IOS 5.1.1 issues
[Closed] IOS 5.1.1 issues
5 Users
Crashing repeatedly anyone?
Debugger messages showing PANIC
yyyy-mm-ddhhmmss.panic.plist
About 4 crashes in 2 days. Duing safari and camera operations.
Only installed latest software yesterday and
Posted : 10/06/2012 5:32 pm
It's ok for me. I only just installed it a few weeks ago on my iPhone 4. Do a reset or load a back up?
Posted : 10/06/2012 5:36 pm
no problems here worth just doing a factory restore.
Certainly looks like what's known as a kernel panic. Not had any significant issues with software upgrades on my two iPhones, a 3 and a 4, or my iPad. Is it properly backed-up? If so, I would suggest doing a restore to factory settings, then do a restore from back-up.
I did that once, after I did something daft, a 3-finger tap, which zoomed the screen right out, without realising what I'd done. What I should have done was google it. Instead I went the restore route. It worked fine, except it didn't cure what I [i]thought[/i] was a problem and wasn't. It may well help with your problem, but you could google it because the Apple Forums may well have it well documented.
Posted : 10/06/2012 5:42 pm
Sounds like a fresh restore and set up as new not restore from backup will fix this(if it's hardware related Apple will replace)
Check out Dev-Team blog everything you could want to know and more.
Posted : 10/06/2012 5:52 pm
Another 3 crashes in last hour, plugged into macbook and itunes launches saying iphone is in recovery mode. Let it do a restore and update and see what happens.
Got an appointment at store booked in for Tuesday, that will be fun as im due looking after my 18mth old daughter.
Posted : 10/06/2012 6:36 pm
Well its now completely knackered and im on call.... oops
It wont restart and the apple logo keeps coming on in a loop. I've plugged it into laptop which shows recover mode however when doing a restore it just hangs on the Restoring software bit. It goes through restore authorisation fine.
So im left nothing. Any options other than smashing it with a hammer which is what i feel like doing.
Posted : 10/06/2012 8:58 pm
