Is this possible? C...
[Closed] Is this possible? Converting a GPX file to turn by turn for Wahoo Elemnt
3 Users
As per the thread title. Entered my first Audax and have downloaded the GPX file but of course it does not have the requisite TBT cues for the Elemnt to read.
Is it possible to some how automatically add this and import the file in or am I going to have to reconstruct the route in Ride with GPS or Komoot?
Posted : 11/09/2018 8:08 pm
Can't you just upload it to komoot?
Also I seem to be being tbt from the wahoo app though I don't know if you can upload agpx to it. Maybe on the website?
Posted : 11/09/2018 8:18 pm
No turn by turn is on the unit (Elemnt and Bolt, not mini) but because Wahoo have installed global maps there is not enough memory to include all the map metadata to do it in unit. This is the same reason it can’t re-route of you go off course.
Komoot and RWGPS will include the requisite cues if you plan a route using them but I don’t know if they’ll add them to an imported route.
Will have a play and report back.
Posted : 11/09/2018 8:25 pm
Nemesis - legend. Works a charm - I imported in to Komoot, let it calculate route or whatever the option is and then it just syncs automagically to the Bolt.
I’ll wait to get the proper cue sheet for the ride and double check against that but looks good to me so far.
Posted : 11/09/2018 8:30 pm
Delete the maps you don't need to free up space
Posted : 12/09/2018 8:09 am
Delete the maps you don’t need to free up space
Is this possible on the Elemnt? Also I would imagine the firmware still needs to be programmed to make use of the map metadata required for on the fly TBT routing rather than relying on cues in the GPX data and I don’t think the Wahoo firmware is.
Posted : 12/09/2018 10:42 am
