Linking pics to STW...
[Closed] Linking pics to STW from Flickr, problems??
Anyone else having issues? I cut and paste the URL for the pic, use the IMG button, the HTML code looks right to me, but when I hit post the image isn't there??
Posted : 29/10/2009 2:53 pm
Tester
[url= http://farm3.static.flickr.com/2601/4014512677_cd9188c1fa_b.jp g" target="_blank">http://farm3.static.flickr.com/2601/4014512677_cd9188c1fa_b.jp g"/> [/img][/url]
Working fine for me.
Posted : 29/10/2009 2:55 pm
OK then... what am I doing wrong? I used to just right click on the pic, then copy the image location and paste it into the IMG thingo. Now, when I right click on the image, I don't get the option to save image location. So instead, I use the 'Share this' option on Flickr and copy the URL from there, but it doesn't show up in the post?
[img] http://www.flickr.com/photos/32746168@N08/4055010023/ [/img]
Posted : 29/10/2009 2:58 pm
Testing, testing.
see, there should be a picture above!?
EDIT: in my post that is 🙂
Posted : 29/10/2009 2:59 pm
It never works for me when i use the "grab the link" address.
Trial and error led me to go to "Grab the HTML". The cut out the jpg add from the code.
Posted : 29/10/2009 3:00 pm
Install Mozilla, then Greasemonkey for Mozilla and add this script from Bez http://www.stewartpratt.com/?p=88
Posted : 29/10/2009 3:01 pm
It could be that Flickr have changed the Direct Linking options ?
By rights you are supposed to post the picture linking back to the flickr site (ie if you hover your mouse over the picture and click it will take you to flickr... like on my pic above). Try that.
Edit....
Install Drac's script. It is ****in brilliant. Works a treat for me.
a href=" http://www.flickr.com/photos/callmebob/3786626714/" title="Mole 1 by callmebobII, on Flickr" img src="
width="500" height="375" alt="Mole 1" / /a
Thats the Grab the html link.
I get this bit:
Then I use the IMG button above with it:
Hope that makes some sense.
Posted : 29/10/2009 3:05 pm
works as long as you've gone to the "all sizes" link before you try to copy location - IME
(didn't know about linking back to flickr - will I be arrested soon ?)
Posted : 29/10/2009 3:07 pm
Messy if you really don't want the ease of Phorumr then right click on the image and in Mozilla select [i]copy image location[/i] then paste that after clicking IMG.
Posted : 29/10/2009 3:08 pm
[url= http://farm3.static.flickr.com/2430/3785813509_5b365ca088.jp g" target="_blank">http://farm3.static.flickr.com/2430/3785813509_5b365ca088.jp g"/> [/img][/url]
Clicky hopefully.
Posted : 29/10/2009 3:16 pm
Joined Flickr just recently for posting up photos here, & so far no success beyond the red 'X'; trying the above advice...
[img][/img]
Nope, once again..
Edit; ah success, wonder what I did different??? How do you get it to link back then? Oh I'm so thick 😳
Trying to link-back again..
Epic Fail!
Thanks, Mr. Pants for the "all sizes" pointer...
Posted : 29/10/2009 3:18 pm
Well it means your doing something wrong Rob are you photos public?
Posted : 29/10/2009 3:19 pm
To get it to link back I used Drac's advice given above. Much easier than what I was doing.
Posted : 29/10/2009 3:26 pm
Posted : 29/10/2009 3:30 pm
Psychle
what you entered is [b]" http://www.flickr.com/photos/32746168@N08/4055010023/" [/b]
this is not the url of the image
you need to use the actual image address, this will show if you go to 'view all sizes' then right click and copy the image url
it'll be this [b] [/b]
giving
or use greasemonkey and sam's script as suggested
Posted : 29/10/2009 3:32 pm
Hey it works 😀
Posted : 29/10/2009 3:35 pm
Not fully read each reply, but I found this problem recently after many years of happily being able to post by just right clicking, choosing 'properties' and cut and pasting the stuff into img brackets. This stopped working recently and the 'stuff' that I cut and pasted changed to not having jpg at the end.
Random trials led me to clicking on the 'all sizes' choosing medium then 'properties' and it came up with the old format of 'stuff' in the bit you cut and paste. So that's what I do now. The rest is too complicated for an eejit like me, however, when I get home I'll read the instructions in the posts above and work out how to do it properly so I don't get arrested for something....
