Mould Testing, wher...
[Closed] Mould Testing, where?
10 Users
Need to get some samples tested, does anyone know a company that analyses samples/sends out test kits?
Thanks
Posted : 18/01/2011 10:29 pm
Also i dont need a test to prove the presence of mould, i need to know the types present.
Posted : 18/01/2011 10:47 pm
Now I've let my personal hygene slip from time to time but I've never got to that stage.........
Posted : 18/01/2011 10:50 pm
Try your local water companies labs, if they won't do it they'll probably be able to point you in the right direction. Won't be cheap though...
Posted : 18/01/2011 11:20 pm
ahem... as in mould found in damp buildings... 😀
come on, surely someone on here is a mould specialist?
Posted : 18/01/2011 11:21 pm
I'm a microbiologist but never done any typing on mould, just general yeast and mould tests. The English water companies have bigger labs that do a wider range of tests (not just on water) than we did.
P.S. we had a minimum charge of £250/month and that was over 5 years ago.
Posted : 18/01/2011 11:50 pm
We used to use a company to do this for us but now we have in house capability. I can't remember who, will look up when I'm in work.
Otherwise, try your local Univ. A lot of these offer consultancy services.
Posted : 19/01/2011 7:09 am
try your local county council analytical services (scientific services), we use a combination of them and our own labs, but we have a minimum order of £100.00 so so if you only have a couple check your local labs first.
Out of professional interest why do you want to ID them and do you want to genus level (not to costly but of limited use) or do you want exact speciation?
Even if you ID something fun like aspergillus to genus level it's only a limited number of species within the genus that are actually opportunistic pathogens in susceptible individuals.
It depends what you want the information for, most labs will give you the data but without decent interpretation of the data by someone who knows what they're doing you can easily go off an aright old tangent
Posted : 19/01/2011 7:25 am
theotherjonv- cool let me know chap.
Yep university is probably a good idea indeed, i need to identify specifically the presence of Candida as I have been ill with intestonal overgrowth (lovely) and need to know if the mould here has been causing it or not.
Just for peace of mind really and to know whether clean-ups need to be done.
Posted : 19/01/2011 8:07 am
Walla - where did you get your diagnosis of Candida from? Its often at best a very dubious diagnosis used by quacks
Posted : 19/01/2011 8:20 am
NHS doctor, i had a couple rather obvious symptoms which i rather not write online, and it fitted my symtoms prefectly.
Having taken the anti-fungal i feel quite ill too which is a good indicater.
Posted : 19/01/2011 8:28 am
walla24 - Member
Im quite partial to a bit of Stilton or Isle of Wight blue if that helps? 😉
Posted : 19/01/2011 9:14 am
Mmmmm brie and grapes on toast....where were we 🙂
Posted : 19/01/2011 9:43 am
Anyone else have any ideas or contacts please?
Posted : 19/01/2011 2:07 pm
sorry, was in a conference this morning
Try http://www.mcs.uk.net/
Posted : 19/01/2011 2:17 pm
cheers will have a look
Posted : 19/01/2011 11:04 pm
 Del
don't mean to be funny but bleach is about 20p a bottle. why not just clean the stuff up?
Posted : 20/01/2011 9:35 am
Nearest University.
What sort of testing did you have in mind?
NBC biological warfare type testing?
Posted : 20/01/2011 9:52 am
 Spud
Could try some of our lot here: http://www.hpa.org.uk/web/HPAweb&Page&HPAwebAutoListName/Page/1222236703354, I have no idea what they may be able to offer but could direct you to somewhere that could if they can't.
Posted : 20/01/2011 1:08 pm
Del- would if I could but its all over I'd never be able to get it all.
just need a simple analysis of anything in the air eg spores so I can work out why I'm ill at work.
Posted : 20/01/2011 1:19 pm
Thanks spud il drop them a mail
Posted : 20/01/2011 1:20 pm
