Oven help...
[Closed] Oven help...
 cb
Why do these things always happen on Friday evening?
Neff double oven. Top oven fan still works but no heat - bottom oven fine. Likely a thermostat?
Any pointers appreciated!
Thanks
Posted : 26/11/2010 5:57 pm
Burnt out element probably
Posted : 26/11/2010 5:59 pm
Is the light staying on to indicate that it's not reached temperature? If so, then probably the element. If not, then probably the thermostat.
Posted : 26/11/2010 6:04 pm
 cb
yep - looking like element, thanks
Posted : 26/11/2010 6:34 pm
Meter out the contacts of the disconnected element.
Posted : 26/11/2010 8:52 pm
Does the light come on when you open the door? If so you may be looking at the fridge.
Posted : 26/11/2010 9:36 pm
