One for the audio p...
[Closed] One for the audio physics deniers
Ransos..
I have a good friend who earns a living reviewing cable (amongst other things) for a highly respected leading UK Hi-Fi magazine..
he's a good bloke.. very honest and enthusiastic about music and hi-fi and enjoys his work immensely..
aside from the fact that I've heard the differences myself time and again when he's reviewing kit back to back.. and ignoring the fact that this well meaning friend has made personal recommendations on the most cost effective ways to upgrade my own system.. I still simply cannot believe that he has just made all that stuff up off the top of his head each month when he submits his pieces to the editor..
as I said earlier in the thread.. ignorance is bliss.. or not, as the case may be..
Posted : 20/03/2012 6:24 pm
Just for fun, can anyone explain (scientifically) why bi-wiring is better than single?
there is a technical reason why it is suppossedly better - that article above may allude to it - the guy who used to run Spendor explained it to me but I forgot it pretty quickly.
However he also pointed out that it is very unlikely that the speaker designer 'voiced' the speaker with it biwired, so it is probably best to use it single wired as he did, and just strip the wire back to it reaches between the terminals.
Once a cable isn't noticeably degrading the signal, that's your plateau
+1
the cable I went back to when I had problems was the blue Van Damme stuff, which is similar to the cheap studio cable mentioned above.
I actually use some Kef stuff which to my ears is the same, but it looks better against the floorboards as the jacket is brown whereas the Van Damme is blue.
Plus if used the white stuff it would stain badly when the cat decides to behind the speakers for a cr8p...
Posted : 20/03/2012 6:29 pm
Just like high-end bike reviews for MTB mags? ๐Ÿ˜‰
Posted : 20/03/2012 6:31 pm
I'm sure he believes it. People also believe in homeopathy.
But the fundamental point is that no-one has ever demonstrated a difference under double-blind conditions. Speaker cable is a pretty odd thing to have faith in.
Posted : 20/03/2012 6:33 pm
[i]Just like high-end bike reviews for MTB mags?[/i]
ooh, are audio mag forums rull of;
"What cable for Dark Side of the Moon"
type threads?
Posted : 20/03/2012 6:34 pm
So, cheap cable inside speakers ... yet expensive speaker cable and interconnects make a noticeable difference. Riiiggght.
So you can't see any inherent difference between a couple of inches of wire inside a shielded chassis and a several metre cable run passing through who knows what?
I'm not disagreeing with you, incidentally; I've explained my views earlier. I just think that some of your arguments are a little tenuous.
Good for you. Are you going to try for the $1 million prize?
it would have to be with my cables, speakers and amplifier - and all it would demonstrate is that my amplifier is sensitive to the load on it. Something about those 4mm stranded cables causes it to perform badly.
I also spoke with the guy who used to run Spendor about this and he said that they used to have problems with Quad 606s being unstable into certain loads.
Posted : 20/03/2012 6:35 pm
Studios are electrically noisy environments, cables heaped in coils, passing over each other, close to power supplies and so on. Remind us what sort of cable they use?
Posted : 20/03/2012 6:36 pm
type threads?
I remember looking for some advice last year on audio forums about how to get my Linn audio multi room stuff hooked up in the house I moved into. Those guys take things quite seriously.
I ended up asking on here in the end, and got a better response ๐Ÿ™‚
Is there anything that STW doesn't know? ๐Ÿ˜‰
Posted : 20/03/2012 6:37 pm
I suggest you contact James Randi. Let us know how you get on.
Posted : 20/03/2012 6:38 pm
i love STW.
a bunch of cyclists have almost tonned arguing about wire.
again.
๐Ÿ™‚
Posted : 20/03/2012 6:39 pm
You've repeated the joke several times ransos, but I still don't get it.
Posted : 20/03/2012 6:40 pm
 grum
No-one willing to defend this then?
