Inflatable hot tub ...
[Closed] Inflatable hot tub insulated covers?
 ed34
[#12076510]
Anyone got any recommendations for inflatable hot tub insulated covers?
Found these 2
https://cwtchy-covers.co.uk/
https://inflatablehottubthermalcovers.com/
Anybody used them, or other companies?
My DIY cool bag over the pump, and foam mats over the lid is saving about 70p a day according to the energy monitor plug, so a proper fitting one and a jacket for the sides should be cost effective within a year
Thanks
Posted : 17/10/2021 12:21 pm
What you want is a massive rubber, to keep the spunk from dribbling down the sides.
Posted : 17/10/2021 8:13 pm
Also interested in insulation and spunk drain products.
Posted : 17/10/2021 9:27 pm
70p a day saving is quite a bit. Ours probably costs £5 or £6 a day to run.
Ours is within a wooden gazebo that's covered, so out of the wind. We've currently got all the outdoor furniture cushions on the top of it (dry storage). I might try kingspan or something similat over the top.
I'd assume you've got to remove the side jackets, as you'll only get water going over the side between both.
Posted : 19/10/2021 2:40 pm
Meanwhile, on the Heat Source Pump and Climate Change threads...
Posted : 19/10/2021 2:52 pm
 ed34
I’d assume you’ve got to remove the side jackets, as you’ll only get water going over the side between both.
I think you leave them on, the fabric pouch the insulation is in is waterproof, and they're supposed to be a snug fit so would any water getting down the sides matter?
70p a day also includes putting a better mat underneath (interlocking kids foam play tiles!) which I forgot in the first post, but can feel some heat loss from the sides so been looking at the insulated jackets.
Posted : 19/10/2021 3:34 pm
Wow. That is nuts. I knew sex ponds were expensive but I genuinely had no idea they were that expensive.
Funny old world.
Posted : 19/10/2021 3:58 pm
Holy ****
Posted : 19/10/2021 4:05 pm
Sous Vide semen. Delectable.
Posted : 19/10/2021 4:10 pm
Just checked and I used £40 electricity last month for a three bedroom granite house built in the 1940's.
So £5 * 30 days = £150 a month to run an inflatable hot tub, that can't be right!!!
Posted : 19/10/2021 4:13 pm
So £5 * 30 days = £150 a month to run an inflatable hot tub, that can’t be right!!!
Value depends on how much jiggy jiggy you get by having a sex pond.
Posted : 19/10/2021 4:55 pm
I'd want water with the viscosity of custard if I was getting a fiver a day's worth out of it.
Posted : 19/10/2021 4:57 pm
 ed34
Yeah are you sure that right? Ours is set at 37 degrees, works out at 2.35 a day with the kids using it nearly every day. Hopefully more side and kid5 insulation will knock it down a chunk more
Posted : 19/10/2021 5:21 pm
Just caused a coffee:keyboard interface.
Posted : 19/10/2021 5:22 pm
Obscene wastes of energy like this should be banned.
Posted : 19/10/2021 9:09 pm
It's probably £3 a day. Add in the teens gaming machines...ouch. Our total electric is £160 a month normally. The dry is used reglaar as well. I think insulating the motor is a great idea. Underneath additionally insulated already, and it's protected from any loss through wind.
I'm thinking of adding a kingspan type top, enable it to be folded - The existing top is insulated to some extent, but you can always make it better.
Posted : 19/10/2021 10:21 pm
 ed34
I agree! Please come round and tell that to my wife and kids!
Posted : 19/10/2021 11:59 pm
Same here, tell the wife please.
Then again, who drives round in a massive car or van, buys bikes like underpant changes, etc etc.
I've made sure ours doesn't waste too much energy through environmental loss (i.e. it's not just sat on the patio) - I've warned my BIL about increased leccy since he got his recently.
Posted : 20/10/2021 10:51 am
Sorry if this is a naive question, but do you have to keep them warm all the time then?
And how often do you use them?
I’d want water with the viscosity of custard
I presume they get like that anyway if you don't change the water (y'know, with love custard).
Posted : 20/10/2021 11:14 am
