New laptop screen w...
[Closed] New laptop screen with an unusual fault.
4 Users
Just fitted a replacement screen to my Lenovo x230 laptop and it has a fault I have never heard of before.
It seems to have a part number printed on it that is only visible once the screen is working.
I have tried cleaning it off but with no effect.
You can actually feel it when you run your finger over it.
Any suggestions about removing it? I would like to avoid having to return it, so if it can be fixed I would prefer that.
Posted : 23/11/2014 1:39 pm
was it a thin peel off film that you've missed
Posted : 23/11/2014 1:40 pm
Gosh, that's different.
Contact the supplier and see what they suggest. If you attempt an unsuccessful DIY repair / clean and are unsuccessful they might well refuse to replace it because you've damaged it.
Posted : 23/11/2014 1:41 pm
Ah yes, good point. Every screen I've ever fitted came with a screen protector over the front that you're supposed to remove, though they've been loosely attached by masking tape rather than a peel-off type. However, I see no reason why that might not be the case.
Posted : 23/11/2014 1:43 pm
Never thought it might be a screen protector.
I'll open it up and check.
Posted : 23/11/2014 1:46 pm
craig and cougar - many thanks gents. It was a screen protector.
Normal service resumed!
The other screens I have replaced had protectors with the masking tape.
Still feel a bit of an idiot. Especially as I have sent an email and photos to the supplier! 😳
Posted : 23/11/2014 1:54 pm
Posted : 23/11/2014 1:55 pm
On the bright side, your email will probably be forwarded to everyone in tech support.
Posted : 23/11/2014 1:57 pm
