Not putting the hea...
Not putting the heating on - how's it going...?
 myti
22 degrees in Brighton yesterday. We had dinner outside though we did light the chimenea after dark for a few hours to keep the dew off.
Posted : 09/10/2023 8:06 am
@cinnamon_girl At 20 yrs old it’s well worth checking if yours is a condensing one as that will make a difference.
Posted : 09/10/2023 8:54 am
 mert
Had our first gentle freeze over the weekend, nearly went down on my arse outside the back door on friday night.
Had the heat pump serviced on friday, it's 22 years old. Had a new compressor about 10 years ago, under the manufacturers warranty, as it's supposed to last the life of the unit. Needed new temp sensor on friday as well (20 quid).
Other than that, it got a clean bill of health.
Had the log burner going on saturday and sunday evenings too. House is warm enough, but wanted to get everything dried out and good to go for when the weather turns properly. (Chimney sweep is due to visit on wednesday too)
Posted : 09/10/2023 9:20 am
I replaced the summer duvet with the winter duvet yesterday. Much better.
Running the central heating for half an hour this morning prior to having smart meters installed this afternoon.
I might light the approved wood burner when the temperatures next drop but I think I'll use the gas central heating more often this year given the increased price of wood briquettes.
Posted : 09/10/2023 9:44 am
Condensing isn't that big a gain and you only get it if you always run it cool enough for it to be able to condense (which I suspect most people aren't doing). The payback time for swapping out a working non condensing to a condensing one is still over 10 years (when I last did the maths), which isn't a very strong business case.
Posted : 09/10/2023 9:59 am
Condensing isn’t that big a gain<br /><br />
Really? Everywhere I look there are figures of 20-30% quoted. Is that all just sales pitch rubbish then a bit like car MPG figures? Mind you even if it’s only 10% that’s worth having when bills are £200+ per month.
Posted : 09/10/2023 11:00 am
thats what Im hoping for having just swapped a non condensing boiler from 1992 for a modern condensing boiler. I dont think the efficiency gains are only in the condensing (although thats probably the lions share), but there are also gains to be made from modern boilers being much more intellgent than just full power heat on or off, ie modern boilers can modulate the burner to reduce short cycling etc,ie reduce the flame, they can also be more intelligent monitoring the temperature of the return flow and keep the pump running when the burner is off etc .
My old 1992 glowworm was literally just full power on or off, based on a mechanical thermostat for the flow temperature. Obviously depends how clever the old boiler is, but in my case I'm hoping for quite a difference.
Posted : 09/10/2023 11:10 am
That would be £20 a month, say over 6 months of the year so £120 (we use virtually no gas for half the year).
A new boiler all in is probably £3k.
You'll get your money back in 25 years!
IMO anything over 10 years isn't worth bothering with.
My old 1992 glowworm was literally just full power on or off, based on a mechanical thermostat for the flow temperature. Obviously depends how clever the old boiler is, but in my case I’m hoping for quite a difference.
Same as our 30+ year old Potterton Nettaheat Electronic (70% efficient). But it works fine, doesn't short cycle and our gas bill is quite modest. Every time I run the numbers, there's not a strong case to upgrade. You can still get spares for it and I just keep it going myself, replacing bits when they fail.
Posted : 09/10/2023 11:29 am
That would be £20 a month, say over 6 months of the year so £120 (we use virtually no gas for half the year).<br /><br />
Well, yes at 10% and only for 6 months but at a quoted 30% and assuming most people are heating water even in the summer. so say £500 per year saving, that’s covered the cost in 6 years.
Plus you get a 10 year warranty which is useful for people that don’t do their own maintenance. <br /><br />Specific cases vary quite a lot though obviously. For you clearly not much to be gained.
Posted : 09/10/2023 12:00 pm
30% would be a best case assuming the new condensing is always running at a low temp where it can actually condense and the original was very old and not fan assisted. If they end up turning the flow temp up so the house heats up quicker or for warmer hot water, they've just thrown away most of the efficiency gain!
£500 a year would mean your original gas bill would have to be several £k, which means a large house or someone who likes living in a sauna.
Our gas bill for HW in summer is only £5 a week ie £20 a month and that's not scrimping on hot showers (mind you, no teenagers in the house, just cats).
But yes, each case is different.....
Posted : 09/10/2023 12:23 pm
Every time I run the numbers, there’s not a strong case to upgrade
yep, every case is different, it depends how much gas you use, and what you pay for the gas, at the peak of gas prices last winter,my new boiler/cylinder etc would have paid back in 4 or 5 years (even faster without the government price support) . With prices now significantly lower its looking like payback in around 10 years - but I presume prices will continue to drop a bit over the next couple of years, pushing the return on investment past 10 years.