VALHALLA Reference Power Cord from Nordost redefines the standards of performance in this category. The Valhalla offers a dramatic sound stage, tremendous dynamic range and superb articulation of the musical event. When used with video components; clarity, detail, and the natural depth of colors are revealed. Valhalla Power Cord uses our new proprietary 'Dual Micro Mono-filament' technology to enhance audio and video performance.
I woudl suggest that he would say his $1 million was safe as I was not demonstrating a difference between cables, just amplifier performance.
Posted : 20/03/2012 6:42 pm
it is not a joke - some guy has put up a bounty if anyone can demonstrate that they can hear cable differences, under DBT conditions.
EDIT:
http://gizmodo.com/305549/james-randi-offers-1-million-if-audiophiles-can-prove-7250-speaker-cables-are-better
he mentions specific cables.
there is some other guy who is offering a bounty as well, but less and not linking it to the supernatural.
Posted : 20/03/2012 6:48 pm
It appears those who believe in uber cables are a bit like those who believe in homeopathy.
Posted : 20/03/2012 6:53 pm
Remind us what that has to do with wiring inside devices?
Wonder how many electronic engineers there are here with some of the guff that's being spouted.
Cables do make a difference, whether a ยฃ1k cable is a significant (or any) improvement over a ยฃ40 cable is another matter.
Also, the cable part of the transmission line is only one element, just as important are the connectors. For real quality you need impedance balanced termination. AFAIK Linn are the only major consumer hifi company that make this kind of stuff and they are correspondingly expensive.
In my lab we use cables that are as short as possible and terminated with 50 ohm connectors, some of these can be >ยฃ1k for a 10cm semi-rigid. Sometimes, you get what you pay for...
Posted : 20/03/2012 7:06 pm
So the $1 million prize is for anyone who can tell the difference between a stupidly priced 'audiophile' cable and its equivalent reasonably priced high-end cable from another manufacturer. Not, as ransos has alluded to several times, good quality cables versus wet string.
Bit of a house of cards you've got there, really.
Shall we have a closer look at this "cheap cable that recording studios use" next? What cable is that, exactly, anyone know?
Posted : 20/03/2012 7:15 pm
Thanks - I kept seeing links to paranormal stuff. Couldn't find the actual hifi cable quote.
It seems specifically directed at a couple of people though (reviewer from Stereophile and one other guy).
If it were open to anyone (like the paranormal stuff is), then someone would have done this. After all, they have no reputation to lose and $1m to gain!
Been reading through some of the paranormal challenge applicants. Some of them you just want to succeed - like this one: http://forums.randi.org/showthread.php?t=89877
Posted : 20/03/2012 7:17 pm
 grum
From Sound on Sound - probably the most respected music production magazine around. Paul White runs his own studio and has written dozens of books and edited various audio recording and production magazines....
Hi fi purists make a lot of fuss about speaker cables, sometimes spending several hundred pounds a metre on specialist cables. The main function of a speaker cable is to provide a low-resistance path between the amplifier and the loudspeaker, so thin bell wire is obviously a bad idea -- not only will thin wire take some of your amplifier power and turn it into heat, it will also reduce the damping factor of the amplifier. Without getting too technical, the damping factor of an amplifier is its ability to sink the current produced when a loudspeaker overshoots its position and starts to function as a generator rather than a motor. This mechanism effectively damps the speaker movement, keeping it under control, thus producing a tighter, more accurate bass end.
The most pragmatic approach is to use the shortest speaker leads you can, make sure they are both the same length, and choose heavy cable. [b]I'm unconvinced that there's a difference between multi-strand cable and solid-core cable, and I've yet to hear the difference between the oxygen-free copper and 'virtually oxygen-free copper' that most stock cable is made from, but if you think it's worth the difference in cost, don't let me put you off. If you're on a tight budget, 30A cooker cable works perfectly well, albeit a trifle ugly.[/b]
http://www.soundonsound.com/sos/1996_articles/feb96/cables.html
Posted : 20/03/2012 7:38 pm
A very sensible article and no real surprises there.
