Macbook pro fan noi...
[Closed] Macbook pro fan noise
 iolo
I have an early 2015 13 inch retina macbook pro. For the last week the fan is constantly running. It's sounds like car idling (but obviously not quite as loud).
It's bloody annoying and I've gone back to my notebook 10 inch windows thing to do my work as the noise is going on my nerves.
Has anyone else encountered this problem?
Is there an easy fix?
Posted : 30/05/2015 10:45 am
launch activity monitor, and have a look for discoveryd process under CPU usage- mine was up around 99% and killing the battery - kill the process- it's something to do with networks - you can google it - lots of geeks have looked into it- apple bug for now it appears
Posted : 30/05/2015 10:50 am
I had an older model, Mid 2011, that did the same. It was driving me mad too so I changed to an extra SSD drive and put all the apps/software on there and just keep files on the HDD. Runs much quieter and much, much faster.
Pretty easy to do and cost about £120 all in (I got a special offer from Maplin).
Ian
Posted : 30/05/2015 11:28 am
Ian
Retina mbp already has an ssd and it's not in the same form as a laptop HD
Posted : 30/05/2015 11:35 am
Apologies. I stand corrected.
Ian
Posted : 30/05/2015 11:41 am
dust and crap, anyway to clean it?
Posted : 30/05/2015 11:44 am
Try a PRAM reset (google it).
Posted : 30/05/2015 11:53 am
I'd be taking a can of compressed air to it in the first instance.
Posted : 30/05/2015 2:08 pm
If it's early 2015 i doubt there'd be much dust/fluff inside it.
Posted : 30/05/2015 2:45 pm
Sounds like a runaway process or you're doing some heavy duty processing.
As rockhopperbike says, start activity monitor and look for processes using high % CPU (99% and higher). Sort by % CPU to make it easy. If one process stays at the top for a while consider killing it. Usual culprits are webkit components, Chrome components, or a couple of the daemons.
Another check to make is CMD+option+esc and look for 'not responding' processes. If you're happy to, kill those.
If a process takes a long time to write to a disk (local, or networked) it can appear 'not responding'. If you kill it you will likely lose any work since the last save.
Posted : 30/05/2015 3:01 pm
