over-soaking lentil...
[Closed] over-soaking lentils?
10 Users
If lentils have to be soaked for about 24 hours, what, if any, is the harm in soaking them for 3-4 days?
Posted : 11/02/2011 3:05 pm
they will probably sprout/rot - if you wanted to make a dal you might get away with it
Posted : 11/02/2011 3:22 pm
They just to into slush dont they?
They're still hard but the water is a bit brown though. I'll chuck them and start again.
Unless someone wants them?
Posted : 11/02/2011 3:25 pm
I've never bothered for curries and dhal etc - as long as they've simmered for at least 45 minutes they're fine.
Posted : 11/02/2011 3:36 pm
you dont need to soak lentils it is there best feature as a pulse
Posted : 11/02/2011 3:41 pm
What? The anti-social element.
Posted : 11/02/2011 3:44 pm
You will die.
Posted : 11/02/2011 4:15 pm
(post removed)
Posted : 11/02/2011 4:34 pm
You will die.
When?
Cougar, tut tut!
Posted : 11/02/2011 4:56 pm
Over soaking? No problem. They will simply disintegrate quicker when you boil them later that's all. I used to soak them for a day and I think two to three days once. No problem just like eating soup that's all.
Posted : 11/02/2011 6:22 pm
I once didnt pre-soak kidney beans, resulting in me undercooking them = coming out of both ends; bradford and bingley. But as above, lentils are nice unsoaked, cooked in curry
Posted : 11/02/2011 6:50 pm
No need to soak this type of thing if you cook it in a pressure cooker. I come in from work and can have good soup done in a few minutes. Handy when you have forgotten to steep them the night before.
Posted : 11/02/2011 6:59 pm
nbeans are dangerous as they have a poinous enzyme in them that will only be broken down by boiling cant recall the correct procedure. i just buy these tinned as it is easier.
If you just want mush/soup/humous you can use the pressue cooker way
Posted : 11/02/2011 7:04 pm
For beans, I just soak them for 24 hrs and boil for 1.5 hrs, rinsing then adding to the meal.
Posted : 11/02/2011 7:19 pm
I never soak red lentils, they cook to (delicious) mush in 15 minutes!
Posted : 11/02/2011 7:30 pm
