People driving cars...
[Closed] People driving cars with sidelights on - why?
[i]If you struggle to see cars with sidelights on I suggest you may wish to inform the DVLA. [/i]
That's not what I said. My point is that, because they're so dim, having sidelights on doesn't really make a car any easier to see than not having them on. Having headlights on does make a car more easily seen.
So, if, say, the weather conditions dictate that you think that the car you're driving needs to be seen more clearly by other road users, why would you choose sidelights over headlights?
Posted : 18/04/2012 9:59 am
have an accident when you only have sidelights on in reduced visibility you could be found partly to blame for not following highway code advice
Someone really needs to tell that to all of the police vehicles in our area then.
Posted : 18/04/2012 10:01 am
I think what the OP is trying to say. Is that you can often see the car before you can make out that their side lights are on. And I agree.
It is what you said, as you think they're so dim they make the car as visible as not having them on at all, which is quite frankly nonsense to me as I think it makes them vastly more visible. Each to his own I guess.
I'd love to stay and argue but I've got stuff to get on with, enjoy your day folks.
Posted : 18/04/2012 10:02 am
I think the point is that it seems an odd decision to make 'I am sure I am suitably visible with just side lights on, there is no need to go to that extra effort clicking the light switch round a little bit more to the dipped setting'.
Posted : 18/04/2012 10:05 am
[i]I think the point is that it seems an odd decision to make 'I am sure I am suitably visible with just side lights on, there is no need to go to that extra effort clicking the light switch round a little bit more to the dipped setting'. [/i]
eggs act lee
Posted : 18/04/2012 10:07 am
Yeah, but that's the same logic that's made the country full of fatties.
'I am sure I am suitably full with just that one slice of cake, there is no need to go to that extra effort of picking up the rest of it which is just a little bit further round the plate'.
Posted : 18/04/2012 10:10 am
Sidelights in dull weather because it turns the rear lights on and popping up the headlights creates more drag because I have an [s]awesome[/s] hairdressers car.
Posted : 18/04/2012 10:16 am
a lot depends on how bright one's LED sidelights are
Posted : 18/04/2012 10:17 am
 piha
Mmmm, side lights you say........
eggs act lee
See above comments on masking cyclists, wasting fuel and other aesthetic issues. Personally I also see it as a waste of energy and fuel, but looking at the number of people on here who struggle to see any difference between cars with and without sidelights on maybe I should fear for my life and change my views.
Posted : 18/04/2012 10:18 am
Coffeeking - maybe you should accept you are wrong and drive in accordance with the highway code
You should also
use [b]dipped headlights,[/b] or dim-dip if fitted, at night in built-up areas and in dull daytime weather, [b]to ensure that you can be seen[/b]
Posted : 18/04/2012 10:19 am
Define dull?
Posted : 18/04/2012 10:21 am
Live and let live.
Conversely they could help a cyclist see me
wasting fuel
Straws anyone?
aesthetic issues
Posted : 18/04/2012 10:22 am
I find cyclists rarely fail to see cars, it's almost always the other way around.
Straws anyone?
Not really, perfectly reasonable point.
Posted : 18/04/2012 10:23 am
TJ, if you want to go down that path, then you have to accept that you're wrong, or a hypocrite 😀
59
Clothing. You should wear
a cycle helmet which conforms to current regulations, is the correct size and securely fastened
Posted : 18/04/2012 10:24 am
😀 I was wondering if anyone would bring that up
Posted : 18/04/2012 10:25 am
Seems to be a taxi-driver / minicab thing around Manchester. Generally it's sidelights only (presumably to save petrol) but if not they'll flick one headlight on. Sometimes they'll break the mould and put [i]both[/i] headlights on.
Though I'm beginning to think that a large proportion of cars driving around on sidelights only have simply had both headlight bulbs blow and not noticed.
Posted : 18/04/2012 10:29 am
My driving instructor taught me that sidelights were never to be used. Headlights only. It must have resonated as I have not once in 22 years of driving ever used my sidelights. I recall his biggest issue was the fact that when it got dark people would forget to switch on headlights as the dashboard illumination was the same. This theory seems correct in my experience.
Have we done fog lights when its raining yet?
Posted : 18/04/2012 12:00 pm
Rear fog lights are for when you are hogging the middle lane any time after the visibility has recovered from almost perfect to perfect.
Front fog lights are for looking like a gangsta
Any fool knows that
Posted : 18/04/2012 12:04 pm
In dull weather I'd rather people used their sidelights than use their poorly adjusted dipped headlights which blind me as I ride/ walk/ drive around.
I don't understand what all the fuss is about with people "only" using sidelights when it's not dark or terrible visibility.
Dazzling headlights and always-on fog lights are what really boils my p1ss.
Posted : 18/04/2012 12:20 pm
veedubba - if you're blinded in daylight by headlights (poorly adjusted or not) you might want to see an optometrist as it could be an early sign of cataracts. The only light that should dazzle you during the day is the sun. 🙂
Posted : 18/04/2012 12:25 pm
i thought this thread might be about the modern trend to fit cars with day running led lights and weak as p!ss indicators which mean you can't see which way someone wants to go at a junction.
And breathe 😉
Posted : 18/04/2012 12:28 pm
any time you do not need shades to drive or visibility has been reduced from the horizon to the horizon minus 5 foot it seems the majority of drivers use their lights
I dont see the point tbh as it does not make them easier to see as for the latest fad of keeping your fog lights on constantly FFS learn to use the controls on your car you dimwit.
