mcmoontertrackworld...
mcmoontertrackworld....... Vices
The what?
Posted : 27/06/2021 8:45 pm
A life of vice
Clean of rust and put oil where rust was 🙂
Posted : 27/06/2021 10:52 pm
Seems a lot of people don’t like the idea of refurbishing vices, not sure why!
Or heinously ruin it with a slathering of hammerite like everyone else “refurbing” and make it look nothing like new – look good on the bench though.
As I pointed out with mine, it was in a shocking state, covered in several layers of different coloured grubby paint, crazed and filthy, and really not a nice thing to look at. Just cleaning up with the whizz-wheel wire brush made a huge difference, giving it a couple of coats of flat blue Hammerite that was a close match to the original made sense.
The one the poster got as a gift, showed honest wear, with original paint, so in no way did it need stripping and re-painting.
Two completely different situations. Why spend several hours doing something that isn’t needed?
On the other hand, spending the time refurbishing something that had just been crudely painted but didn’t show much actual wear through use was well worth it for the end result, where wear of the paint from use will show a proper patina over time.
I’m a bit obsessive about painting things, I like to do a decent job and I didn’t ‘slather’ the paint on, one careful coat, masking the jaws, let dry for a couple of hours, another coat, checking for any missed bits, let dry, then a final coat. Looks like oven-dried enamel.
If mine had looked like the freebie one, I’d have been chuffed to bits, squirt of WD40 with a rag, job jobbed, minimal effort.
Posted : 28/06/2021 12:40 am
Wally reacted
The what?
Where metal rubs against metal. So the bit where the handle rubs against the jaw and where the threads are engaged.
Posted : 28/06/2021 9:20 am
Vice is back together, greased and wiped with an oily rag
[url= https://i.ibb.co/Ks8Wrjy/PXL-20210628-115413973.jp g" target="_blank">https://i.ibb.co/Ks8Wrjy/PXL-20210628-115413973.jp g"/> [/img][/url]
Posted : 28/06/2021 1:59 pm
Finally got the vice my Dad gave me firmly mounted on the workbench, used a pair of M12 130mm bolts! With the vice itself, the 2x18mm MDF top, then 39mm CLS, there's 100mm of material to get through, but just in case that wasn't enough to support it (FFS LOL) there's a 5mm metal footplate as well.
So far I've used it to bend some galv builders band into right-angled brackets with a pin hammer.
vice1
vice2
After cleaning it up I rubbed with some bike grease to keep the rust at bay. How would you finish it?
Posted : 30/06/2021 10:28 pm
Now this is a pretty funky vice being restored. I would love one of these for sure....
Posted : 01/07/2021 11:07 am
@sirromj that looks rather smashing. I’d leave it exactly as it is - lovely patina…although the bolts are a bit bright!
Posted : 01/07/2021 12:27 pm
I just pulled this old Woden out of the local tip. Unfortunately it's not in as good condition as it looks - the jaws are wonky, the bolts which hold them have stripped the holes in the casting, and the slide has a crack in it. It does still function for holding things tightly whilst you wallop them, but it's definitely seen better days.
More pics
Not decided what to do with it yet. I have a couple of decent vices already, and not sure it's worth my time rfixing this one up. If anyone in Sheffield it interested, let me know before I make plans for it!
Posted : 14/07/2021 6:25 pm
papamountain reacted
@sirromj - finish it? That’s finished, that is! Clearly well used but looked after, a quick spritz with WD40 every now and again and a wipe over, that’s an heirloom item you’ve got there. Nice. 😎
Posted : 14/07/2021 8:10 pm
Quick query on sizes - found a Record 84 and Record 6 to go an look at. Is bigger really better? General workshop fettling and the 6 is a few quid more but not much. Any reason not to go bigger? I've just built a 3m long workbench out of substantial reclaimed timber so I have the space (although slightly worried it's a bit high to then stick a 6" vice on top!)
Posted : 22/07/2021 12:38 pm
I wanted a quick release vice and this popped up for sale.
Record 113 - It's enormous, FAR too big for my use but I couldn't just leave it there for the price they were asking....
What to do with it though? I thought outside workbench.... but can I resist a refurb?
Posted : 22/07/2021 7:15 pm
Finally after months of searching, 2 come along at once!!
https://flic.kr/p/2medwrD
The 84 is a steel version - fitters vice so designed to take a beating (not as brittle as cast iron). Some Neanderthal had painted it (badly) Red over the original blue so stripped that back and will give it a lick of paint.
