ISS Supply Rocket E...
[Closed] ISS Supply Rocket Explodes at Liftoff
Expensive firework
Posted : 29/10/2014 12:24 am
Thats privatisation for you ๐Ÿ˜‰
[Edit] ??? Mwahahaahaaha!
Posted : 29/10/2014 12:26 am
What happens when you privatise space travel ๐Ÿ˜›
[Edit] beaten to it ๐Ÿ™
Posted : 29/10/2014 12:27 am
Blimey I didn't know ISIS had rockets like that. Good thing it blew up !
Posted : 29/10/2014 12:50 am
That's quite a bang. Fuel leak?
Posted : 29/10/2014 12:53 am
looks like one of the ancient 2nd hand soviet NK-33 engine fails then after a couple a second the first stage tanks explode. The rest falls to the ground and the 2nd stage solid fuel goes off like a fire work.
Posted : 29/10/2014 1:15 am
So, it is rocket science then.
Posted : 29/10/2014 7:29 am
Is it guy Fawkes night already?
Posted : 29/10/2014 8:14 am
I hope the clietnts with expensive satellites aboard remembered to tick the box for optional insurance.
Posted : 29/10/2014 9:10 am
'kin hell now that's what I call an explosion
Posted : 29/10/2014 10:02 am
 DrP
ka-blammo.....
DrP
Posted : 29/10/2014 10:06 am
Ah yes I see the problem. Clearly the left Falange has come loose prior to lift off. It's a common problem with the Antares series.
Apparently it really upset Richard Dawkins's dogs.
Posted : 29/10/2014 10:08 am
[i]Stay at your consoles
[/i]
Launch Team: Erm....I am currently underneath my console.
Posted : 29/10/2014 10:16 am
I hope the guy who lights the blue touch paper had retreated the recommended 100 feet.
Posted : 29/10/2014 10:41 am
 IA
More video and good info here:
http://www.slate.com/blogs/bad_astronomy/2014/10/28/breaking_antares_rocket_explodes_on_takeoff.html
Watch the press camp vid in particular, you'll want sound...
Posted : 29/10/2014 11:03 am
So after NASA has spent all that money they are now relying on old USSR technology and Ukrainian sub contractors to get stuff into space.
Funny how things work out.
Posted : 29/10/2014 11:14 am
I think NASA still do some of their own launches. But the actual lifting stage is probably the least interesting part of the projects so it makes a lot of sense for them to farm it out. Especially if you can punt it down to companies using moon-race era rockets they found in a skip to do the lifting...
Posted : 29/10/2014 11:52 am
Why the hell are they crying? Wimps.
Posted : 29/10/2014 11:57 am
I suppose stuff like that's gonna happen now and again when you try launching rockets that were built in the 1960's ๐Ÿ˜ฏ
Well, the rockets weren't built in the 60s; rather, the engines were designed back then.
Posted : 29/10/2014 11:59 am
Woh...
Posted : 29/10/2014 12:01 pm
Cougar - Moderator
It seems that these ones genuinely are barn-find soviet moon rockets, refurbished and with different control systems but otherwise yes, built in the 60s and 70s. Kind of a cool story tbh! Orbital don't seem to have a long term plan for when they run out though
Posted : 29/10/2014 12:06 pm
Really? Good grief.
Posted : 29/10/2014 12:10 pm
According to this article, they were built in the 60's and have been refurbished!
http://www.theguardian.com/science/2014/oct/28/antares-rocket-explodes-nasa-launch-pad-orbital-science
Posted : 29/10/2014 12:12 pm
It's the barn-find bit I like... Supposedly were all supposed to be destroyed but someone decided to warehouse them instead, where they sat for about 30 years, til someone from Aerojet decided to follow up a longstanding industry legend and found 150 of the most powerful rocket engines ever built just waiting. You can imagine them throwing off the dustsheet...
It's probably a much drier story in reality but frankly if it is, I don't care to hear it ๐Ÿ˜‰ It's like buried spitfires.
But then, the reason the russians cancelled their moon program was partly because they had a high fail rate- supposedly it's a great way to make a very light, very powerful, fairly unreliable rocket motor.
Posted : 29/10/2014 12:20 pm
One thing the former USSR/Russians have a heck of a lot of experience in is getting stuff in to space.
The last time I saw numbers, it was something like 1700 Soyuz launches, and that was well over a decade ago.
Indeed, that is exactly why the Europeans took the decision to build a Soyuz launch capability in French Guiana.
And as for privatisation? well pretty much the entire space industry in the western world has been created by public limited companies for a very long time, with only money coming from governmental sources for certain programmes (which may well be a significant financial portion).
Posted : 29/10/2014 12:55 pm
"Main engines at 108%".
So that's what happens if you red-line it.
Posted : 29/10/2014 12:58 pm
 LoCo
Yep, and someone appears to have taken the rev limter off that one ๐Ÿ˜
Posted : 29/10/2014 1:09 pm
Exactly what I was thinking..... Doesn't sound good does it?
Posted : 29/10/2014 1:18 pm
100% is the nominal max thrust in the original design. If the engines later on get rated to run at a higher power that original reference still gets used to avoid any confusion in test data and specs etc.
ie. these ones actually *do* go to eleven. Well... they're supposed to anyway ๐Ÿ˜•
Posted : 29/10/2014 1:39 pm
That's not uncommon- the 100% can be the original design limit but further testing and upgrades can allow them to exceed it.
So - this is pure wiki btw, for the example- the space shuttle main engine's power range was 65% to 109%- it took off at 100% then went up to 104.5% for the first 40 seconds after launch, then ran at 70% for most of the rest of the burn, after some revisions and upgrades. It was rated for 111% for emergencies, and 106% for short term burn but that damaged the engines and so wasn't used in normal use.
<edit- crossposted!>
Posted : 29/10/2014 1:47 pm
someone should show NASA and Orbital Sciences Corporation this, rocket science looks fairly simple tbh! ๐Ÿ˜†
Posted : 29/10/2014 1:57 pm
Spaceflight has a history of failures think Challenger or Ariane 5.
So if you want balls watch the first Shuttle launch. It had never been flown before unmanned, and John Young & Robert Crippen just buckled in and went for it.
[url=
STS-1 launch[/url]
Posted : 29/10/2014 3:15 pm
Thing fall down, go boom!
Sharkbait had exactly the same thought I did when I saw it in the paper. ๐Ÿ˜†
Posted : 29/10/2014 7:29 pm
 Pook
The second bang was the on site safety guy detonating it so it didn't fly off out of control somewhere
Posted : 29/10/2014 8:16 pm
That's what I thought too. The Range Safety Officer has the unenviable job of killing everyone on board on manned missions if the alternative is having a vehicle crash onto a populated area.
Posted : 29/10/2014 8:24 pm
