Omelette frustratio...
[Closed] Omelette frustration
18 Users
My wife makes me an omelette and it tastes lovely and looks lovely.
Today she is doing the xmas shopping so I have to make my own lunch. I get all the same ingredients and end up with something that tastes strange and looks like a car crash. Grr...
Okay, not the best rant but it is nearly Christmas so lets be happy
Posted : 22/12/2009 1:44 pm
You did break the eggs, right? You can't make an omlette without breaking eggs.
Posted : 22/12/2009 1:47 pm
You did pre-heat the pan till the oil was, like, proper smoking?
You can't have a rant about something you've done youself. It's against the rules.
Wee in your own shoes.
Posted : 22/12/2009 1:48 pm
Of course I broke the eggs, I break everything I touch.
Eggs, bacon, onions, cheese, mushrooms.
Oil? What Oil? Doesn't the butter and fat from pre-frying the mushrooms and bacon count?
Posted : 22/12/2009 1:51 pm
that's why it looks like road kill...
Posted : 22/12/2009 1:52 pm
Yes. Then cook slowly on a non-stick pan. It cooks through and no need for stirring or touching.
Posted : 22/12/2009 1:53 pm
did you let the eggs set before you put your other bits in?
 cp
noooo, you need LOADS of oil 🙂 for a really good one, you need a good layer in the bottom of the pan...
keep the eggs moving in the pan until they start to set, then load in the rest of the filling.
I just can't care about the way my omlette looks, it usually comes out looking like scrambled eggs with bits.Always tastes the same and fills the same hole.
Posted : 22/12/2009 1:59 pm
How many eggs?
2 eggs are never an oeuf.
Shall I leave now?
Posted : 22/12/2009 2:26 pm
Posted : 22/12/2009 2:28 pm
Mmmm rubbery.... how not to cook an omelette!
hot pan, butter, not oil. eggs in, use a fork to give it a good going over in the first 30 seconds of cooking, leave on heat for 1 minute.Add Cheese. Fold over. another 45 seconds. Omelette. Done.
Posted : 22/12/2009 2:32 pm
Always butter.
Posted : 22/12/2009 2:34 pm
That sounds like raw egg in a cooked egg packet. Bleugh
Posted : 22/12/2009 2:35 pm
strange, cause when i made about 20 a day for 6 months in a hotel I never had one complaint...
Posted : 22/12/2009 2:38 pm
 Pook
mine always look like puke
Don't try and fluff the mixture in the pan, ends up like scrambled eggs!
It's something the chefs tell you to do, so you screw it up and end up buying their book to learn how to do it!
There is no need, just get loads of air in the mix before you put it in the pan, while still runny in the middle fold into pouch then cook for a minute then flop out, sorted!
lots of hot olive oil - butter will just burn at that sort of heat
pour your egg mix in - then use a wooden spoon to drag the cooked egg into the middle of the pan, the runny egg will then run onto the hot pan surface and cook itself.
you should have a nearly cooked omlette in about 30 secs
add your cheese to the top, and fold over - leave a few seconds to melt the cheese and cook any remaining raw egg
Posted : 22/12/2009 2:42 pm
Not if you're quick enough it won't, it may go a bit nutty, but theres nothing wrong with that
Posted : 22/12/2009 2:44 pm
This I don't agree with - French omelettes (which are the fluffy ones I believe) are nicer in presentation and also cook more quickly. I always do them like that and don't have any problems. I guess the trick is to only fluff them up until they have partially set - if you carry on fluffing (ahem) it will end up like scrambled eggs as it can't bind together once fully cooked.
Posted : 22/12/2009 2:46 pm
I separate my egg whites and yolks. Whisk the whites up, add the yolks and gently fold.
Put the pan on a highish heat, pop in a knob of butter, when it's melted put in the beaten eggs, with some nicely grated cheese on top.
A few minutes into the cooking, fold said omelette and serve when a golden brown colour ( not burnt).
Voila.
Posted : 22/12/2009 3:05 pm
*chuckle* where else but STW could you get 20+ posts arguing over how to make an omelette.
Posted : 22/12/2009 3:08 pm
I put the eggs into a tupperware box and shake violently. It fluffs the eggs up beautifully, plenty of air in them.
Posted : 22/12/2009 3:12 pm
Anyone mentioning "oil" and "omelette" needs to go back to school. Butter every time!!
Posted : 22/12/2009 3:15 pm
Doesn't it melt the plastic?
Bunnyhop speaks the truth - that's the correct method for creating very light thick omelettes.
Heat the butter until it very gently starts to bubble and then reduce the heat just enough so the bubbles stop forming but still remain.
No more than a couple of minutes and then fold and leave to firm through for a few seconds.
Voila.
Posted : 22/12/2009 3:17 pm
 cp
i use half butter and half oil. the oil seems to help prevent the butter burning.
only takes about a minute or two to cook an omlette... anything longer you get a proper weird thick and crispy on the outside crust going on. no need at all for non-stick pans either.
move the egg round till it starts to set then stop moving it round. you wont get 'scrambled eggs' if you do this.
fluffy omlettes??? southerner.....
Posted : 22/12/2009 3:22 pm
