My old 1978 gl1000. Ignition switch was buggered and not working so got a new one for £25happy days. Fitted it this morning, connected it all up, turned it on, lights, camera and no action, starter button doing nothing..tried the kick start and it fired up...any ideas?
Starter relay?
Does that come with pictures??!! 😂 I know nothing about motorbikes, I will look it up in my Haynes.... I expect I should check fuses too?
Ok, I think it's that thing near the battery? I'll have a rumage with the wires.
If it were the main fuse you wouldn't get lights, if it were the starter you'd get noises.
Find that. Turn ignition on, use a pair of pliers and put on each terminal to bypass
Note, there will be sparks!
Thanks, I 'll give it a go later in week
Wtf. Get out there!
I have given up to bask in father's Day stuff...actually I went for a mtb ride with son, it was during that I remembered the kick start handle in the dummy tank!
Yip, my bets, starter relay.... you have connected it all up properly? 😀
Sorted thanks a connector to the starter relay had come unplugged in my rummaging with wires. Thanks a lot!!