It doesn't really answer the question though. What do they use in recording studios, what is this "cheap cable" Rasnos keeps talking about? I have no idea what a studio uses.
The other question on the back of that of course is relevance. Assuming we're talking about speaker cable, would a recording studio care about high quality speaker cable? It's recorded at source as far as I know, the only speakers would be monitor speakers; sound engineers use headphones. Is that a fair comparison? An audiophile home user's primary aim is sound reproduction; a studio's primary goal is sound recording, reproduction less so.
Perhaps a better question would be not "what do sound engineers use in a studio" but "what do sound engineers use at home"?
Posted : 20/03/2012 7:54 pm
 grum
I do recording work in a studio - I'm not a proper 'sound engineer' but have studied production at Uni. I use fairly cheap balanced jack cables to connect up my monitor speakers. I have a friend who is a proper sound engineer, it's his job and he studied audio engineering at uni - the proper version with physics etc. He is scathing about hifi equipment manufacturers claims - describing it as 'voodoo'.
For mixing in a studio, engineers mostly use some decent near-field monitors, often with some large main speakers and something like Yamaha NS-10s to compare stuff on. People do use headphones, but not on their own.
They use decent quality audio cable - but I don't know of any studio that uses high-end audiophile products - most engineers see it as overpriced bollocks.
Posted : 20/03/2012 8:04 pm
Errr, really? A tune doesn't just mix itself you know. I would imagine more effort/time goes into the production of a song/album than recording. The key components there are the producer's ears and the equipment they are listening to the music on. Also the hardware used in a studio is all about providing a brutally honest representation of the audio being produced, wheras 'audiophile' hardware is all about flattering the audio and making it sound nice and deep and all the other adjectives they love to use. Listening to music on a proper quality pair of studio monitors isn't necessarily a pleasant experience, the highs can really get tiresome and the mid range much more prominent than you would get from hifi speakers.
I think most producers will be using powered monitors too surely? I doubt headphones are used much in production in a studio either.
Paul White knows his stuff, I'm glad he came out with the sensible argument.
Posted : 20/03/2012 8:07 pm
And did you get those for 20Khz signals or 20Ghz signals?
And have you put a gold plated mains plug on the signal generator and network analyser? ๐Ÿ™‚
Posted : 20/03/2012 8:09 pm
Cool, thanks.
I think everyone here is in agreement with that, no-one's arguing for stupidly expensive cable I don't think; just that reasonably priced cable is better than any old bell wire you've got lying around, rather than "it doesn't matter."
Errr, really?
I don't know, I'm guessing, I've never been in a studio. I imagine that the room for auditioning a song is very different from the one used to record it. But yeah, that's where I was going - it's not necessarily a directly comparable experience, the home user's requirements will be very different to a studio's.
Posted : 20/03/2012 8:13 pm
Wonder how many electronic engineers there are here with some of the guff that's being spouted. Cables do make a difference, whether a ยฃ1k cable is a significant (or any) improvement over a ยฃ40 cable is another matter. Also, the cable part of the transmission line is only one element, just as important are the connectors. For real quality you need impedance balanced termination. AFAIK Linn are the only major consumer hifi company that make this kind of stuff and they are correspondingly expensive. In my lab we use cables that are as short as possible and terminated with 50 ohm connectors, some of these can be >ยฃ1k for a 10cm semi-rigid. Sometimes, you get what you pay for...
we also use silly expensive cables in our lab (in ekg, eeg and related medical grade things). They cost that because they have to deal accurately with tiny signals and/or extremely high frequencies, not the relatively decent level and low frequencies of audio signals. To make a cable that wasn't fine at audio frequencies,you'd have to really try hard.
Oh and on the studio front, a lot of studio places I've seen also hand make their cables, usually in a hurry, cutting things with any old knife that comes to hand and using any old cheap metal jack plugs, no fancy connectors, and certainly no 'impedance balancing'.
Posted : 20/03/2012 8:19 pm
Mr Woppit - Member
Really? Why aren't you using hedge-trimmer cable from B&Q?
