Micro sim from stan...
[Closed] Micro sim from standard sim?
Anybody cut a standard sim down in size to fit a micro-sim phone?
Easy or not worth the risk?
Posted : 30/06/2015 2:48 pm
 iolo
Very easy. Either use another micro sim or download a template to know where to cut.
Don't worry if you cut through the chip as it still works.
Posted : 30/06/2015 2:50 pm
OP
Can you not just get a free micro sim from your provider?
Posted : 30/06/2015 2:51 pm
Fast haggis - yes - that will my first option but I need it for Saturday to take to my daughter in Paris! Bloody kids!
If I don't get it in time I'll get her to cut the old one.
cheers
Posted : 30/06/2015 2:56 pm
Most independent shops can just clip your old one.
Posted : 30/06/2015 2:57 pm
 nuke
Worth noting micro is often thinner as well...when I chopped my standard sim down, I sanded the back down as well
Posted : 30/06/2015 2:59 pm
You can do it, but the phone may not like it. A SIM tray will work, a spring loaded slot probably won't
With EE I just popped into the nearest shop and had a new SIM in the correct size in about 5 minutes.
Posted : 30/06/2015 3:17 pm
Call into your nearest mobile phone shop and ask for a micro sim, it'll cost about a £1.
Posted : 30/06/2015 3:26 pm
I've cut several down with a pair of scissors, never had a problem.
Posted : 30/06/2015 3:32 pm
Yeah easy. I've even cut one down to the "nano" size to fit an iPhone. I just used a template off the net, scored it with a sharp razor, snapped the edges off then lightly sanded with a emery board.
Posted : 30/06/2015 3:38 pm
Just to check, Are you sure it isn't micro SIM ready? The last couple of Sims I've had have been normal size with a press out centre to make than micro.
Posted : 30/06/2015 4:16 pm
Dead easy - I'm pretty inept and if I can do it without screwing up, anyone can.
Posted : 30/06/2015 4:17 pm
Std and Micro are supposed to be the same thickness, nano are thinner.
Posted : 30/06/2015 4:25 pm
