Plumbers or anyone ...
[Closed] Plumbers or anyone in the know about toilets?!
18 Users
I'm about as technically minded as a twix ( current fave ).
When I flush the loo , it takes a rather long time for the tank to fill back up before you can flush again. No good for the awkward "double flushers" .
Anyone know the reason why it's taking so long to fill back up? And how it may be fixed?
Edit - the flush is a button on the top of the cistern .
Danke.
Posted : 19/05/2016 8:23 pm
You could be in the shit here..
Posted : 19/05/2016 8:52 pm
You may have a high pressure valve on a low pressure feed 8)
Posted : 19/05/2016 8:56 pm
You might be able to change the flow rate.
I did, but it was the simple ball float valve with the nozzle that could be swapped.
Which type of system is it?
Posted : 19/05/2016 8:57 pm
Inside the supply pipe, just above the point where it attaches to the household pipes irk, there will be a little spiral that's designed to slow down the feed to the cistern. Take that out and it should be fine.
If there isn't one, then I've no idea.
Posted : 19/05/2016 9:00 pm
I recon we have the wrong way arround in our downstairs loo. Literally seconds after flushing it's good to go again.
Great for when you have a hunch that it's going to be a floater.
Posted : 19/05/2016 9:03 pm
It really depends on where the water refilling the cistern is coming from.....
If your toilet is connected to the cold mains - check by turning off the water at the stopcock and flushing - if it doesn't refill then it is mains fed, then it could be the high pressure valve on a low pressure supply.
If it is tank fed, I.e. It does refill when the mains is off, then again you could have the wrong valve - high pressure when it should be low pressure.
Screw fix will hav low pressure valves to swap, or you might have one that has a high pressure 'insert' that can be removed. You'd need to google the valve make to find out.
Posted : 19/05/2016 9:09 pm
 Rich
Ours was recently doing this and it was a split washer in the inlet valve. Apparently a common problem with Siamp valves.
Posted : 19/05/2016 9:16 pm
 Bear
Most likely a part 2 ball valve washer that is been misshapen into the shut position. Simple fix if you are half competent.
Posted : 19/05/2016 9:46 pm
You need to replace the high pressure valve with a[s]low pressure valve[/s] new bike
Posted : 19/05/2016 9:57 pm
Thanks,for the replies. No idea where the water feed comes from etc. I'll take the top off it and explore.
Posted : 20/05/2016 5:40 am
 Bear
Take a picture of the ball valve inside and mail it to me timATj-wren.eclipse.co.uk or post it on here and I can advise what it is likely to be, other wise people on here may help too.....
Posted : 20/05/2016 5:51 am
FFS call a plumber.
Posted : 20/05/2016 6:27 am
Where the hell is the fun in that?
Hit it with a hammer if it breaks it needs replaced.
Try removing a couple of kilos of finest columbian from the cistern?
Posted : 20/05/2016 6:52 am
Definitely the most useful of comments so far.
Posted : 20/05/2016 6:57 am
Just take a bucket of water in with you for the second flush.
Posted : 20/05/2016 7:14 am
Run the hosepipe upstairs and fill it from that?
Posted : 20/05/2016 7:58 am
Wee in the cistern, great for flushing the serious business away. And free.
Posted : 20/05/2016 8:20 am
I had the slow filling thing; just replaced the whole inlet doodad inside the cistern with a new one from screwfix. Only cost a few quid and despite being a plumbing simpleton there are so many helpful vids on YouTube it was easy.
Posted : 20/05/2016 8:51 am
Worth checking if you have an isolation valve on the cistern feed and if it's fully open
 Rich
[url=
This is easy to check and only £2 to replace if split.
Posted : 20/05/2016 9:22 am
Thanks for the replies so far. Once i'm able to get the lid off (currently on crutches, dont fancy a one legged balance with a cistern lid!) i'll look inside and inspect and report back.
Posted : 20/05/2016 8:24 pm
Do you have hard water? Could be limescale blocking the inlet valve
Posted : 20/05/2016 8:28 pm
We live in a hard water area and had this. Also had the old ballcock type mechanism. Just replaced the lot with a fluidmaster from b&q for about £14 I think. Just watched a few you tube vids and was, to my surprise, very easy to replace. Refills like a dream now.
Posted : 20/05/2016 9:08 pm
