Plumbing help pleas...
[Closed] Plumbing help please
4 Users
The shower we've got is one with the dial/controls tiled into the wall. The controls have always been very tight so i took the facing unit off to reveal the gubbins. When i was trying to free it up a bit (sprayed with wd40 and turning it off and on!) the unit came off in my hand and water sprayed all over me. When i turned the water off at the mains, re inserted it and put it back together there is a slight leak. Basically i think the seal between the inner and outer gubbins needs replacing.
The problem is there's no make in the shower and it's not a "normal" o ring type seal so i don't know how i'd go about getting a replacement ( i could always take the old one to a plumbers and see what they think) and the unit and seal need to rotate so i can't just put some sealant in there.
What i need is some sort of grease type sealant that will seal but allow movement
or advice on any other way to do it?
Posted : 19/01/2009 9:11 pm
new shower time by the sounds of it mate?
Posted : 19/01/2009 9:14 pm
i hope not i've just had the bathroom tiled!
Posted : 19/01/2009 9:16 pm
You could give [url= http://www.protecdirect.co.uk/Boss-White-&-PTFE-Tape/P.t.f.e-Tape-12mm-X-12m-White.htm ]PTFE Tape[/url] a try.
Mira and Triton do service kits which include the correct size o rings.
Like [url= http://www.plumbers-mate-sales.co.uk/mira-415-service-pack-93622-55-p.asp ]this.[/url]
HTH
Posted : 19/01/2009 9:20 pm
graham, ta but ptfe won't allow for movement,
geoff, that would be good but as i said there's no make at all on the shower and the seal isn't an or ring, it has a ridge on it.
i think i'll take it into the plumbers to see if they recognise it.
ta
Posted : 19/01/2009 9:28 pm
