I have a 2010 orange 5 and ive bent my front rotor (hope x2 183). Has anybody got any suggestions on what to put back on? Thanks. 🙂
Wordy1979 Is this the standard flat Hope metal rotor or a floating rotor?
another rotor 😆
try putting on a thinking cap
I've got a spare set of rotors for a metro city 1.3 you can have if you want?
Have you tried a chapati? Or possibly one of those big Millies Cookies?
10" peperoni I've heard are good for trail centres.
Take your pick. Replacement hope ones are quite expensive I find. But i think any 180/183 rotor will work for you.
was it floating rotar im guessing (i slightly bent mine a while back and hubby managed to straighten it again ! lol... you can get coloured floating rotars too ! 😉
A set of cantis ftw
**** the rotor I want a 160 in disco black!!!!!
You can bend them back if it's not too bad.
Honda Fireblade, 2000 model. 6-bolt fixing, admittedly not the same size of bolts as your Five and not the same BCD but it's the right number at least. 330mm for extra stopping POWAH and mounted on an alloy carrier for weight reduction so it only weighs about a kilo. Perfect for your needs.
Or alternatively, just fit another one the same.
On the off chance its a 203mm black saw-tooth floater and you dont mind a couple of scratches...
I've a spare.
I'd suggest a Yeti or similar.,...oh...you want to keep the bike...sorry....are you sure?
Bend it back or buy another. If you can afford a five you can afford a new disc. 😉
I'd put on a small dinner plate.
thanks for the comments. lol. 😆