Wrong plugs.
Posted : 20/03/2012 8:38 pm
Quite.
Posted : 20/03/2012 9:06 pm
Grum...is your penultimate post any different to the crap folk buy re. bikes?
Posted : 20/03/2012 9:11 pm
this guy is on a yahoo group I am a member of and he does use
very expensive cabling - I would have to search the group archives to see which but they may be some of the Nordost stuff:
http://www.barrydiamentaudio.com/
he certainly seems to believe in cable differences.
the studio he runs is:
http://www.soundkeeperrecordings.com/about.htm
he is very against the modern trend of compressing the heck out of everything to make it sound loud - it seem she puts a lot of effort into making his recordings as high a quality as possible.
Yamaha NS-10
They may use these but I am not sure they are the most desirable form of monitoring. Better to use something from Harbeth, I reckon, something where they compare them against real sounds (apparently Alan Shaw uses recordings of his daughters voice for reference) when voicing them, like in the old BBC days.
that said - I am still not a believer in cable sound, only that they can affect the amplifier/speaker/cable 'system'.
I love how people get so worked up and spend so much on audio cables for their speakers, yet don't consider that the XLR cables, and the patch bays (including the dusty soldering round the back that hasn't been looked at since it was installed), and the patch cables and all of that used in recording studios is nowhere [i]near[/i] the same 'quality' that these super-expensive hifi cables are. As seen in the post above mine.
Hilarity ensues.
Posted : 20/03/2012 9:20 pm
 grum
I'm sure some studios do use expensive cabling, but most don't compared to 'audiophile' gear - and all the sound engineers I know would be extremely skeptical of some of the fairy-dust claims in Nordost's promotional materials. High-end studios also sometimes spend lots of money on fancy (clean) power supply units - but unless the people running them are idiots they won't buy ยฃ20k kettle leads and plug them into a standard mains circuit.
As someone said above the point in a studio is to have as clear and flat a sound as possible, not to try and make things sound flattering.
I would also be very interested to know how many 'audiophiles' have spent much of their budget on sorting out proper acoustic treatment for their listening room.
Generally people use NS10s for a couple of reasons. 1) Most studios have them, so the engineer will have an idea of what things should sound like on them 2) They roughly equate to the kind of standard hi-fi speakers many people will be listening to music on.
They're not particularly great monitors, hence why they would use them in conjunction with other, more expensive sets. Genelec seem to be pretty popular - I've never worked in a studio that had Harbeth monitors.
Posted : 20/03/2012 9:21 pm
There is a lot of bickering here, and very little backing up of arguments.
While it is difficult to argue with someone who says that they themselves hear the differences between cables, if only because you are not sharing the same ears and brain to process the signal received from said ears, perhaps the naysayers could explain the reasons for not believing there to be differences?
Might even help to know what equipment was listened to and perhaps even the style of music? No willy waving, purely for reference.
For example, I can't imagine anyone could pick the differences in cables while listening to whigfield on an alba...
My stance: I can easily tell the difference between some cables, and struggle to tell others apart. Some amplifiers reacts differently to speaker cables due to the construction of the output stage and available power, amongst other reasons. I do not believe there are any magical noise pixies at work. I do believe that electrical properties and interaction of those properties between various pieces of equipment are pretty much the only reason for sonic differences. Cost has pretty much nothing to do with it.
For reference, I listen to various types of music, from Mark Lanegan to The Dillinger Escape Plan via Radiohead, through a Rega Saturn CDP, Naim Nait 5i amp and Jamo Concert 8 speakers wired together with Rega Couple interconnect and Naim NACA5 speaker cables. I use these cables because they have been designed to work properly with the components of their name sake and are not excessively priced IMO. I have tried others, I moved them all on. Nothing was better.