There are other non financial benefits though - like the house now heats up faster than with the old boiler - cant work out why this would be , but it does. Plus a much greater supply of hot water from the much larger hot water cylinder means we're not constantly waiting for the water to heat up after one shower etc, plus the water heats up much faster due to the fas recovery coil in the unvented tank. Our newer setup seems just more fit for purpose/better than the old one, but again this does depend how unfit for purpose the old setup is. I think ours was very unfit for purpose
Also some people (not really me though) take the view that return on investment is not as important as just reducing your use of fossil fuels.
I've only had the summer duvet on for a couple of weeks.
Desk thermometer showing 20C at the mo, heating not going on yet.
Posted : 09/10/2023 12:32 pm
Same here. Numbers for replacing our early 80s baxi with just a gas valve and heat exchanger were sitting at about 18 years payback until fuel prices went nuts. It was kettling and short cycling just before the price jump so got it changed just it time.
Ballparking comparative costs, (I've not compared volume consumptions pre and post), given domestic prices peaked about 80-95% higher than pre, we're using about 40-50% less. But, its a much cleverer modulating system boiler with fully integrated pump and flow controls, AND its been heavily optimised for condensing, AND we reduced our standard indoors temp to 18 from 20, AND we also replaced the old tank for a new heavily insulated one, AND we changed to an unvented system for efficiency and reduced losses through the header tank.
Posted : 09/10/2023 2:32 pm
It’s October, the sun’s out, it’s 18c outside, and we’ve got all the windows and doors open.
Nope, heating not on yet 😆
Same here except it's 22 during the day and hasn't dropped below 13 in the night for a long time. Still sleeping with the bedroom window open otherwise it gets too hot! Does help I'm in a very warm block of flats, even though I'm on the ground floor. I've normally had the heating on once or twice now due to predicted cold snaps (storage heaters so have to plan a day ahead) but not this year, I'm actually having to clean flies off the car it's so warm!
Posted : 09/10/2023 3:28 pm
I'm away at the mo, but the Wiser app tells me that the heating kicked in for 15 mins or so this morning, as the temp in hallway and bedroom above got down to the 'Away mode' set point of 14c.
Mid Oct ain't bad, but may lower the set point!
Posted : 15/10/2023 7:47 pm
I’m away at the mo, but the Wiser app tells me that the heating kicked in for 15 mins or so this morning, as the temp in hallway and bedroom above got down to the ‘Away mode’ set point of 14c.
My house this morning was about 14c as well, that was quite chilly! But outside had got down to 0c so not unexpected. Popped the heating on for half a day while I went riding, it was all toasty warm when I got back.
That's the first time it's been on this season though.
Posted : 15/10/2023 7:50 pm
Clover and Clover reacted
I’ve overridden my timer several times over the last few days, because evening temperatures have noticeably dropped, and now I’m at home most of the time, instead of at work twelve hours a day, I’ve revised my timer settings, and I’ll review them again as the winter progresses. It’s on right now, because it was getting noticeably chilly by around teatime.
Posted : 15/10/2023 7:54 pm
Probably limescale, you can clean it out with Fernox DS40.
We're in a super hard water area and I descale ours every 10 years or so (when it starts kettling).
Had to put mine on for the first time this morning.
Below freezing (-1C) outside and the house was down to 13C.
Posted : 15/10/2023 8:07 pm
Ours kicked in for the first time Saturday morning, then yesterday evening. Cars needed scraping this morning, autumn had arrived.
Posted : 15/10/2023 8:32 pm
I have no heating 🙁
c/h boiler died in September, British Gas condemned it. So now I’m trying to get it replaced, turns out I have an old fashioned one pipe system which is not suitable for modern combi boilers.. so now I need a whole new heating system 🥶
Tested the heating yesterday. Only the second time since we moved in. No need to put it on yet but wanted to make sure it worked.
Posted : 15/10/2023 8:42 pm
My heating is off. The pub I'm in have lit their fire though 🙂
20231015_180015
Posted : 15/10/2023 8:45 pm
Clover, retrorick, MoreCashThanDash and 3 people reacted
First real wintery day, daughter left the front door open going to her mates, our heating thermometer went down below 18 and it kicked in, worked fine, no horrible smell this year, did have a new boiler and so on, so that might be the reason.
Fully expect a new 'crisis' to appear in the next two weeks that'll unfortunately see energy prices double before December!
Posted : 15/10/2023 8:48 pm
I've caved in, thermostat at 20c now....
