Mechanics: Honda Cl...
[Closed] Mechanics: Honda Clutch Slipping
6 Users
I've an '04 Accord CDTi with about 70k on the clock. About 10 months ago the clutch started to slip under hard acceleration in 4th and 5th. It did this for a while but then over summer stopped. Then late summer it started again but 3rd as well. Now it's not slipping. I was out on Saturday with 2 bikes on the roof and used full throttle through the gears on a dual carriageway and it was fine.
I've got a price for a new clutch but this makes me think that maybe its something else. Surely if the clutch plate is worn and on its way out it will only get worse?
Any ideas?
Cheers,
Dan.
Posted : 15/02/2010 9:42 am
Contamination, crank seal leaking or something dripping down inside your bell housing. If you'd said on cold days it slips worse I'd have gone down the route of saying you generate a *little* more power in cold weather, but for it to display the same thing over 12 months would suggest it's not temp related.
Posted : 15/02/2010 9:47 am
Still an engine out job then 🙁 and might as well put a clutch plate in while its out
or do I just put up with it?
Posted : 15/02/2010 10:20 am
I have a civic diesel with a clutch at 110K. It makes a squeaking noise but hasn't slipped yet (biting close to the carpet and quite heavy) The cost of Honda taking it out, and the piss while they're at is was £670.
I'll hang on bit longer.
Posted : 15/02/2010 10:22 am
Could just be a leak from another location (cam cover etc) dripping down block. Check that sort of thing out before whipping the engine out.
Posted : 15/02/2010 10:32 am
 Doug
Sounds like slight contamination that manifests itself just before the slave auto adjusts as the clutch wears. Personally I'd live with it but the SO would want it changed.
if you check out [url= http://www.civinfo.com ]civinfo[/url] you will find lots of problems with Civic clutches slipping "before their time". Might be the same with Accords.
I have a 56 Civic diesel, bought with 27k on the clock 6 months ago. I have had to have the clutch replaced due to slipping in similar circumstances to you. The car was out of the manufacturer's warranty so I had to cough up the labour, even though they did pay for the clutch as a gesture of good will (if ever there was a euphemism for owning up to the problem!).
Apparently there are stories of Civic Type R clutches going in 2000 miles 😯
That said, at 70000 miles you've not done too bad, but it is an engine out job
Posted : 15/02/2010 10:35 am
 jonk
Can sometimes be the cruise control switch that causes this common fault.
Posted : 15/02/2010 10:37 am
70K miles isn't BAD for a clutch TBH. A little light but depends how hard it's been thrashed.
Posted : 15/02/2010 10:41 am
had that checked
Posted : 15/02/2010 10:59 am
How does the cruise control cause it?
Posted : 17/02/2010 10:30 am
Must admit I was confused about that too.
Posted : 17/02/2010 10:32 am
