The last two I've bought have been awful, one that wouldn't grip the tin and the other just destroys it. I remember my parents having one when they got married and it lasted about 50 years!
Can anyone recommend a can opener? Is it too much to ask for it to open a can?
Yes, there is one (maybe Oxo good grips) that unpeels the join rather than cuts. It's really good.
Butterfly can opener is your search term. They just work.
IKEA one.
Mine must be 22 years old.
Still opens cans
I have two different oxo good grips can openers. Both very good (for right handed people anyway).
Our OXO one is great, proper sturdy & has never failed. It'll even take the top off a corned beef can when the key snaps/goes missing.
I started a similar thread on here a couple of years ago. The search function being what it is, there's not much chance of finding it.
Anyhow, off the back of recommendations on it I bought a Khun Rikon and it's awesome. It will outlast me and just works.
Oxo good grips - it just works
We’ve got an Oxo one which works fine.
Also got an ancient one in the camper that arguably works better. This type: Guilty Gadgets Stainless Steel Butterfly Kitchen Can Tin Bottle Metal Steel Food Opener Camping https://amzn.eu/d0x7a4E
Can’t say I’ve ever had any can opener issues?
I have. Cheap ones are just rubbish. Ragged cut, blunt easily, clumsy to use, go rusty, awkward to wash. We had dozens over our married life including some more expensive ones. They all eventually ended up in the bin through frustration. That Khun Rikon is a joy to use compared to the others. It feels like it will last forever and wasn't even expensive.
They are really hit and miss in my experience.. I went through two or three in sucession when I needed a new one until I found a decent one. Was a cheap one, about a fiver, maybe more but less tan a tenner IIRC in a similar style to this... works really well and had it probably 5yrs+ now.
OXO GG as above
So are the Oxo ones under the rim, or inside the rim opening?
My other half has the older version of the Kuhn Rikon one and its been brilliant and lasted for donkeys years 👍
Seems like Oxo is coming out favourite but our Brabantia one has done a great job for many years
Tescos stainless steel one (£4), that they usually have hanging along their supermarket aisles.
Mines still ploughing away. Invest in a brush and let it steep in soapy water to stop the parts from getting too grimy.
I was wrong earlier, ours is a Kuhn Rikon.
I've recently bought a Brabantia one, but it seems a bit lightweight in all honesty.
I suppose i all really comes down to how long that toothed wheel lasts
Sounds like you need a busier life. I just use the one on my pen knife which i've had since i was about 11.
Cool. Do you carve meat, chop veg and slice bread with the penknife too? And brush your teeth with a twig? Fess up, you do don't you? 😉
Only used various knife type tin openers, such as the one on my work victorinox pen knife and the ones which i think are Canadian army issue. Never had a problem opening a can, plus you can peel an orange with them as well.
This never fails.
[url= https://i.ibb.co/nzkhBLT/501117008.jp g" target="_blank">https://i.ibb.co/nzkhBLT/501117008.jp g"/> [/img][/url]
This never fails.
If you have a spare hour to get around the whole of the tin 😆
How do you get to Carnegie hall ?
This always seems to do the trick...
Well if you insist on being an amatuer about it...
WMF Profi Plus here. Just works, sturdy, comfortable to use.
It's great there's loads of can openers that are "just" working, but I demand the best of the best! Not found it though.
I've been using an Army one since my uni days back in the 90's.
[url= https://live.staticflickr.com/65535/52510824635_c0b1e03fca_k.jp g" target="_blank">https://live.staticflickr.com/65535/52510824635_c0b1e03fca_k.jp g"/> [/img][/url]
I recall being introduced to a fixed blade version of that back in the early 90s. Took a while to get used to it, but worked a treat.
We use a cheap opener at the moment, but could do with something that is good for inner rim slice, not round the edge slice. Sone to both, some don't. Needs to be slim, most of the fancy ones are quite girthy.
Well if you insist on being an amateur about it…
😆 Hardly a place for it these days though is there. Modern kitchen - No. Off camping, well who brings tins of food camping ?.
Seems more of a gimmick to me.
How come?
Have had a Kuhn Rikon one for over 20 years. Still works. Although not so well with the cans that you can open with a ring-pull. Most of those though can be opened upside-down.
I have the same one derekstarship has.
I love it. I understand what I'm doing with it.....
Mrs t-r hates it.
It slices the top off the can leaving no ragged edges to cut your self on in the recycling like the old inner rim cutting one
I have questions.
See, the beauty of the way the Kuhn Rikon jobbies work is that they break the seal between the can and the lid, meaning no razor sharp edges that animals might lick the night it’s out for recycling etc., and a ready-made, perfectly fitting lid for the can if you don’t want to use all the contents.
@trail_rat we too have the lantana that derek_starship mentioned. I’m competent with it. Mrsjonwe and the children (big ones who really should be able to use an advanced design) struggle with it and revert to the butterfly model and dangerous edges.
Now the issue I have is with some cans that have a low height seam (aldi - why do you do this?) - it struggles to engage or stay engaged. Any tips?
Those Kuhn Rikon openers are a step above everything else. Once you work out you need to use the little pincers to lift the lid off...
I'm still not sure how it actually works, leaves you with two smooth edges that fit together like a container and lid, it's black magic I tell thee.
Mine is a Stellar stainless steel can opener that cost around £25 perhaps 15 to 20 years ago. Very good and solidly with only metal parts. Still look as new today. I tried to search online for the photo but couldn't find any.
Feature is similar to this one below but Stellar is much better designed and look much better.
Yes, no sharp edges anywhere once the can is opened.
Those Kuhn Rikon openers are a step above everything else. Once you work out you need to use the little pincers to lift the lid off…
I’m still not sure how it actually works, leaves you with two smooth edges that fit together like a container and lid, it’s black magic I tell thee.
Agreed. If you put the lid back on, you can't see the join the cut is that smooth. For a cheap kitchen gadget it's incredibly well designed and made. The bizarre thing is, we don't actually buy much tinned food, or it has ring pulls. So when we do, I get a tiny little buzz coz I get to use the Khun Rikon. Yes, my life is that sad.
you can’t see the join the cut is that smooth
Pretty sure that is because they do not cut the can. They unroll the crimped join.
Practice, practice, practice.