Posted : 20/03/2012 9:39 pm
Oh, and in response to the OP, I can half believe that article. In my experience, Monster products are pretty s4!t โ—
Posted : 20/03/2012 9:42 pm
People who give a carp about their wiring are the same as people who believe 29ers are the way forward
Gullible fools
Posted : 20/03/2012 9:50 pm
I'd be interested to know if any of the audiophiles have had their hearing tested. Given that hearing degrades with age, and I suspect that audiophilia is more fully indulged by old farts, it would seem to be a reasonable thing to do to ensure you're not attempting the auditory equivalent of polishing a turd.
Posted : 20/03/2012 9:55 pm
Yeah its funny really, from the music production perspective its the most important thing to do, before spending even ยฃ500 on monitors.
But not as important as
http://www.audiotweaks.com/reviews/cblelevators/page03.htm
http://machinadynamica.com/machina31.htm
Posted : 20/03/2012 9:57 pm
Pretty much the same reasons as for the belief in Gods. In that I don't doubt for a moment that people have a sincere belief and personal experience of interaction with various gods, however I have never had such an experience, so have to rely on empirical evidence, which for both gods and much of audiophilia appears to be somewhat wanting. When someone finds a quantifiable and repeatable difference in the transmission line parameters of wire declared fantastic by audiophiles compared to one a bit more pedestrian then we might be getting somewhere.
Posted : 20/03/2012 9:59 pm
I am not convinced that the intelligentsia of scorn such as crikey and his fellow-travellers have ever been exposed to a real HiFi system and what it can do. Although the level of wit is, of course, very polished indeed...
Posted : 20/03/2012 10:02 pm
Likewise, maybe you and I just haven't been to church enough.
Posted : 20/03/2012 10:06 pm
There is actually a serious question in there Mr W. If we are discussing something which is eminently dependent on a sense, it would be interesting to know how degraded said sense is.
You would struggle to be an art critic if you needed glasses but didn't know it.
...and as I said, hearing degrades with age, and I suspect that disposable income for audio related purchases increases, so are you spending money to compensate for aging ears, or are you spending.g money which will not overcome a physical problem?
Posted : 20/03/2012 10:12 pm
Cables matter - without them your system won't work. Defective cables with insufficient bandwith (excess capacitance) will screw up a digital system just as they'll cause a lowpass filter effect in analog systems, etc etc. But 13A mains cable meets the requirements for most passive loudspeakers. Those believing in cable snake oil keep the economy moving though...
Posted : 20/03/2012 10:45 pm
Obviously they're not going to be able to tell the difference without cable elevators!!!
http://www.russandrews.com/product-Cable-elevators-4227.htm
Posted : 20/03/2012 11:04 pm
I had some expensive denon separates and infinity speakers, decided to upgrade my speaker cables, didn't like the sound that the new ones made, and had to change them again. How's that possible if the cable makes no difference to the sound produced?
Posted : 20/03/2012 11:06 pm
 grum
Those Brilliant Pebbles are a stroke of utter genius - wish I'd come up with them!
Posted : 20/03/2012 11:09 pm
hearing may well degrade and you will lose HF response, but the most important part of the audio spectrum is still the midrange and this remains pretty well functional for quite a long time.
Posted : 20/03/2012 11:23 pm
russ andrews would have a heart attack if he could see the mess of cables in my system ๐Ÿ™
Posted : 20/03/2012 11:24 pm
Where's Mr Woppit gone?
I SAID WHERE'S MR WOP.... Ah forget it...
Posted : 20/03/2012 11:30 pm
Well?
Gone to bed?
Posted : 20/03/2012 11:47 pm
Have you seen how musicians treat their own audio and power cables! Stuffed and tangled up in a Tesco flight case (plastic bag). all crackly, held together with tape, power supplies modified to fit with tin foil. "yeah it does that, if you wiggle it like this its fine...see?"
As long as it's not tiny wire anything works. Most folk listen to MP3's all crunchy and horrible. Our venue PA is not flattering to any highly compressed source. I'm trying to educate Dance schools and failing.
