Ditto. 180m is a huge distance when travelling at 10mph and indicates (to me) poor driving, I'd rather get past said dodderer to avoid potential aggro* later on.
* of course they might just pile into the back of me due to said dodderyness.
3 local roads to watch it happen, Hoole road in chester 30 mph speed limit, tailbacks into the city
Coast road at Ainsdale to Southport, cycle lane goes alongside it, so plenty of viewing opportunities,
and the A 483 from the Ruabon to A5 turn off. If ever on these roads at busy times check it out.
600ft == 180 metres. There's a gap and there's interstellar space.
Smoke him.
#awesomedriverthread
It's often the case for these drivers that once they have to queue for more than about 1 min, they just seem to "give up" and then completely switch off and totally fail to attempt to make any progress.
Our road network is busy. When you get to a feature, like a roundabout, junction, set of traffic lights or whatever, you need to navigate that feature at a safe speed, but also at a speed which is commensurate with clearing that feature for others in as reasonably a short time as possible.
Time after time i sit in a long queue at say a set of traffic lights, where the lights change to green and yet no one moves. Then just 3 cars dawdle through, and the lights go red again. And yet, the 50 drivers held up by those lights seem oblivious as to what is holding them up!
These dawdler seem to not understand basic maths: ie if 1000 cars an hr want to use a junction, just 1 sec delay per car will result in a huge queue.............
I'm happy to roll along at, say 15mph, when the car in front is doing 30 - stop - 30 - stop in the queue to a roundabout. No-one behind ever seems bothered by that, and I close up on the car in front sometimes. I think it's easier for them too. Though I don't see it catching on. But 600ft is going to wind up everyone.
And as mt above says, we should all fit through the junction efficiently.
Page 2 before we get making progress...
Plenty of times in the van I would just leave it ticking along get in second and just slowly roll along of there was no point in closing up the gap quickly.
Remember the phrase you are not stuck in traffic you are the traffic.
It won't change anything at all with traffic flowing smoothly unless the gap between the cars is greater than 3.6 seconds in your 1000 car example. The dawdlers understand basis maths and know the only time it's worth making an effort to get away promptly is when you're in the group of cars that will get through the lights before they change. The rest of the time it doesn't matter.
Cars are slowed down on congested motorways such as the M42 to avoid queues at junctions.
^^ er what??
if there is a "queue" at a feature then by definition that feature is resulting in a bottleneck, and hence every car passing through it adds to that bottleneck!
So, if there is always "a group of cars that will get through the lights before they change" ie, they will go red and someone, in the queue will have to stop. So, on every Green light you need to maximise the number of cars that pass that feature! Hence every "delay" is additive.
On the Mway, all the 50mph limit does is to make the queue a "rolling" one. I.E instead of being stationary, it slows people down BEFORE they get to the feature. As a result you are still held up by precisely the same amount of time as before, but you are moving whilst being held up!
For example, my local town bypass put a new traffic light controlled junction (previously normal r/about) on the main M-way exit to the Town. Town councilors proudly announced after a years study that "Congestion in the Town has fallen by 30%". ER Der, Of course it has, every one is now queuing OUTSIDE the town you idiots!
They claim "traffic congestion has been massively reduced" which to anyone with even half a brain just shows how massively stupid people like this are..............
mikewsmith
And there is nothing wrong with this^^^ as long as it is done sensibly! It should be clear that "slowly rolling along in gear with enough of a gap to avoid stop/starting" is a whole different kettle of fish to "stopping completely and leaving a '600' yard gap!
As a driver part of your responsibility is to drive your car in a fashion that gives other drivers the minimum inconvenience. There are plenty of scenarios where occupying the moral or legal "High ground" inconveniences others, and this would be one of them.
At this point I could build a nice little model to show queue times and journey times to demonstrate why such things work, how and why logic doesn't always hold true... But it's a nice Sunday. The variable speed limits can improve flow and journey times by management rather than just keeping things moving. People's obsession with making a place or few seconds are part of the problem.
you idiots!
We're really not. A couple of advantages over and above the smooth, regular flow of traffic.
At a lower speed a greater number of cars can be stocked on the motorway whilst still respecting a two second gap.
The accordion effect is much reduced so there are less accidents which result in lane or road closures.
More cars will get through a junction if they are already moving than if they have to start up to approach the junction, particularly at roundabouts.
What's the difference between the OP's point and this:
I'm cycling a long a road, approx 100m from a set of traffic lights (currently red) a car behind me accelerates to overtake and then immediately pulls in and has to brake sharply for the red light. I then re-overtake the now stationary car and take primary position in the ASL box and slowly make my way forward when the light goes green.
IMO, both are evidence of the same thing - a lot (perhaps a majority, perhaps not) of drivers have no concept of what will actually cause any sort of delay in their journey time. In the OP the overtaking driver had clearly decided that the chap in front was having a delaying impact on his journey, when clearly any rational thought would suggest otherwise. In my example exactly the same applies, however it happens so often I wonder if there is some psychological basis for it.
This is similar to people taking massively circuitous routes to avoid traffic, when often these routes actually take longer than if you just went the direct route and accepted you might be stationary for 5mins at some point during the journey.
The change in psychology of people when they get behind the wheel of a car is fascinating imo. They behave in ways they otherwise wouldn't and which are entirely illogical.
mikewsmith - Member
Had a little bit of a LOL at that^^^
(the irony of building a mathematical model to show that logic doesn't hold true! Let me help you with that TRUE = FALSE. there! 😉
PS, this post is mean't tongue in cheek and should be taken that way!!!)
