Induction hobs - an...
[Closed] Induction hobs - any good for stir frying on?
Speccing out our new kitchen and was looking at getting a 5 burner induction hob, now thinking maybe 4 burner induction and a single gas wok burner?
What are your experiences like wrt induction and stir frying?
Posted : 06/03/2017 2:00 pm
 sbob
Woks only work on gas.
Posted : 06/03/2017 2:12 pm
I practically live on stir fry, and have an induction hob. I bought a proper induction hob wok (they exist). I didn't notice any difference in functionality, taste, or my satisfaction. 8)
Posted : 06/03/2017 2:23 pm
How often do you actually use a wok where no other pan would do? Use a wok with a flat base? Use a big frying pan?
There are plenty of work arounds. Personally I think having a separate gas burner detracts from the clean lines that an induction hub gives.
Posted : 06/03/2017 2:25 pm
Response times on induction hobs is so good, I wouldn't bother with the gas. We have a flat bottomed wok, and stir fry using an induction hob. No problem at all.
Posted : 06/03/2017 2:27 pm
Interesting. Not having ever used an induction hob I thought they wouldn't be so effective as gas for stir frying as the heat is only really from the bottom, whereas stir frying needs heat from all around the bottom and up the sides of the pan. Hmm yeah maybe I don't need a wok burner.
Posted : 06/03/2017 2:46 pm
We're currently induction only… get the gas hob for the wok… don't hesitate.
We've got [url= http://www.aeg.co.uk/kitchen/cooking/hobs/induction-hob/hd955100nb/ ]one of these[/url] in our kitchen for a best of both worlds solution. I think if we were on mains gas we'd have gone for an all gas hob though.
Posted : 06/03/2017 2:58 pm
 sbob
We have a [s]flat bottomed wok[/s] frying pan
Posted : 06/03/2017 3:07 pm
Flat bottomed grills make the wokking world go round...
IGMC
Posted : 06/03/2017 3:22 pm
Same thing.
Posted : 06/03/2017 3:24 pm
She taught me to wok this way.
Posted : 06/03/2017 3:28 pm
You wok the wok, do you torque the torque?
Posted : 06/03/2017 3:33 pm
A flat bottomed wok works fine for me, on an induction hob. Who cares whether it is a 'traditional' wok or not.
Easy to control the heat, it can heat up pretty quick on full power. And a lot less faff than gas, easy to wipe clean etc.
Posted : 06/03/2017 3:34 pm
Have a Seimens 5 ring induction hob. When on 'Boost" power, if you don't keep food moving around it either burns or sticks - it chucks out a lot of energy.
The beauty of induction is the control. I've yet to use a gas hob that you can turn down REALLY low (with such a large area of heat transfer). Great for slow cooking curries/paella etc.
Yes you have to fork out a lot of cash (and get pans that work on it), but it's easy to wipe clean and I'll never go back to gas.
Different pan brands transfer different amounts of heat. Cheap is not always best!
Posted : 06/03/2017 5:25 pm
Which is what those 'wok shaped' induction wok units are for - they put heat right the way up the side of the pan.
Induction is excellent for most things. Hugely powerful when needed, simmers at a very low temperature consistently. Puts far less waste heat into the room. You won't get a true wok on one but i'd say a flat bottomed one will work well enough.
Posted : 06/03/2017 5:27 pm
@bark has nailed it, if its important buy a proper pan. We do a bit of stir fry with a normal large frying pan and it works ok. The topmost setting on induction is "nuclear" 😯
Posted : 06/03/2017 5:36 pm
We have a biggish gas range with 5 burners on it complete with cast iron pan stands. Having seen how well induction hobs work I bloody hate our range and the cleaning up involved 🙁
 sbob
gonefishin - Member
Must admit, I do a lot of Asian cooking in a wok where the style is very "dynamic". Simply wouldn't work with the very static nature of induction hobs, but then I've learnt to cook in Asia and in professional kitchens; it's lively! 😀
Posted : 06/03/2017 6:52 pm
Cooking with an an induction job needn't be static. The pan first go cold instantly if you lift it off the hob.
I remember seeing quite a few of them in Cambodia although that was quite some time ago
Posted : 06/03/2017 8:09 pm
Metal conducted heat, last I checked.