Posted : 20/03/2012 11:58 pm
What musicians do isn't really the issue. You're not aiming to faithfully reproduce the exact spectrum of a guitar string - that would sound really rubbish. There's a load more distortion aka colour, timbre, texture, whatever, that's added by the amp, the cables, the room, the medium and all the rest of it that you want reproduced in your living room. And they probably add a load of stuff digitally that goes straight onto the CD/DAT without touching anything analogue.
So you want to reproduce what's actually on the CD as faithfully as possible - maybe. Then again maybe not ๐Ÿ™‚ We all have tastes. Also, I reckon that crappy pop music is produced to sound better on really cheap equipment, knowing their target audience.
Anyway. A lot of people on here are dismissing other people's experiences and anecdotal evidence as the waffle of a gullible fool. That's pretty arrogant of you and rather insulting to those who have gone to the trouble to try this stuff out.
How many people have actually tried out different cables and found no difference, rather than just hypothesising?
I should add that I am on my third set of speaker cables. Mostly necessitated by changing rooms and needing longer runs, but I chose to upgrade to ยฃ5/m stuff last time (many years ago though) and yes I could tell the difference - more bass.
Posted : 21/03/2012 12:54 am
Quite right, which is why I find the views of some of the alleged gulls on religion so interesting.
People in glass houses etc. ๐Ÿ™‚
Posted : 21/03/2012 10:07 am
Straw man argument. Irrelevant.
Any number of people in front of a music system will agree on what it consists of and that there is music coming from it. Their ears are receiving and brains interpreting in different ways, what all agree is actually there.
People who hear voices where no one is present and see things that others present do not, are hallucinating.
BIG difference.
Posted : 21/03/2012 10:26 am
 grum
http://www.ethanwiner.com/audiophoolery.html
That tells you pretty much all you need to know.
And Woppit your lack of awareness of your own massive hypocrisy is really quite hilarious. Do keep it up. ๐Ÿ™‚
Posted : 21/03/2012 10:39 am
I am glad you're amused. I don't understand the hypocrisy charge, though. Please explain.
Posted : 21/03/2012 10:44 am
Makes no difference what you use. Expensive cabling is a huge waste of money.
Talk to anyone in the profession, who does not have a vested interest in selling expensive cables.
Most of the high end audio setups I have seen demonstated use mains cable.
Posted : 21/03/2012 10:51 am
I agree that Nordost cable and the like are probably a waste of money with much of the "differences" being wish-fulfillment. I say "probaby" because I haven't actually heard a comparison demo, though I have heard it being used in systems that I didn't think much of, pretty or impressive-looking though they were...
The difference between audio cable and mains-wiring cable is obvious however. Inability to hear any difference would be like listening to a Harley Davison chugging past and then a Bentley purring by and saying that they sound exactly the same because they are after all, both powered by internal combustion. In my experience.
Having said all that, I do own a mostly NAIM-based system using their relatively inexpensive cable designed for best use with their own equipment, and it outperforms many other makes of equipment that I've heard at HiFi shows costing absolutely STRATOSPHERIC amounts of wonga. Go figure, as they say... 8)
Posted : 21/03/2012 11:01 am
Whoppit he may be saying your view is an act of faith or a belief in something you cannot prove. You wont listen to the evidence because you know from personal experience...please dont say you need it spellingout more than that as to what he is alluding too.
Why dont you all take your super ears and do the challenge not only will you be able to prove your point you will have a million.
Posted : 21/03/2012 11:02 am
I am aware that the measurements taken so far by the established methodology indicate what they indicate and I cannot "prove" that there is a difference between the reproductive qualities of audio cable and mains-wiring cable in this way.
I have, however, demonstrated it.
To my mind, this raises some interesting questions as to what method needs to be developed so that this can be explained.
Unfortunately, there was no one else present at the time, for independent verification but I am confident that such would have been forthcoming.
I would suggest that the likes of grum and IanMunro should try out their own demo which would be easily arranged and cost only pennies. They may find the results interesting.
Just a friendly suggestion, no offense intended.
