Phone battery quest...
[Closed] Phone battery question.
If I charge my ipad and don't use it, no charge gets used.
I made a point of checking my phone last night and it has used 11% apparently doing nothing.
What gives?
Posted : 05/08/2017 8:26 am
Background tasks. Email checking etc etc. And the iPad battery is 4x as large approx.
Posted : 05/08/2017 8:29 am
Try it again in airplane mode.
Posted : 05/08/2017 8:31 am
You're phone is working as a phone all the time - connected to cell towers waiting to see if anyone is going to ring. You'll notice if in you're in areas with poor reception that your battery drains faster as its working harder to find and maintain those connections.
Posted : 05/08/2017 8:37 am
This. If the pad had a SIM in, then you'd probably notice battery drain after a while as well.
Posted : 05/08/2017 6:15 pm
I leave my phone in airplane mode a lot now , ever since I realised the effect on battery life.
Posted : 05/08/2017 6:21 pm
Posted : 05/08/2017 6:32 pm
Not exactly a phone then, is it... (-:
Posted : 05/08/2017 6:45 pm
i guarantee that charge does get used in the ipad if it's switched on just at a much slower rate, the batteyr on an ipad has about 4 times the capacity so 1% drain on an ipad would be about 4% on the phone
Posted : 05/08/2017 6:52 pm
It has a bigger battery for a reason - it has a higher load. That massive bright hi-res screen doesn't run on sunspots.
Posted : 05/08/2017 7:06 pm
This is why I like the ultimate power saver switch on my Lenovo p2.
Basically turns it into an old school phone; calls and text, but not a lot else.
Turn it on before going to bed and it uses no more than 1% overnight, just via a switch; no menus to fiddle about with.
Posted : 05/08/2017 7:55 pm
I normally charge my phone overnight so its not really a problem. Just bought a 9000mah battery for my phone and they say I have to run it flat 5 times before it gets up to full power. Not sure if thats true but its what I'm doing.
The last 2% is lasting forever.
Posted : 05/08/2017 8:02 pm
But the screen isn't on when its on standby
Posted : 05/08/2017 10:24 pm
