Noisy Arcam CD play...
[Closed] Noisy Arcam CD player?
7 Users
Got an old Arcam 8 CD player, it's started making a buzzing noise when the power lead is installed, even when the player is switched off
Tried a different power lead and no difference
Any idea what it could be?
Otherwise it still works fine
Posted : 21/12/2011 11:29 am
Power supply inside I bet.
Posted : 21/12/2011 11:33 am
Turn up the volume on the amp.
Woody's probably right.
Posted : 21/12/2011 11:39 am
Just worried it might blow up or catch fire if I leave it plugged in
Posted : 21/12/2011 11:40 am
jamesgarbett - Member
Unplug it then.
Posted : 21/12/2011 1:48 pm
 GJP
[url= http://singletrackworld.com/forum/topic/fsot-hifi-black-cyrus-cd6s-cd-player ]Buy this one it will sort out your problems !!![/url]
Posted : 21/12/2011 4:11 pm
If it has a toroidal transformer (normally heavy and round) they can sometimes do this with a noisy mains supply. Or the bolt could be loose, they do vibrate a bit. Plug into a different ring main or remove cover to check these theories out.
Posted : 21/12/2011 4:30 pm
Where do you live James. I have an Alpha 7 that
wont spin discs. Pretty sure the power supply
would be the same.
Posted : 22/12/2011 12:55 pm
