Physics question (o...
[Closed] Physics question (or motorbike restoration qn!) - involving vinegar & fuel tank
 Aus
Have an old motorbike and inside of fuel tank was quite rusty - superficial I think but enough to clog up carbs. So I have:
- drained the tank
- filled with vinegar
- left for 36 hrs sloshing it occasionally
- drained it (lots of rust flakes and rust coloured vinegar out)
- hose pipe inside and rinsed
- it looks very clean
- filled with water and bicarb soda
- rinsed with water
- empty as best is possible
- filled to the brim with petrol (to avoid flash rusting if left to dry)
- added Wynns dry fuel to absorb/emulsify the water
- plan to leave for a while and then drain a mug flu or 2 of water from the prime pump (thinking water sinks to the bottom)
And then good to go.
Now I've done all this. But is the logic sound, or have I really messed up.
Posted : 05/08/2014 6:26 pm
It's chemistry rather than physics. Personally I'd have used another acid to pick up the oxide, probably phosphoric like most rust removers. But your procedure seems sound
Posted : 05/08/2014 7:48 pm
 Aus
and not drying the tank but using an emulsifier that'll burn off (I think) - seem OK
Posted : 05/08/2014 9:25 pm
nice try... empty the tank od fuel allow to vent/ dry them use a proper tank liner the stuff from frosts in rochdale is best..
Posted : 05/08/2014 9:29 pm
I've no idea about the answer to your question, but surely the time to ask is [i]before[/i] you did all those things? If you're wrong it's a bit late.
Posted : 05/08/2014 9:30 pm
 Aus
Cougar, very true but enthusiasm got the better of me and I reckon if I'm wrong, it'll not be catastrophic!
Posted : 05/08/2014 9:54 pm
Then I wish you well. (-:
Posted : 05/08/2014 9:56 pm
Coke is a better rust remover than vinegar as it contains phosphoric acid. Have cleaned loads of stuff with a mixture of that or brick cleaner for really knackered stuff.
I've also used these [url= http://www.fuel-tank-renu.co.uk/pages/tanks.html ]people[/url] before on sumps that were dying. The coating's a bit like glass reinforced plasticoat, only thicker and a bit more gloopy. Worked a treat.
Posted : 05/08/2014 10:19 pm
