Laptop hard drive h...
[Closed] Laptop hard drive help.
4 Users
Daughters laptop had a virus and she tried to use recovery discs to re set it. Then all she got was a black screen and a flashing cursor but can't type. I then tried using discs to restore and all went fine until windows restarted then black screen came back. I've googled it and the problem could be a knackered hard drive. If I buy a new drive will the restore discs put windows back on? and how hard is it to swap a laptop hard drive. Machine is only two years old so seems a shame to bin it.
Cheers, Graham.
Posted : 13/08/2013 5:03 pm
How hard depends a bit on the make/model. You should find some Youtube videos to help. Laptop harddrives are standard, I just bought a 750gb one for about £70 and switching it into my computer (Mac Mini was easy)
Posted : 13/08/2013 5:10 pm
Shouldn't be hard to replace the drive if you know which end of the screwdriver you hold, and which goes against the screw. 🙂 All you normally have to do is open a cover, gently remove the drive. It may be fitted in a caddy, if so then just make a mental note of the orientation of the connector on the drive so that everything slides back in nicely.
To rule out some other possible causes: does the laptop beep on boot, and if so, how many times ?
Posted : 13/08/2013 5:19 pm
It goes straight to black screen and flashing cursor and only beeps when you press a key. Pressing f2 repeatedly as you fire it up brings up set up page. I did this to get it to boot from dvd drive to restore with original discs.
Posted : 13/08/2013 5:24 pm
Download an ISO of Seatools on another PC and burn to CD/DVD, boot from the disc on the problem PC and run a full test, this will tell you conclusively if the hard drive is good or bad.
Posted : 13/08/2013 5:41 pm
