Laptop battery has ...
[Closed] Laptop battery has died.
8 Users
We have a HP laptop that is 20 months old, the battery has died. My wife was using it at the time and she said she heard a faint pop noise. Should a genuine laptop battery last this short a period. It only gets light use and most of the time is running plugged in.
Their seems to be a good range of non genuine replacment batteries out their can they really be any worse than the original. Anyone recomend somewhere to buy one from.
Posted : 26/10/2010 1:36 pm
Isn't the problem here that you were essentially charging a rechargeable battery continually? I thought that they liked to be charged and discharged regularly.
Mine went on the blink after a similar period of time and when it was on its last legs it kept making switching the mains circuit breaker.
Posted : 26/10/2010 1:45 pm
our dell went the same way, i was told that when the laptop is 'plugged in' take the battery out, it will last longer apparenlty.
some mad logic in there somewhere!
Posted : 26/10/2010 1:55 pm
Certainly shouldn't go in 20 months. Mrs M's HP battery holds only 5 mins of charge now, but has been left plugged in almost continuously for over 3 years
Posted : 26/10/2010 1:56 pm
My old battery only had 6 cells and lasted 1 1/2 hours or so. Bought one of the 12 cell ones off eBay and its very good.
Posted : 26/10/2010 2:00 pm
I don't think it has particularly been overcharged as it was still performing well giving at least 2 hours of use on the battery it sounds as if somethng has actually blown. It never really gave more than 2 hours of battery life.
Posted : 26/10/2010 2:02 pm
Batteries "go wrong" and expire early just like many other mechanical/electrical things.
Cheapest option is to grab the battery's partcode (from the sticker) and check on Ebay. Beware loads of supposed like-for-like batteries, not just second hand/recons, will be underpowered and may not even power up your machine. I know this from experience. Hence why it took 4-5 attempts to get a proper replacement battery for my HP.
Posted : 26/10/2010 2:06 pm
There was a recall on HP batteries
http://bpr.hpordercenter.com/hbpr/
80:20 rule.
Run it on battery once over 80% charge point and charge back up when down to 20%.
Laptops are designed to use battery so unplug it, but don't run it down to extremely low.
Should be able to get a replacement battery but they do take the mickey on prices.
Posted : 26/10/2010 2:08 pm
