Paint rollers or pa...
[Closed] Paint rollers or pads?
14 Users
We're painting a few rooms and have seen some people claim that paint rollers are for chumps and paint pads are the hot new thing. I've also seen 1 star reviews on cheap pads on Amazon.
Help me STW, should I buy a set of paint pads because they're great, or just stick with rollers?
Posted : 08/03/2021 9:08 pm
I used pads years ago and there were not all that. Used rollers since and every decorator I've used at home or seen working elsewhere use rollers or good old brushes. Cant recall ever seeing a pro decorator using pads.
Posted : 08/03/2021 9:23 pm
Suspected that would be the case...
Posted : 08/03/2021 9:26 pm
That said using pads on a ceiling was a god send. No drips and spray and job done. Ive used pads on walls and pretty happy. I had the ones from wickes which seemed much better than the cheap spongey ones. BTW IANAD
Posted : 08/03/2021 9:37 pm
Pads are much slower than rollers. Or maybe that’s just the way I paint!
Posted : 08/03/2021 10:08 pm
Pads are great for water based verathane ime. rollers for paint.
Posted : 08/03/2021 10:28 pm
Pads, or any other form of applying paint to walls that isn’t a roller and a paint tray is just a gimmick.
The pros use rollers. You should use a roller because it’s what the pros use.
Posted : 08/03/2021 10:38 pm
The real pros use brushes for a perfect finish, if using rollers and you want a quality finish on smooth walls, use a short pile roller and sand down with atleast P180 grit Inbetween coats
Posted : 08/03/2021 10:45 pm
For edges the pads win hands down. Rollers for the bulk of the wall and pads for the edges?
Posted : 08/03/2021 11:06 pm
Pads for the edges sounds like a plan. I hate the cutting-in with a brush, malarkey.
Posted : 08/03/2021 11:28 pm
Worked for an architect doing the showroom build for Vitra, and we used pads, as well as rollers.
Personally with rollers if the paint is quick drying, going over it it can pick up the dried surface of the finish and deposit it back on, meaning it needs removed and start again. Pads have been in use since the 80's Rollers are a very quick way to apply finish over a large area leaving a reasonably smooth finish.
Pads are good for edging, especially close in to right angles of walls, where the edge of the roller catches the opposing wall.
My thruppence ha'penny worth, if it helps 🙂
Posted : 08/03/2021 11:45 pm
Roller everytime. Purdy white Dove sleeves, Purdy Monarch brushes, Purdy roller and a Purdy extension pole. Yep I'm a Purdy Fanboi
Posted : 09/03/2021 7:14 am
Poor quality, Pads, rollers or brushes will give you a poor finish.
Pads never made it into the industrial world that I experienced.
Rollers do give a characteristic finish with Matt wall paints, as do brushes when you are cutting in if you are a little heavy handed.
Posted : 09/03/2021 7:33 am
After pondering for a few years I tried out some pads for the first time last year. The paint went on much thicker, but probably too thick. The sponge of the pad absorbed half a tin of paint which was then wasted at the end. It was much slower but slightly more satisfying to use but all the dragging around sideways put a weird strain on my elbow that wasn't comfortable.
I stick with a roller now knowing that I've scratched that itch and it wasn't a magic solution to my general dislike of painting walls.
Posted : 09/03/2021 9:48 am
Rollers for large areas
Brushes for cutting in at the corners
Pads for... um very smooth finish?
Posted : 09/03/2021 9:53 am
