NIkon D40 Camera Pr...
[Closed] NIkon D40 Camera Problem
6 Users
"Error. Press Shutter Release Button Again!.
Does anybody know what the problem is, how it can be fixed or how much it's likely to cost?
There is a very feint click a few seconds after the shutter button is pressed.....it sounds like the shutter is going down and then a pause and it goes back up. I've taken the battery out and put it back in, removed the lens and refitted it, fitted a different lens and cleaned the lens contact points
Any help gratefully received.
Posted : 21/02/2009 9:59 pm
is there a hardware reset you could try?
Posted : 21/02/2009 10:06 pm
it's broken 🙁
when you say a faint click - I wonder if that's the lens stopping down ? Or it could be one curtain moving. Does the viewfinder go blank ? If so the mirror has popped up.
shutter fire is (order may vary):
mirror up
lens stops down
first curtain opens
2nd curtain closes
lens opens up
curtains retract
mirror down
Posted : 21/02/2009 10:09 pm
Just looking for a hardware reset. thanks for the tip.
Arse! Viewfinder blacks out and doesn't clear again until the shutter button is pressed again. I'm guessing it's very poorly 🙁
Further to the above. Tried the hardware reset. Still the same 🙁
Posted : 21/02/2009 10:21 pm
how old is it?
Posted : 22/02/2009 12:11 am
Purchased from Jessops on 22/12/2007 so just over a year old
Posted : 22/02/2009 9:24 am
Select 200 asa as your default film speed / iso.
Put the camera's control dial to M.
Select a shutter speed of 1/250 second.
(In fact, you could try all the shutter speeds if you like)
It might be that you had it on P and were shooting inside with a slow lens and the shutter speed is 1 second. That would account for the time delay!
Check that the lenses are correctly sighted on the camera.
Let us know how this works out.
Tim
Posted : 22/02/2009 10:01 am
but not the error message! The sole function of a camera is to take photos, and if it instead generates an error message that can only indicate it is broken 🙁
Posted : 22/02/2009 6:22 pm
[quoteThe sole function of a camera is to take photos
Well thank god you've cleared that one up for us SFB, I'll never again doubt your authority on matters photographical. 🙂
Posted : 22/02/2009 8:23 pm
No luck with your tips either Ti29er but thanks very much for the suggestions. I'll take it in to Jessops tomorrow.
Posted : 22/02/2009 8:26 pm
I meant that the error message was pointless. It would have been more useful if it had said something like "Shutter jammed, please submit for repair"
Posted : 22/02/2009 8:41 pm