Posted : 29/10/2009 6:06 pm
cheers all, I've figured it out now. Just like jojoA1 I've always just right clicked and copied the image address, but that no longer works for some reason... so for now I'll remember to go into 'all sizes' and copy from there 🙂
Posted : 29/10/2009 6:10 pm
I've just started having exactly the same problem. Testing, testing
Excellent - to tip about going to all sizes
Posted : 29/10/2009 6:12 pm
I've only tried this once before..so here (hopefully) is a photo I tok last Saturday...
Posted : 29/10/2009 7:55 pm
[i]The rest is too complicated for an eejit like me, however, when I get home I'll read the instructions in the posts above and work out how to do it properly so I don't get arrested for something.... [/i]
Easy if you use the script I mentioned above, once you go to allsizes there's a new box for you to copy from paste it in STW and does it all for you no need to click IMG.
Posted : 29/10/2009 10:00 pm
Test, Excellent!
Posted : 29/10/2009 10:04 pm
 a11y
Drac - Member
That is awesome, cheers for highlighting that. Makes life easier.
Posted : 29/10/2009 10:08 pm
[url= http://farm4.static.flickr.com/3607/4039699660_149d3e416c_b.jp g" target="_blank">http://farm4.static.flickr.com/3607/4039699660_149d3e416c_b.jp g"/> [/img][/url]
[url= http://farm3.static.flickr.com/2617/4038950791_cca3d5a3da_b.jp g" target="_blank">http://farm3.static.flickr.com/2617/4038950791_cca3d5a3da_b.jp g"/> [/img][/url]
Ah so that's how you do it then. Cheers Drac 8)
Posted : 29/10/2009 10:24 pm
Yeah think it should be added to Forum Help as a tip.
Posted : 29/10/2009 10:26 pm
testing
Posted : 30/10/2009 1:27 am
Nope!
Posted : 30/10/2009 1:28 am
Ehmm!
[url= ]null
Posted : 30/10/2009 1:34 am
Nope - again!
Posted : 30/10/2009 1:36 am
It's IMG not url.
Posted : 30/10/2009 2:37 am
[img] "[/img]
TESTER
Posted : 30/10/2009 9:15 am
Ah bugger I'm still ****ing useless!
Posted : 30/10/2009 9:17 am
Posted : 30/10/2009 10:31 am
[img][url= http://farm4.static.flickr.com/3141/4056283881_a7e0934225.jp g" target="_blank">http://farm4.static.flickr.com/3141/4056283881_a7e0934225.jp g"/> [/img][/url][/img]
Posted : 31/10/2009 12:45 am
Please work this time!
Posted : 31/10/2009 12:50 am
Yipee! Cheers Drac.
Posted : 31/10/2009 12:52 am
No problem but Bez deserves the credit really.
Posted : 31/10/2009 1:16 am
 pate
I think I'm useless at this 😯
Edit: wow 😛 I finally did it but it's the one which doesn't link back to flickr I think. Does anyone know which one I have to use to link it back? I'm PC useless.
Posted : 31/10/2009 10:13 am
If you using the code posted up there ^ then when go to all size it's the third box.
Posted : 31/10/2009 6:31 pm
[url= http://farm3.static.flickr.com/2609/4062046146_7484e76b6a_m.jp g" target="_blank">http://farm3.static.flickr.com/2609/4062046146_7484e76b6a_m.jp g"/> [/img][/url]
Cheers guys, learned a new skill
Posted : 31/10/2009 10:09 pm
Posted : 31/10/2009 10:31 pm
how come my pic is so small?
Posted : 31/10/2009 10:32 pm
Manitou,
I think it depends what size you've selected from all-sizes & taken the url. eg.
this was 'small'-size url -
this was 'medium'-size url -
Still can't get the link back though...
Posted : 01/11/2009 10:42 am
[url= ]null[/url]Again?
Posted : 02/11/2009 11:35 am
They've definitely changed it.
Anyone give a tip for making the picture link back to the flickr page?
Posted : 02/11/2009 11:21 pm
Yes. Go to the previous page and read what Drac has posted.
Posted : 02/11/2009 11:40 pm
[url= http://farm3.static.flickr.com/2538/4119610799_4faa06f72a.jp g" target="_blank">http://farm3.static.flickr.com/2538/4119610799_4faa06f72a.jp g"/> [/img][/url]
Has that worked?
Edit: It seems so!