The thing about speaker cables is that the results from obsessing over them are going to be far less effective, by orders of magnitude, than from getting rid of passive crossovers (audiophiles would die if they realised how much distortion is caused by the inductors in a crossover) and using line level active crossovers and amplifiers wired directly to speakers.
If you prefer the sound of skinny cables to decent cables then you're probably enjoying the mid-bass hump due to an increase in woofer Qts as a result of the series resistance. Cables do make a difference but as long as resistance and capacitance are low (as with 13A mains cable) then that's the job done.
Posted : 21/03/2012 11:13 am
 grum
I'm not convinced that's really an answer to anything Woppit. I could arrange my own test, but I know that research shows our perception is clouded by various factors. Unless it was a proper double blind test there would be no point.
BTW I'm not disputing that there can be noticeable differences between different types of cable, it's just that once the basic physics needs of the cable are met any further supposed gains are based on myth. And the claims for AC power leads improving the character of the sound are laughable.
Again:
The total number of correct answers was 73 out of 149, which amounts to 49% accuracy. That is no more accurate than flipping a coin, and therefore, no statistically significant detection of power cable differences.
Test participants were asked to rate themselves as to how much of an audiophile they considered themselves to be. The scale was 1 to 5 where 1 = ?I?m not an audiophile at all? and 5 = ?I?m a hardcore tweak.? (?Tweak? is the word Manny chose; I would not have used such terminology, which I find belittling in this context). The self-proclaimed hardcore audiophiles got 48% correct; the rest got 50% correct. Again, no significant differences based on whether or not a listener felt he was an audiophile or not.
http://www.hometheaterhifi.com/volume_11_4/feature-article-blind-test-power-cords-12-2004.html
Posted : 21/03/2012 11:16 am
Oh. I thought you were. Many on here are, without actually trying it out, bizarrely.
Care to explain why I'm a hypocrite, BTW?
Posted : 21/03/2012 11:19 am
Up until August last year, I don't think I'd ever owned a HiFi set up worth more than ยฃ500 in total. Don't get me wrong, I love good audio, but in the same way that there are people out there who are keen cyclists but don't feel the need to buy an Ibis Mojo, I was happy with what I had.
Then I moved into a house which had been originally been fitted out as a luxury serviced apartment next door to a 5* hotel, but the hotel decided it wanted a long term let rather than having to manage a serviced apartment. One of the major attractions was a ยฃ25k Linn multi room set up (5 zones) with the lounge having a 5.1 type set up).
The system was incredible. Watching movies in the lounge was a joy, and playing BF3 in the cinema room used to give me PTSD.
I've moved out of the house now, and I'm back to some fairly basic kit. I think I noticed the difference the first few times I watched a movie or listened to some music. I even considered buying some 2nd hand Linn (or equivalent) kit for a week or so.
But now I'm back to being (almost) completely happy with my basic set up. Yeah, I can hear that it's not as good as the Linn set up, but ยฃ25k? No chance.
Perhaps my ears aren't as special as audioophiles' though.
(NB - I'm prepared to spank ยฃ5k on bicycle(s), so I have no appreciation of true value, and would have happily spent the money on hifi stuff because i like it, but I just couldn't get the money/experience factor to balance out. Like I said though, maybe my ears are just shit)
I guess my (long winded) point is that the law of diminishing returns seems to be huge in audio kit. In saying that, some of the 2nd hand Linn kit I looked at seemed to hold its value well, so not necessarily pissing money up against the wall, if components were purchased with care then it could be an investment.
Posted : 21/03/2012 11:21 am
the challenge involves two specific cables and a power amplifier of which Mr Woppit has no experience.
He has said that he uses Naim amplification.
There is something funny about the design of most Naim amplifiers that means that they are particularly sensitive to speaker cables, and they may go unstable unless they have a couple of metres or so of cable with adequate inductance, such as Naims own cable.
So it is quite feasable that he can hear differences between cables.