*applause*
Posted : 06/03/2017 9:32 pm
OP,
Induction hobs are fine for wok so long as you use flat bottom wok.
The wok needs to be "magnetic" ...
My advice is to get 3 to 5-ply stainless steel wok that can be magnetised, because there some that aren't so will not work on induction hobs.
There are many good 3 to 5 ply stainless steel wok available but they are not cheap.
John Lewis = 5-ply stainless steel wok is £85 with the lid. This one is heavy. This is the one I have and I use a cheapo aluminum lid from my carbon wok for it.
Fenwick = Zwilling 3-ply stainless steel wok £129 with nice glass lid. This one is light.
Demeyere also do stainless steel wok.
Try to get a wok without inner rivets coz that's a pain with spatula ...
There are many other brands but those two are the one I can find locally to me in the Toon.
However, you will need a period of training to make it non-stick by playing the temperature. I think adjusting temperature with induction hob is easier.
The stainless steel wok is gaining popularity amongst some housewives in the far east ...
As for taste there is not much difference as far as I am concerned. i.e. if you are a good cook then you are ...
Fry pan = a wok ... 😆
You will have flying food all over if you do quick stir fry action with a fry plan.
I think I have 8 woks as I keep trying to get the best one because I don't have a turbo gas burner ... got a cheapo stainless steel wok just for doing steaming ...
Posted : 06/03/2017 9:48 pm
but not all metal is magnetic and that is how the heat is created .
Posted : 07/03/2017 12:10 am
I use something very similar to this [url= http://amzn.eu/8gflt3E ]Carbon Steel Wok[/url].(but with a flat bottom!) Works nearly as well as it did on gas. No need to spend bag loads of money on induction specific pans 😉
Posted : 07/03/2017 8:39 am
Surely its the current in the pan that creates the heat?
Posted : 07/03/2017 9:29 am
No mention of wok hei that you can't achieve with domestic burners anyway?
Standards are slipping.
Posted : 07/03/2017 3:23 pm
Alternatively you could always got for an [url= http://www.stellarcookware.co.uk/Ranges/Stellar-Electricals/Electric-Wok.html ]electric wok[/url].
We were bought one of them a few years ago and use it at least once a week - it's far easier to keep clean than a gas hob & wok combo but as I've just fitted an induction hob in the last couple of weeks I may have to try a proper wok on that sometime.
Posted : 07/03/2017 3:31 pm
 sbob
The Pinkster - Member
Alternatively you could always got for an electric wok.
That will not get hot enough to cook a proper stir fry without the non-stick coating burning off.
Posted : 07/03/2017 4:01 pm
260C is pretty damn hot. The again if you have temperatures that high the likelihood of anything sticking to a normal pan is pretty low.
Posted : 07/03/2017 4:13 pm
 sbob
gonefishin - Member
Not for proper wok cooking! 🙂
Posted : 07/03/2017 4:39 pm
You don't use Boost for cooking, you use it to bring a pan of water to the boil in 10 seconds and then turn it down.
You must be nuking your dinner!
Posted : 07/03/2017 4:50 pm
Induction hobs are great for stir frying on, and I wouldn't go back to archaic inefficient slow gas again.
Or maybe I just have imaginary stir fries?
Posted : 07/03/2017 5:35 pm
 sbob
Gas is plenty quick! 🙂
Probably not, but I'll cook you better. 😀
ETA: sometimes I cook on wood or coals, that'll [i]really[/i] blow your mind!
Posted : 08/03/2017 3:57 am
So any recommendation for a good hob? Not that bothered about anything fancy but quick and simple controls would be a must.
A friend has a halogen hob and the controls do my head in, having to select the hob and then choose the power level might not be the end of the world but bloody annoying still.
Posted : 08/03/2017 8:13 am
In true STW fashion of recommend what you have, we have a [url= http://www.smeguk.com/product/si5952b/ ]smeg si5952b[/url].
Its very good.
Posted : 08/03/2017 9:45 am
There are a few that have touch controls separately for each 'burner'. That's one of reasons we chose our Siemens.
De Dietrich used to but not sure if they're imported to the UK any longer.
Posted : 08/03/2017 12:09 pm
I rinse out my wok with clean warm water and dry it with a kitchen towel. How is that difficult?
Posted : 08/03/2017 12:47 pm