Incidentally, the "maximise thoughput too preventing queuing" only works because on average, drivers do dawdle and fail to proceed!
maxtorque - MemberAs a driver part of your responsibility is to drive your car in a fashion that gives other drivers the minimum inconvenience. There are plenty of scenarios where occupying the moral or legal "High ground" inconveniences others, and this would be one of them.
Go on then, what's the inconvenience of leaving the gap? I'll give you a clue: the person behind will arrive at their destination at exactly the same time as they would if the gap hadn't been left.
Edukator
At a lower speed a greater number of cars can be [b]stocked[/b] on the motorway whilst still respecting a two second gap.
Interesting choice of words you have used to attempt to persuade me that going slower helps one get to where one is going faster...... 😆
3 local roads to watch it happen, Hoole road in chester 30 mph speed limit, tailbacks into the cityCoast road at Ainsdale to Southport, cycle lane goes alongside it, so plenty of viewing opportunities,
You want to overtake on Hoole Road? Asking the question and using this as an example says more about you and your driving, and my impression is not good.
This is a busy road with cars parked on either side with many side roads where traffic want to join the flow. I have driven down here leaving space for cars to join Hoole Rd or turn right into Faulkner Street.
Why do I do this? Because I know there is nothing to be gained by being nose to tail and if anything, not allowing other traffic to flow is likely to create more problems. You're not going to gain anything as you're likely to get caught at either of the two pedestrian crossings in Hoole and Flookersbrook, if not there, you'll get caught at the Brook Street lights.
I look forward to your "Why won't people let me pull out of the side road?" thread.
EDIT: I challenge you to drive down this road at 30mph and I bet a huge gap opens up infront of you too. 😉
The A483 is likely done by locals who know that there's no point racing to the McDonalds roundabout as this is the likely cause of traffic building up, and the dual carriagway going from 2 lanes to one at Ruabon. Why not sit back and enjoy the view if there is a traffic jam? If you're in that much of a rush, wait until you get past the roundabout and attack the traffic head on as you drop towards the Gledrid roundabout. either way you're going to get wound up at the lack of passing opportunities once you get past Oswestry anyway.
I question your ability to judge traffic and drive safely
pjt201Go on then, what's the inconvenience of leaving the gap? I'll give you a clue: the person behind will arrive at their destination at exactly the same time as they would if the gap hadn't been left.
It's the fact that the following driver can misconstrue your actions, resulting in them overtaking and both them and you getting angry with each other over nothing whatsoever!
Remember, when driving other people on the road aren't physic! The following driver, when they see what they consider to be abnormal actions WILL react. It doesn't matter if you are or are not causing any greater obstruction, simply being perceived to be doing so is enough to cause inconvenience.
@maxtorque - I think your definition of inconvenience must be different to mine. This all goes back to the bizarre logic displayed by many drivers. (myself included sometimes).
Might react. When I slow down to let tailgaters go I sometimes get down to walking pace before they wake up and overtake.
One bad driver trying to teach another bad driver how to drive. Lolz.
Not trying to teach anyone anything, just trying to avoid being crashed in to.
pjt201 - Member
So why so you think the following driver felt the need to overtake?
I'm using the word "inconvenience" to refer to any driving actions you (or i) might make that causes another driver to react or change their course or speed.
For example, I often see people pull out into the right hand land of the Mway, causing a rapidly approaching (often speeding) car in that lane to have to brake.
Now they are completely within their right to do that, but it inconveniences the other driver and adds unnecessary risk and the potential for anger that could have easily been avoided.
Of course, the rapidly approaching driver in L3 also needs to understand that the car following that lorry in L2 might pull out in front of them, as it works both ways!
This is what i mean: Drive in a fashion that brings you into the MINIMUM potential conflict with other road users!
Classic STW motoring thread - it's like the Jeremy Vine show in here.
If someone was stopped in front of me and left a 600' gap I'd think they'd broken down.
As TJ used to point out, sometimes adopting a road position which is safe will irritate other road users. Most of the time being polite and courteous are also safe. Sometimes just respecting the law winds people up. I mentioned the aggressive behaviour driving a van at the van speed limit can provoke though some posters didn't believe me. Overtake in L3 at the limit plus speedo error and some people will get angry with you (tailgate, horn, flashing lights). Some people will seek conflict, don't let them bully you into doing something less safe.
Madame leaves big gaps, this sometime irritates drivers behind. However, when the car in front of her aquaplaned and span she just gently braked, didn't crash into it and didn't get hit from behind.
Coast road at Ainsdale to Southport, cycle lane goes alongside it, so plenty of viewing opportunities,and the A 483 from the Ruabon to A5 turn off. If ever on these roads at busy times check it out.
The A483 is likely done by locals who know that there's no point racing to the McDonalds roundabout as this is the likely cause of traffic building up, and the dual carriagway going from 2 lanes to one at Ruabon. Why not sit back and enjoy the view if there is a traffic jam? If you're in that much of a rush, wait until you get past the roundabout and attack the traffic head on as you drop towards the Gledrid roundabout. either way you're going to get wound up at the lack of passing opportunities once you get past Oswestry anyway.I question your ability to judge traffic and drive safely
POSTED 3 HOURS AGO #
Thankfully not me i was just an observor on many times on these roads, also theres a crossing at Park Drive,new doublw yellow lines, 2 footway build outs at the crossing points a traffic island a speed camera, and a shared use cycle path all on Hoole road.
I now question your ability to read the thread properley abnd to observe all the above points
[b]Thankfully not me i was just an observor[/b] on many times on these roads, also theres a crossing at Park Drive,new doublw yellow lines, 2 footway build outs at the crossing points a traffic island a speed camera, and a shared use cycle path all on Hoole road.
That's what they all say.
The traffic is seldom backed up past Newton Lane enough for those to warrant a mention. 😉
