pipe to reudce the flow, but it still does it.
Posted : 12/05/2011 6:11 pm
airlock? try opening all the taps in the house and running them for a few minutes.
Posted : 12/05/2011 6:19 pm
Dead body in the water tank
Baby Robin with a hammer in the loft ?
Posted : 12/05/2011 6:20 pm
Sounds like an airlock somewhere. Not sure of the real solution but I would start with all taps running at same time for at least five minutes then turn off from nearest to stopcock. Good luck.
Not sure that I want to leave all the taps running for 5 mins, we're on a meter....
Posted : 12/05/2011 6:25 pm
Ees pigion in water tank ? Oww he get there ? Oink oink !
Apologies to Manuel.
Go with Matthews' idea. Possibly ending with leaving the offending tap on full to ensure it is flushed.
Check for a high point in the pipe run if possible too.
Move to Scotland, no meters here !! Plenty of water too ! And Midges !
Posted : 12/05/2011 6:27 pm
I left Scotland 15 years ago!
Not going back to live, too cold, wet, dark, midge infested...
Posted : 12/05/2011 6:32 pm
incorrect pipe sizing can cause clonking in some circumstance I think.
Posted : 12/05/2011 6:49 pm