Painting:
"The arrival of the gas bill"
Oil on canvas, artist unknown.
gas
Posted : 15/10/2023 10:08 pm
cerrado-tu-ruido, Clover, james-rennie and 11 people reacted
LOL @mattyfez 🤣🤣
Posted : 15/10/2023 10:12 pm
Ours kicked in yesterday set at 17 hallway sitting at 16.5 got the fire on too that'll warm the house.
Posted : 15/10/2023 10:16 pm
Just got back from a week in Cyprus and it's a bit of shock...
Posted : 15/10/2023 10:32 pm
Roasty toasty holiday cottage in a chilly Northumberland 👌😁
[url= https://i.postimg.cc/qMRJXhdq/IMG-1932.jp g" target="_blank">https://i.postimg.cc/qMRJXhdq/IMG-1932.jp g"/> [/img][/url]
Posted : 15/10/2023 11:32 pm
Stove lit for the first time tonight.... still no heating.
Posted : 15/10/2023 11:35 pm
Stove lit for the first time tonight…. still no heating.
I'm sure we've been over this many times in this thread already but what part of having a fire in your house is not having heating?
Posted : 15/10/2023 11:37 pm
jacobff, Pauly, footflaps and 3 people reacted
 DT78
yep our heating has kicked in.  set to 18.  was down to 2 last night.
Posted : 15/10/2023 11:50 pm
Put it on as got fed up of all the doors sticking.
Posted : 15/10/2023 11:52 pm
 FFJA
A trip to B&Q on the cards here, MrsFFJA’s house was 10 degrees this morning. A day with the heating on and it raised the temp to a tropical 12 degrees….  No noticeable draughts, but wondering if the large un-insulated void below the ground floor is making it so cold? Suspect no insulation above the spare room that’s over the garage too. I’m hoping some insulation in those spots is going to make a difference as it’s always freezing in winter!!
Posted : 15/10/2023 11:56 pm
Are you sure the boiler was on all day and is actually connected to the radiators?  That sounds horrific.
Posted : 16/10/2023 12:24 am
I’m sure we’ve been over this many times in this thread already but what part of having a fire in your house is not having heating?
Yeah, this always amuses me also. "I've not put the heating on yet but I've lit a massive fire in the house to keep me warm" 🤷‍♂️🤷‍♂️🤷‍♂️
Posted : 16/10/2023 1:00 am
That's a good point!
Of course you're right, but lighting the stove to heat ⅓rd of downstairs and nothing upstairs feels better than burning oil to heat the whole place!
Posted : 16/10/2023 1:20 am
My heating came on yesterday morning. Officially winter in Leeds!
Posted : 16/10/2023 9:05 am
Mine wants to be on now... but i need to order some gas, which will take till Weds... it is, a bit on the chilly side this morning.
Posted : 16/10/2023 9:06 am
2 Deg outside here this morning in the South Cotswolds.  My Nest is complaining vociferously about "NOT BEING ABLE TO CONTROL THIS EQUIPMENT!"  as it's less than 14c in the house and it's trying desperately to reach 17c and has been for some time.  I may need to switch the boiler to allow for central heating again...
Winter is coming.
Posted : 16/10/2023 9:10 am
This, this morning.
Posted : 16/10/2023 9:20 am
That's not an insulation issue - the heating clearly isn't working. How many radiators are there? Are they hot?
Posted : 16/10/2023 9:26 am
Heating is on, was at £3 before the family even woke up this morning...not great.
We converted the spare room into my little girls room and it is freezing cold, every other room is toasty except hers.  Just cant figure out where the cold is coming from except its a north facing corner room, 2 external walls and above the porch/hallway.  I've doubled the insulation in the roof above her room and even checked the stud walls for insulation (none there).  She wont sleep in there anymore, proper shitty for a first bedroom!
Next step is hiring a thermal imaging camera to see where the rooms losing heat.
Posted : 16/10/2023 9:35 am
 FFJA
@molgrips 8 radiators and yep they get hot but this never seems to lift the temp. Tbf they’re probably too small for the size of house I think.
Posted : 16/10/2023 9:36 am
Our heating clicked on yesterday.
My wife must have been anticipating it, as a couple of minutes after it came on she shouted "Whoop!! The heating's on" down the stairs.
I'm quite pleased, as we'd reached the point where the towels in the bathroom weren't drying & the normal suspect doors that stick around this time of year are starting to be a pain.
There's a lot of moisture in the air at the moment. I guess partly because it's still quite warm during the day, but I've been wiping a lot of condensation from the windows over the last few days.
Might treat myself to one of those Karcher window vac things.
Posted : 16/10/2023 10:15 am
Page 39 / 47
