Hi all,
Got a document with a bunch of figures, tables etc. Each one has a caption created using the "Insert Caption" tool in References. I've also used the "Cross-reference" tool to mention the figures and tables within the text, eg "see Figure 4-5 for an example of this".
The numbering of the captions is all messed up. From what I've seen, the cross referencing all links to the correct figures/tables, but the numbering is not in order. eg it goes 3-1, 3-3, 3-2 etc etc.
Ctrl A + F9 does not fix it, nor does closing and reopening the document (which apparently updates everything).
I understand that for captions inside a text box (ie almost all of them) they need manually updating, but that doesn't seem to work anyway.
Any tips?
Ta! Duane.
Try putting it in outline mode, then select all, update.
Try printing it (as a pdf to save paper)
That should force all the fields to update.
Nope ๐
(to both)
'Fraid not, think that's for Word 97! Case 2 sounds like what's happening to me though.
Select all ( the whole document).
Go to the index, right click, update all fields. This will force the whole document including references to update.
genuinely read the thread title as "Miss World 2010 - Updating captions and cross-references"... the OP didn't make a lot of sense thereafter ๐ณ
For Word 2010 the help is here:
http://office.microsoft.com/en-gb/word-help/troubleshoot-captions-HP005189363.aspx
My guess is that you are going to have to reformat the document so the offending captions are in the body of the document and the pictures are formatted as 'in-line with text'. The Caption numbering will then look after itself.
Good luck!
Right click and update all fields.
I had a colleague deliberately take out all the auto numbered captions and cross-references from a 60,000 word report that I'd put together because he didn't understand them.
SC - looks like that's what I need to, link the figure captions (slave) to the caption in the text (master), not vice versa as I currently have.
Any ideas how to do that..? (That link doesn't explain how to)
Thanks!
Duane - I would copy the figures out of the text box and into the main text (each figure in a 1x1 table if that helps formatting).
And fingers crossed that you don't break the cross-references in the main text.
If you wish to email me the document (email in profile) I'll have a look at it for you - no guarantees though!