The 23 is a beast but had a harder life. Wonder if it once used to be quick release as the threads have the same angled cut and “half screw” as the 84. Still works fine though.
No idea which one to keep but £45 each can’t complain!
Posted : 30/07/2021 3:59 pm
Free! To good or bad home - well worn Paramo fitters vice going for scrap.
Collection only from Rossendale.
[url= https://i.ibb.co/C9zxTQP/42-F52852-C2-BD-455-A-96-FC-CE419-C9-EDCFE.jp g" target="_blank">https://i.ibb.co/C9zxTQP/42-F52852-C2-BD-455-A-96-FC-CE419-C9-EDCFE.jp g"/> [/img][/url]
Posted : 11/08/2021 11:57 am
Another thread revival!
Funnily enough I was nerding out trying to find information on a vice that I've been given (karma for giving my old one away and then regretting it I guess), and ended up here.
It's a Woden 186/3 S in green. I've seen it listed in a 1957 brochure but no note on colour. From what I can tell, the green vices were older though. Anyone here nerdy enough to know?! Sounds like Woden went to blue vices at some stage and the green ones were early models?
It seems to be in structurally good condition and no rust, but not surprisingly after probably 50+ years, not great paint. I'll probably just clean it up though.
Posted : 11/12/2022 12:02 am
@walleater - difficult to say without pics, and I’m no expert anyway, but just from your description, so long as it moves in and out smoothly, (quiet at the back, there!), and doesn’t seem to try to slip or jump when tightened, then a spray with WD40 and a wipe over, job jobbed.
If the one I picked up had looked like sirromj’s, I’d have been thrilled to bits, but it really looked a mess. At least four different layers of different types of paint, maybe more, so cracked and crazed, and filthy dirty to boot, and even with a whizz-wheel wire brush it took ages to get all the crap off.
Posted : 11/12/2022 2:12 am
Lets see if this picture works:
Posted : 11/12/2022 6:37 pm
👍 nice one
Posted : 11/12/2022 7:23 pm
Another thread revival...
It's time to start the renovation of my Victory #3 vice;
IMG_6653
I don't have access to a media blaster, what's the best stuff for removing all the old paint? I gather NitroMors is no longer the shiz...
Posted : 01/04/2024 5:23 pm
lb77, anorak, lb77 and 1 people reacted
Just clean it, it looks fine.
Posted : 01/04/2024 5:42 pm
Murray, leffeboy, Murray and 1 people reacted
WD40 will get rid of the old oil and muck, if you really want to repaint it a flap wheel in an angle grinder will take the paint off. I haven't bothered with mine, I like the patina.
Posted : 01/04/2024 6:11 pm
Yeah just clean it, mine looked like that when I got it. And to be fair it still looks exactly the same
Nice little record. 50 years old
Posted : 01/04/2024 6:44 pm
Nitromors seemingly works better if you wrap it in clingfilm and leave it. As said though, unless it's down to the metal I'd leave as is. Blasting does no favours to the sliding surfaces if you don't protect them either.
Posted : 02/04/2024 12:45 am
dyna-ti and dyna-ti reacted
You can buy dichloromethane, which is the active ingredient of old nitromors, pretty cheaply, but it's terrible to work with in liquid form, presumably you can thicken it but i don't know what with. I experimented with sugar and that kind of worked. Or dichloromethane based strippers are still available "for professional use only". Evil stuff but it works great.
TBH though I might be tempted just to wire wheel it? It's a pretty simple shape, you should be able to get into most of the nooks.
Posted : 02/04/2024 1:06 am
Saw this at Sea Otter and thought of you all.
IMG_8047
Posted : 25/04/2024 10:23 am
AD, RustyNissanPrairie, AD and 1 people reacted
very pretty but £1499.00
for something that might get in the way of a hammer or saw..
Posted : 25/04/2024 11:56 am
There's a lot of wrong in that there clamping device.
If they give me £1500 I will design them a nicer looking one, and I promise not to use the word Vise .  😉 😆 😆
Posted : 25/04/2024 12:07 pm
fruitbat and fruitbat reacted
Neighbors were chucking a lovely record number 3, so I rescued it and gave it my mate over the road, I already have a no4 which is one betterer.
Posted : 26/04/2024 11:38 am
Seeing this thread has reminded me that I still haven’t used the Samsonia that I inherited a few years back. It’s crying out for a bit of grease 😄
IMG_3874
Posted : 26/04/2024 2:00 pm
fasthaggis, CountZero, CountZero and 1 people reacted
Snap. I acquired this a short while ago. It's taken a beating, needs a bit more than a spot of grease!. The quick release doesn't work, some deepish saw marks in the jaws. Summer project!
