Mopping up water in...
[Closed] Mopping up water in a car
Left the window open in the car and it got flooded, is there some kind of magic sponge, pads you can buy to soak up the water?
Yes I am an idiot ๐Ÿ˜ณ
Posted : 07/05/2012 5:33 pm
down the local garage and vacumm it out.
Posted : 07/05/2012 5:37 pm
Vacuum then throw a couple of bags of silica gel in there. Then vacuum again. Repeat as necessary. ๐Ÿ˜†
Posted : 07/05/2012 5:41 pm
Newspaper covered in cat litter.
Posted : 07/05/2012 5:58 pm
soak the standing water out with a sponge/tea towel/ newspaper etc. Then leave a broadsheet newspaper in the footwell to soak up any in the carpet over a day or two.
Might be worth putting a bowel of salt out as well else you'll get moisture on the inside of your windows and a foisty smell!
Posted : 07/05/2012 6:05 pm
 hora
driy rice. empty a 500gm bag in the damp area. liberal covering.
Posted : 07/05/2012 6:20 pm
I used a wet and dry hoover in my girlfriends car - it had a failed door seal so it had been accumulating water over a long time. Then a day or so later hoovered it again. Then sat a dehumidifier in there for a night, with a tea towel sealing the gap in the window where the cable went in.
Posted : 07/05/2012 6:52 pm
I drilled a hole in the floor
Frankly i was amaized it held water to begin with but it did so drain holes it was
Posted : 07/05/2012 7:05 pm
