I'm a lumberja...
[Closed] I'm a lumberjack and I'm alright...(well, I'm not really..)
24 Users
 DrP
Just 'getting more STW' in my ways, and sorting out a woodburner..
What's the deal with small hatchets for chopping/splitting for kindling??
They can vary from £10 to £110 and beyond...
Anyone recommend a decent hand hatchet for splitting small logs/palletts for kindling please??!!
DrP
Posted : 27/02/2015 8:04 am
Do you want something nice or something cheap?
[url= http://www.abbeygardensales.co.uk/hand-tools/axes-and-splitting-mauls/showitem-EL-576926801.aspx ]This[/url] would be ideal for splitting small logs and kindling. With a bit of snading and some linseed oil it'll look and feel lovely. Can be found cheap on amazon I think.
or if you want to go cheap and chearful something like [url= http://www.diy.com/departments/bq-steel-axe-865g/30141_BQ.prd ]this[/url] will be fine for kindling, and probably more suitable for breaking up pallets.
[img] http://kingfisher.scene7.com/is/image/Kingfisher/bnqTemplate1?$overlayHide=1&$product=Kingfisher/5036066_01c&wid=425&hei=425 [/img]
Posted : 27/02/2015 8:06 am
I just got a cheapo £7 jobbie from the tool shop in the Metro Centre, then sharpened it with the angle grinder.
It's for chopping small bits of wood.
Posted : 27/02/2015 8:07 am
I picked up a little Fiskars axe in canada. It's been comlpletely brilliant.
Posted : 27/02/2015 8:22 am
 DrP
Cheers...
Went for [url= http://www.amazon.co.uk/dp/B003XII9DQ/ref=sr_ph?ie=UTF8&qid=1425025490&sr=1&keywords=Mannesmann+76531+Hatchet+800g%27+by+Mannesmann ]this[/url]..
Now for my revenge spree, I mean wood cutting..
DrP
Posted : 27/02/2015 8:25 am
The whole point of buying a woodburner is to have an excuse to buy axes and live out your Lumberjack/Nick Offerman fantasies. So buy yourself a nice one!
Posted : 27/02/2015 8:26 am
More importantly, have you grown a beard yet DrP?
If not, you shouldn't really be using an axe unsupervised...
Posted : 27/02/2015 9:02 am
 DrP
[url= http://www.drpidgeon.co.uk/blog/the-secret-bivi-spotjust-south-of-the-ae-entrance ]I shouldn't really use anything sharp unsupervised...[/url]
DrP
Posted : 27/02/2015 9:18 am
Chopping sticks? £10 jobby will be as good as anything else. I find that pallets need a chainsaw otherwise they're a PITA.
YMMV
Edit: the one you've gone for looks just the job DrDeath.
For kindling, I'm on the "anything cheap will do" side. You're just splitting with the grain, hitting a nail is the only issue.
This was mine:
http://www.qwikfast.co.uk/shop/silverline-hardwood-shaft-hatchet-1-5lb-ha68/
Not the most beautiful tool (handle was a bit damaged and splintery in one place) but it works fine.
Posted : 27/02/2015 9:21 am
Jeez, DrP, you put my own sharps-derived injuries to shame! 😯
My hatchet is just a £10 job from the tool shed, and after 5 years and no sharpening, still works great.
Posted : 27/02/2015 9:49 am
Personally I have 2 from [url= http://www.gransforsbruk.com/ ]Gränsfors Bruk[/url]
Proper axes and been making them over 100 years.
However may be a little OTT for some smashing pallets up.
Posted : 27/02/2015 9:51 am
Bream - Member
Personally I have 2 from Gränsfors Bruk
I wouldn't go near a pallet with my Gransfors [i]or[/i] my chainsaw. Sledge hammer and a pry bar.
Posted : 27/02/2015 9:58 am
I thought it was 'I'm a lumberjack and I'm okay'
Posted : 27/02/2015 10:02 am
 DrP
I'm going to need a bigger axe...
DrP
Posted : 06/03/2015 12:17 pm
I now understand the whole hipster thing. It has developed from wood burning stove ownership.
Posted : 06/03/2015 12:20 pm
[i]I'm going to need a bigger axe...[/i]
That's not your new rustic window cill then?
Posted : 06/03/2015 12:22 pm
 DrP
Yes?
DrP
Posted : 06/03/2015 12:25 pm
 JAG
Most of the Hipsters I know wouldn't go outside and dirty their hands with something nasty and sharp 🙂
Posted : 06/03/2015 12:51 pm
with that lot youll buy a bigger axe , realise its the wrong toolfor the job
buy a small bush saw and realise its the wrong tool for the job
and then youll buy a chainsaw.
skip to step 3 if you plan on having wood like that often.
Posted : 06/03/2015 12:58 pm
I've got a £10 B&Q job which has been working fine for a number of years.
Posted : 06/03/2015 1:02 pm
 DrP
Have access to one... but will need to split it.. I suppose my hatchet may do..
DrP
Posted : 06/03/2015 1:59 pm
 kcal
splitter maul might make a decent job of that.
Salvage one of the chunkier cuts for a splitting platform.
probably as per t_r says though, if only because it'll probably be a bit 'sticky' for a plain old bush saw. And find a friendly person to borrow a trailer from as well..
Up round here there are several cooperages selling whisky barrel offcuts, by the ton, the calorific value in them is terrific!!
Posted : 06/03/2015 2:09 pm
DrP - Member
DrP
Oh
Dear
God.....
Posted : 06/03/2015 2:10 pm
kcal - Member
A maul for that? 🙄 Cut to length you could split that with a brush hook (not that I would). The splitting hatchet I linked to would be more than adequate.
Posted : 06/03/2015 2:31 pm
 JoeG
[url= http://www.fs.fed.us/t-d/pubs/pdfpubs/pdf99232823/pdf99232823Pdpi300.pdf ]An Axe to Grind pdf[/url] and the video
Posted : 06/03/2015 5:54 pm
Never use a sharp axe
Posted : 06/03/2015 7:34 pm
Toolstation do a hickory shaft maul and small axe, which is ideal for splitting kindling, circa £17. I've split many tons of hardwood with them, then you can decide if you want to buy a designer axe.
Posted : 06/03/2015 7:38 pm
When did functional become a synonym for homoerotic?
http://www.drpidgeon.co.uk/store/p7/McMinns_functional_and_clinical_anatomy.html
Posted : 06/03/2015 7:53 pm
trailmoggy - Member
What?
Posted : 06/03/2015 9:07 pm
If Dr P and WCA ever go out on a bivi night together the local PCT are going to call an emergency and cancel all leave!
Posted : 06/03/2015 9:18 pm
Never mind what axe, I need your open fire calzone recipe please.
Posted : 06/03/2015 9:30 pm
