lawnmower & cha...
[Closed] lawnmower & chainsaw engine oil
9 Users
Are they the same? Can I put the engine oil I have for my Stihl chainsaw into my petrol push-along lawnmower?
I went to my local garden centre to get some oil but they don't sell lawnmowers anymore! Nor the oil you need for them. Takes up too much space which can be put to better use selling fluffy toys, pot pourri and jars of glass pebbles. 👿
Posted : 05/08/2010 3:56 pm
Is one diesel and the other petrol?
Posted : 05/08/2010 4:01 pm
both take unleaded
Assuming this is a serious question....
Both 2 stroke? The Stihl almost certainly is, the mower maybe. If they are, yes they may use the same oil for premix though the oil/petrol ratio may be different. Stihl like the petroil to be really oily if you don't use their 2s oil.
If your mower is 4 stroke, no the 2 stroke premix oil for the chainsaw is different from the oil you put in a 4 stroke sump. Cheap multigrade from Halfrauds should do it.
If this question is a wind up, well done.....and use rapeseed oil in both, you'll be reet.... 😀
Posted : 05/08/2010 4:13 pm
I was kidding.
Posted : 05/08/2010 4:14 pm
Your chainsaw engine oil will be two stroke engine oil yes?
You can't use that as engine lubricating oil in a four stroke lawn mower which is what I suspect you have.
I use whatever spare oil i have lying around in my mower, currently is Motul 300V fully synthetic which smells lovely!
Posted : 05/08/2010 4:16 pm
Chainsaw is either two stroke oil or chain oil. Dont use either of these as a lubricant oil in an engine as one is designed to burn and the other has anti fling qualities (yes really!)If its a Stihl use good quality Stihl stuff.
Mower 10-40 maybe? Use cheap halfords oil, should be OK
Posted : 05/08/2010 4:31 pm
No it wasn't a wind up. I am a bumbling idiot. I do use Stihl engine and chain oils with my chainsaw. Its in my top 5 toys ever 8) I was wondering about the 2 & 4 stroke thing, that's why I was asking...will get some cheap Halfords stuff for the mower then. Ta
Posted : 05/08/2010 4:48 pm
If your mower has an oil filler cap on top, it's a 4 stroke. If it has a second little tank in which to put oil, it's 2 stroke.
Posted : 05/08/2010 4:50 pm
The fuel tank will have either the emblem of a petrol pump and a drop (of oil) 2 Stroke
Just a petrol pump 4 stroke
just a fuel tank....2 Stroke
Fuel tank, seperate oil fill and dip stick/sight glass.....4 Stroke
Long cable coming out the back......electric 😆
Posted : 05/08/2010 4:58 pm
Chainsaw - 90% likely to be 2 stroke (usually pre-mixed oil:petrol - 1:50).
Mower - very likely to be 4 stroke - no oil needed in the fuel. In my experience good 4 stroke mowers very rarely need oil top ups.
Both use the same petrol - unleaded.
Posted : 05/08/2010 5:00 pm
Just checking my works mower and I need sae 30 and not 10-30 as I mentioned.SAE 10-30 will run thinner so you will use more and the engine will run hotter.
Google the make of engine,as alot of mowers use the same engine(honda or Briggs and Stratton for example)
Hope that helps
Posted : 05/08/2010 7:55 pm
Two stroke mowers do exist. We had one, it was really light, compact and sounded like a chainsaw on wheels 😈
Posted : 05/08/2010 8:10 pm
Yes, I've got one. It's a Flymo something or other. Woe betide he who dunt put in petroil, it'll be a short cutting session.....
Posted : 05/08/2010 8:43 pm
