New transponder key...
[Closed] New transponder key for "blocked" vehicle?
I've been given the run-around by a few shops and suspect that people here will prove to be more reliable!
My vivaro came with a single key, I'd like a 2nd for obvious reasons. However it seems that the usual process of making a spare is "blocked" in some way, the suggestion is that the van was lease or hire or something (which wouldn't be surprising, it was used commercially). Is there a way round this? It can't be that rare an issue surely. I've spoken to (and visited) several different Timpsons and they've all said something different. I first tried Harrogate and they told me to go to Skipton, Skipton told me it could only be done by someone plugging a computer into the ECU which they didn't have but Keighley definitely did, but when I phoned Keighley they said no it's impossible (though the specific person who deals with that stuff was not in, so the phonee might have been mistaken).
Posted : 01/08/2017 2:57 pm
Have you tried speaking to Harrogate Auto Electrics? You'll get more informed advice from them.
Posted : 01/08/2017 3:02 pm
Or speak to Vauxhall. Yes they'll want to charge you a fortune but if they say " yes sir that'll cost you £450" at least you know its possible.
Posted : 01/08/2017 3:06 pm
take it to the main stealers.
Posted : 01/08/2017 3:08 pm
+1 speak to vauxhall. Did this on my astra, new key £45
Posted : 01/08/2017 3:12 pm
My suggestion would be to speak to a good indie garage (not necessarily Vauxhall) and ask them who they use for programming keys etc.
I had cause to require a new key for our Scenic, Renault wanted around £180 for 1 new key programmed.
A bit of asking around led me to a local guy who recommended an e-bay seller for the blank keys and he would then programme the keys. Total cost £110 for TWO keys.
Avoid going to a dealer if you can help it.
Posted : 01/08/2017 3:17 pm
Something similar on my MX5 when I lost the key.
Basically, you can't just add 1 more key - meant to stop a dodgy garage or someone cloning your key then coming round to nick it later.
You need to code all the keys you want at the same time and this un-synchronises the current keys
Posted : 01/08/2017 3:18 pm
Not necessarily. It depends very much on the maker I suspect.
Our original Scenic key works as well as the two new replacements, the ECU can recognise / store 4 different keys.
Posted : 01/08/2017 3:21 pm
try auto locksmiths 01274 305621
Posted : 01/08/2017 6:49 pm