Ok with bike having lights on all the time but FFS you are in an articulated lorry you are 12 foot high and 50 ft long the 10 watt bulb has not made me notice your presence on the road
I want to start shooting them from motorway bridges can i ?
Posted : 18/04/2012 12:33 pm
My eyes are fine thanks.
A car driving straight towards me with its headlights on and adjusted too high, effectively shining them straight into my eyes does dazzle and annoy though.
Posted : 18/04/2012 12:34 pm
When the weather is less than perfect I always but headlights on, I can see fine, but it helps idiots see me better, whats to loose?
Then you get the idiots in the rain who either put side lights on, or dont bother at all, then the idiots who put fog lights on in the rain. Then the idiots who put fog lights on in slight fog but don't slow down.
Then there are the idiots who buy Audi's that have LED side lights on all the time.
There are lots of idiots.
Just out of interest I find those new LED side lights way too bright, and when I look at them through a rear view mirror they appear to wobble, any one else get this??
Anyone who thinks sidelights are sufficient in poor conditions needs their head examining. even the old dim dip headlights were pretty useless. modern cars have a tiny bulb hidden in the depths of a huge light and they are practically invisible in daylight.
as far as i'm concerned they should configure cars so that lights are either on, or off, and sidelights can only be selected when the engine is off!
Posted : 18/04/2012 12:35 pm
You probably have cataracts too FunkyDunc
Posted : 18/04/2012 12:38 pm
Yeah, the wobble is quite disconcerting, I think it's because they're pulsed rather than constantly on and it interferes with your peripheral vision's inherent high speed.
Posted : 18/04/2012 1:12 pm
Daytime running lights are only a 'trend' because they are about to become law for all new vehicles so it makes no sense for manufacturers not to be designing with them in mind.
And I assume manufacturers choose LEDs because they use less power than conventional bulbs and last longer.
And look well bling innit.
Posted : 18/04/2012 1:21 pm
As it so easy to enable dipped headlights in low light or rain, often with the very same rotary switch, I can think of no reason whatsoever why a driver would [b]not[/b] use their dipped headlights in preference to their [b]position[/b](side) lights.
In dawn/dusk/rain conditions, cars (especially grey/dirty silver ones) are often not particularly visible. Position (side) lights are almost useless in such situations, although a significant minority of drivers seem to think that they are a good idea for use whilst driving, even whilst surrounded by people using their dippped headlights.
Is it mostly ignorance, low intelligence or just mis-guided stubbornness?
Posted : 18/04/2012 1:22 pm
Some of us drive large, powerful cars with large, powerful LED sidelights 🙂
Posted : 18/04/2012 1:23 pm
Seriously wonder how many people should be driving if they find cars with sidelights on difficult to see.
Posted : 18/04/2012 1:24 pm
Some of us drive large, powerful cars with LED sidelights
Hateful, glare-producing things -and so are the LED sidelights.
Posted : 18/04/2012 1:25 pm
I've been quite surprised by the amount of new cars that don't appear to have daytime running lamps, so I had a quick google 😀
[url] http://www.autoexpress.co.uk/news/autoexpressnews/279673/watchdog_daytime_running_lights_ripoff.html [/url]
Posted : 18/04/2012 1:26 pm
FunkyDunc - Member
Yes, very distracting. I wonder if some of them have a PWM circuit inside causing a rapid flicker.
Posted : 18/04/2012 1:27 pm
coffeeking - Member
Seriously, when the sun is low in the sky at dawn/dusk, it is a dull, grey day, or it is raining, many cars, often of a grey hue, do blend into the background, especially if the sun is behind the car.
2 candles buried in the headlights do little to help with this.
The question remains: [b]why wouldn't a driver used dipped headlights?[/b]
Posted : 18/04/2012 1:28 pm
2 5w white lights in a reflector are fairly noticable, in fact better than most cheap bike lights. I do genuinely worry that people are driving around who can't see a car with sidelights on, you're either in too much of a rush or have vision issues.
Why wouldn't a driver used dipped headlights?
See above, if you can be arsed reading, I can't any more!
Posted : 18/04/2012 1:29 pm
Seriously wonder why you still argue against putting dipped headlights on now you know so many drivers can't see your sidelights. My advice to my kids when I teach them about driving? Don't assume every other driver is as good or observant as you think you are because (a) you're not that good (b) they're probably worse.
Posted : 18/04/2012 1:30 pm
Coffeeking - I am astonished you still seem to think its OK to drive on sidelights when lights are needed. 😉
Posted : 18/04/2012 1:31 pm
My sidelights are actually pretty bright so I'm not too worried, and I don't put myself situations I can't get out of if someone doesn't see me.
I'm astonished you don't ride with a helmet when a helmet is needed 😀
(FWIW in total honesty my sidelights are 15w equiv LED replacements so pretty bright because the originals were pish, but the replacement was done for aesthetic reasons not for vision)
Posted : 18/04/2012 1:32 pm
Daytime running lights are only a 'trend' because they[b] are about to become law [/b]for all new vehicles so it makes no sense for manufacturers not to be designing with them in mind.
That came into force 14 months ago.
Posted : 18/04/2012 1:33 pm
I use sidelights every now & again. Now I know how much it irks some people I think I will use them more often.
Page 2 / 4