Must be pretty old, it's got older versions of any markers I've seen discussed - sunk logo, round turning knob, round "3" rather than flat top. 50's? Earlier?
Posted : 14/05/2024 12:24 pm
I’ve pulled my neglected Record Irwin No6 out of the hedge where I’d forgotten I’d stashed it 4 years ago!
It’s not in bad shape considering. I’ve got a spring repair kit from The Viceman, so it’s time for a sympathetic tidy up.
A bit of filing, wire brushes in a drill and maybe a bit of mild angle grinding. Then to decide on what oil to protect it  Certainly not going to cover it in blue paint.
It’s a big old lump too, so it maybe up for trading for a No4?
IMG_7815IMG_7817
IMG_7814IMG_7813IMG_7815
Posted : 29/05/2024 7:38 pm
lb77 and lb77 reacted
So many things wrong with that Orange Vice Co device, like a gap of about a millimetre at the back of the dovetail joint for the jaws!
And a cylindrical slide for the jaws? I can only imagine it’s all alloy for transportation to allow for some (very) light bike fettling.
I can’t imagine it standing up to someone using a length of scaffold pole to encourage a recalcitrant bottom bracket bolt to undo…
Hmmm, I’ve underestimated it, it weighs 50lb and can supply some serious pressure, just don’t use it as an anvil!
https://www.orangevise.com/orange-bench-vise/
Posted : 30/05/2024 4:05 am
Thats not a vice, THIS is a vice(or vise if you live across the pond)
Posted : 30/05/2024 4:13 am
That^^ looks like it should be hauled behind a steam train 😉🙃
Anyway,move over Orange Co and meet  the lovely Bugatti 😁
Posted : 30/05/2024 12:47 pm
Great thread, OK two years on from top pic and have oiled once the thread and the top bit of the vise that slides underneath the static part with fully synthetic 0/30 oil from the secretion of un-flowered sea creatures. Any other maintenance suggestions?
Posted : 31/05/2024 8:09 pm
Just "inherited" a couple of vices from a skip. Been outside for years in a neighbour's garden.
Still working though.
Paramo 1 and York 100.
Not sure what to do with them now. I've already got a couple of Records.
PXL_20241024_121321056PXL_20241024_121333993PXL_20241024_121342465
Posted : 24/10/2024 2:18 pm
Is this one of the oldest threads? Probably one of the handiest things I couldn't do without in my garage.
It's a bit like a frying pan in a kitchen or a radio first thing in the morning
Posted : 25/10/2024 12:21 am
thenorthwind, silvine, Wally and 3 people reacted
Seem to be getting vice suggestions in my instagram feed now. Here's a tiltable/rotatable wood-working vice:
Posted : 25/10/2024 1:02 am
The Paramo could really do with taking down to bare metal, stripping down and wire wool applied to all moving parts, followed by lots of lube.
The York, well, that’s a monster and no mistake! What it needs most is lots of bench space! 8-0
Posted : 25/10/2024 3:12 am
Seem to be getting vice suggestions in my instagram feed now. Here’s a tiltable/rotatable wood-working vice:
Thats called a pattern makers vice.
Posted : 25/10/2024 8:02 am
Looking at the rescued Woden 186B/2  i have, can you get aftermarket swivel mounts that fit easily? Apparently all Woden vices came the ability to fit a swivel mount but you try and find one.. it the only thing stopping me from bolting it down
PS: I have a carpenter vice and a Record No. 23 which is too big for my uses.. if anyone is interest (stourbridge ways)
Posted : 05/11/2024 2:14 pm
Had this installed about 6 weeks now. I've always made do with combinations of Black and Decker work bench, G clamps, levers and weight etc, but this is so bloody useful! I even clamped my SPD shoes in it the other day while I tapped an allen key into the slightly distorted bolt heads to remove them.
PXL_20240912_182931337.NIGHT~3
Posted : 05/11/2024 4:28 pm
What paint to refurb a record vice?
Posted : 05/11/2024 5:06 pm
WD40 and leave the existing paint? My vice looked awful but came up well with WD40 and a cloth
Posted : 05/11/2024 5:18 pm
My latest retirement project, a Record No. 3
Paint is Paragon Enamel, BS381C 110 Roundel Blue.
Posted : 24/07/2025 1:30 pm
dyna-ti, sirromj, anorak and 1 people reacted
Page 9 / 10