Posted : 20/11/2009 8:37 pm
[img] http://www.flickr.com/photos/34577062@N04/4090003992/sizes/l/ [/img]I've avoided doing this as it never seems to work.... so here goes
oh ffs
Posted : 24/11/2009 11:22 am
[img] http://www.flickr.com/photos/34577062@N04/4090003992/ [/img]
grrr
Posted : 24/11/2009 11:23 am
[img][/img]
DOH!
Posted : 24/11/2009 11:24 am
 nbt
Shizzletrack - you need to use square brackets, not angle brackets
Posted : 24/11/2009 11:25 am
[IMG] [IMG]
Ta daaa
oh dear lord
Posted : 24/11/2009 11:31 am
 TN
Since we're using this as a testing thread and I have been failing recently, here goes...
This is when I am not logged into my flickr account, having selected all sizes and then clicking on the medium option, right click, copy image URL
(edit: And it worked... Going to try again when I am logged into my Flickr account)
This is not loged in, having not clicked on 'all sizes'.
Okay, I have done exactly what I have been doing recently and failing apart from the fact that I was viewing my own album on Flickr without being logged in this time? Relevant, maybe?
Posted : 24/11/2009 11:34 am
Posted : 24/11/2009 11:38 am
Yey! Labmonkey!! Welcome to my world!
Posted : 24/11/2009 11:41 am
 TN
Okay, if you're logged in to Flickr but do not go to the 'all sizes' section, you don't get the 'farm3.static.flickr.com' address, just the user/photo ID path with no .jpg image defined and that doesn't work.
Sorted. 🙂
(I am sure someone else already deduced and said this very thing but I had to get my head around it so maybe my version will be helpful to someone else?)
Posted : 24/11/2009 11:42 am
 TN
Labmonkey, your photos are private - is that relevant?
Posted : 24/11/2009 11:44 am
[img] [/img]Just want to see if this pic works. Sometimes it doesnt.
Posted : 24/11/2009 11:45 am
TN - no idea?! I will have a look now... This has always foxed me, and I have never asked for fear of looking dumb... it seems that this latter statement may be correct! haha
Posted : 24/11/2009 11:46 am
 TN
Just testing...
Your 'IMG' brackets didn't have the closing /
You need to open with a {IMG} (in square brackets though, it'll go nuts if I use the proper ones!) and close with a {/IMG}
OK, attempt number 4
[img][img]
[img]http://[/img]
Posted : 24/11/2009 11:47 am
 nbt
Shizzletrack, what is the text you are putting between the IMG tags?
Posted : 24/11/2009 11:48 am
I've tried all sorts!"Grab the link" and "grab the html" as well as logging out and copying the url.
Posted : 24/11/2009 11:50 am
TN - I keep editing the first attempt, just to save me from fillig up this thread with failed attempts... but I now have the 'x' box... progress maybe? From using the advice you posted starting 'just testing' then a white lapierre...
Posted : 24/11/2009 11:52 am
[IMG] http://www.flickr.com/photos/34577062@N04/4090003992/ [/IMG]
the picture ain't even good, it's just the principle now!
Posted : 24/11/2009 11:53 am
Labmonkey, the race is on!!
Posted : 24/11/2009 11:54 am
@shizzletracxk, that URL you've used is the link to the page that has the photo on it, not the picture itself.
the image is:
all I did was right click on the image and choose "copy image address" (in Safari)
Posted : 24/11/2009 11:56 am
shizzletrack... i am foxed, completely... just ghot more coffee... maybe that will help!
Posted : 24/11/2009 11:58 am
img /img working for me
I am using internet explorer... I take it that this is bad? Since you all mention mozilla and safari?
Posted : 24/11/2009 11:59 am
Ladies and gentleman... I give you A PHOTO!
SUCCESS!!!!!!!!
Shizzletrack... well done, you won the race!
TN - thanks for all your help, there is a huge stupid grin on my face right now!
Posted : 24/11/2009 12:00 pm
is the drainpipe part of the frame? 😉
Granted, it was a poor photo, here's something a bit more arty-farty
[img] [/img] 🙂
Posted : 24/11/2009 12:06 pm
Testy Test:
Working for me.
Posted : 24/11/2009 12:14 pm
You used to be able to copy and paste the HTML code from the "All sizes" bit but doesn't seem to work now..
Posted : 24/11/2009 2:24 pm
Posted : 25/11/2009 12:49 am
Try again!
[img]http://[/img]
Crap!
Posted : 25/11/2009 12:59 am