Posted : 21/03/2012 11:22 am
I believe you're getting confused here between "I can aurally tell the difference between a specific cable costing thousands and a sensibly priced good quality audio cable," which is what the challenge is, and "I can aurally tell the difference between sensibly priced good quality audio cable and mains flex," which is what the Wopster is claiming.
I don't know the veracity of his claim, but you can't use "the James Randi organisation says you can't hear a difference in any cabling" as a basis for evidence, because it simply isn't true. The challenge is for one very specific cable, not all cabling, and continually dragging it up is misleading.
Posted : 21/03/2012 11:24 am
 grum
But even your 'cheap' audio cables I bet cost a lot more than some electric strimmer power cord, which they are functionally identical to in use. And what about the power cable?
Can you really not see it? It's pretty obvious, and Junkyard spelled it out to you. You vehemently espouse a rational, evidence based approach to life, especially on matters of religion, yet here you are suggesting that personal experience trumps everything, including physics.
what levels are you suggesting - I think there is a lot more distortion in the actual voice coils in a speaker.
Posted : 21/03/2012 11:28 am
I suspect that the enthusiasm for expensive cabling and the like is the result of having reached the point where, due to being minted, a person has reached the point where they have spent as much as can be spent on high-end equipment (amps and so forth) but still have the upgrade bug but, like having a bad cold, can't shift it. It's got to the point where the search becomes the object and they've forgotten all about listening to the music but can't stop thenselves.
Posted : 21/03/2012 11:32 am
 grum
Let it all out Woppit, it's better once you admit you have a problem. ๐Ÿ˜›
Posted : 21/03/2012 11:34 am
If you're going to quote me, you'd best be accurate.
I never suggested anything of the kind.
Whatever.
Posted : 21/03/2012 11:36 am
I suspect that the enthusiasm for expensive [s]cabling[/s] bike components and the like is the result of having reached the point where, due to being minted, a person has reached the point where they have spent as much as can be spent on high-end equipment ([s]amps[/s] carbon cranks and so forth) but still have the upgrade bug but, like having a bad cold, can't shift it. It's got to the point where the search becomes the object and they've forgotten all about [s]listening to the music[/s] actually riding the bikes but can't stop thenselves.
FTFY
๐Ÿ™‚
Posted : 21/03/2012 11:39 am
If you wanted to do that you would buy some reference monitors with a flat frequency response, as used in audio production, and not an 'audiophile' set up. The sound you would hear wouldn't necessarily be very pleasant to listen to though, which is why for recreational listening you buy equipment that flatters the sound and makes it 'nice', rather than what it truly sounds like.
I admire and agree with Mr Woppits approach to religion, but this has proved most interesting, especially the bit about 'developing a method to explain it', which has similarities to the way religious types deal with calls for evidence; your experiments can't demonstrate x therefore your experiment is questionable, not x.
Posted : 21/03/2012 11:44 am
This is one of those myths propagated by the audiophile magazines to keep you stuck in the cycle of hi-fi upgrading rather than buying some far better value (but still expensive) active studio monitors and being blown away by the sound. Aiming for perfection in the frequency, time and space domains will achieve fantastic sound - you don't need to 'flatter' recordings. If studio monitors were tiring to listen to you couldn't spend all day mixing and mastering on them.
Posted : 21/03/2012 11:45 am
Yes. However, if something is demonstrably happening, then it would behove (let us say) science, to figure out 1: a way of measuring it and 2: derive an explanation.
It seems to me.
Posted : 21/03/2012 11:48 am
Fail.
It all depends which 'reference' monitors you use.
I mentioned Harbeth, which are a derivative of the range of monitors designed at BBC research Department. In the same tradition these speakers are still voiced by the designer comparing the speakers performance to real sounds, like human voice, and then tweaking the speakers crossovers (active or passive) to achieve the closest match.
This contrasts to many modern reference speakers that are basically just designed by computer.
I bet when the band, or whatever, were in the studio making the recording they sounded pretty good - if you have an accurate playback system then they should also sound the same and therefore pretty good.
Posted : 21/03/2012 11:49 am
Page 2 / 3
